Question about Mag Innovision lt456s 14" Flat Panel LCD Monitor
A Simple Power Adaptor Issue
Hey,
I recently purchased a Mag 14" LT-456s LCD Monitor. Upon trying to plug the unit into the AC adapter cable provided, I could not find the port to plug the cable into the back of the monitor. Next to the video cable on the bottom of the unit is what appears to be a small metal plate that is more than likely in place to protect the AC adapter port. However, I cannot figure out how to remove the plate in order to access the port. Any help with this issue would be greatly appreciated. Thanks for your time.
  • wallace_step May 17, 2009
    I was finally able to get the plate off only to discover there is nothing under it at all. Unfortunately, I am still unsuccessful in finding out where the power cable plugs into this monitor as there are no other alternatives that I can see. If anyone has a model similar to this or can provide me with any kind of information about this model, I would greatly appreciate it. Thanks again.
  • wallace_step May 20, 2009
    Finally got the issue resolved. The power connector port is actually on the back of the VGA connector that plugs into the back of the computer. Strange place for a power connector but of course was the only place I did not think to check. Thanks all for the help and time.
  • 102 Answers
See are u sure that cable is for that slot...
try to open it as slider or use some lever to open it
Posted on May 17, 2009
  • Roger Jul 28, 2011
    Another 'wiz'. sheesh. just suggest they stab at it with a screw driver, while the power's on.
The power cable plus into the port which is on the VGA connector. The metal plate you mention is a hinge I think.
Posted on Oct 14, 2012
Cant figure out where the power cord goes or even if it has one...
There are several Mag monitors that use external AC adapters that plug into the VGA cable. Look on the blue connector and you should see the hole where the adapter plugs. The adapter is 12v 5 amp such as this one.
http://www.ccl-la.com/catalog/product_info.php?products_id=48
Dec 03, 2012 | Mag Innovision InnoVision LT 765S 17" Flat...
I am unable to get MAG Innovision 14" LCD monitor
You need laptop-type 12V, 2.5A (minimum) adapter plugged into back of VGA plug
Nov 13, 2010 | Mag Innovision lt456s 14" Flat Panel LCD...
I need a driver i think for my mag lt456s monitor i hook it up to computer and i get no power or anything
first check the power cable connection at both end i.e. source of power and also at monitor side if loosen one tight it or may try to change the cable
Sep 06, 2010 | Mag Innovision lt456s 14" Flat Panel LCD...
Need a driver and users manual for mag innovisionLT576s
42905439-177x150-0-0_.jpg ViewSonic (HASU05F) Information: Product details Price Range: $25.00 - $40.00 at 3 stores This AC Adapter is ideal for use with your Flat Panel Monitor or LCD Display. The High performance AC Power Adapter pictured here provides consistent and continuous power at the specified Voltage and more
this is what else u need to power the monitor it is plug and play compatible
make sure your video card has the right software to run monitor
Where can I get drivers for my video cards?
Answer ATI – http://www.atitech.com/
Nvidia - http://www.nvidia.com/
Matrox – http://www.matrox.com/
Pinnacle – http://www.tridentmicro.com/
Trident - http://www.tridentmicro.com/
Diamond Multimedia – http://www.diamondmm.com/
Cirrus Logic - http://www.cirrus.com/en/
http://www.opendrivers.com/driver/214283/mag-lcd-monitor-drivers-windows-95-98-2000-xp-me-nt-free-download.html
heres the driver that you needed for your monitor
I can’t find where the AC power cord plugs in on the back of the monitor. Answer There are two places where the AC connector could be found.
1. Look at the back of the monitor right next to the signal cable connection.
2. If the signal cable does not detach from the monitor, follow the signal cable to the end, and you will see the 15 pin D-Sub connector (blue connector). There you will find a small hole with a pin inside (in between the two notches).
May 26, 2008 | Mag Innovision LT576s 15" Flat Panel LCD...
Does the MAG LT-456s require drivers
Perhaps your screen resolution is set too high. Try using a different display to set your resolution to 800x600, then attach the MAG display. Adjust from there once it is working...
Mar 08, 2008 | Mag Innovision lt456s 14" Flat Panel LCD...
MAG Innovision LT456s monitor power issue.
If you ask them nicely they just might tell you, else it's only $5 for a user manual(sorry no luck online); http://www.maginnovision.com/service.htm this link has a picture that maybe shows a power cable going to the bottom right (as you look at it) but it's hard to be sure; http://www.amazon.com/gp/product/customer-images/B0002CF06K/ref=cm_ciu_pdp_images_all/104-1966292-9407907?ie=UTF8&s=electronics#gallery this link shows what the power lead should be like - look for a hole that matches; http://cgi.ebay.ca/AC-power-adapter-for-MAG-innovision-lt456s-14-LCD_W0QQitemZ8824271526QQcategoryZ3698QQssPageNameZWDVWQQrdZ1QQcmdZViewItem Hope this helps, if not ask again :)
Mar 17, 2007 | Mag Innovision lt456s 14" Flat Panel LCD...
Mag Innovision lt456s 14" Flat Panel LCD Monitor Logo
427 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Jaime Hernandez
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
