Question about Moen Soap & Lotion Dispenser 3910S
I need the plastic replacement pump for the moen soap pump that goes with my kitchen sink. The pump is a 3910. How do I order the part and what is the $$?
Amazon can provide moen soap parts for lowest prices (about 10$). click on this link Watkins Hand Soap Made Naturally Since 1868 and pick one (which one fits, and which one is cheapest)
I hope I have helped you
enjoy
Posted on Nov 19, 2014
  • 3 Answers
You can order it on amazon. Price is about 12$
click on the link bellow Moen 139221 Manufacturer Replacement Part
enjoy
Posted on Oct 10, 2014
Just visit amazon, I bought from there same part for about 9$.
go here Watkins Hand Soap Made Naturally Since 1868 and search which one you need. regards
I had the same issue with the same model of soap pump. You can pay around $60 to replace the entire top of the pump, the plastic and metal piece that comes out. Or, call Moen directly, 1-800-BUYMOEN. You will be on hold for a little bit, they said an hour, but it was about 5 minutes. I told the customer service person the part I needed. About $11.00 for the part, they waved the shipping, had it within a week. When you call, make sure you have your part number. Good luck.
Posted on Jul 09, 2009
  • 3 Answers
I went to Lowes hoping to find a replacement pump for my Moen faucet/soap dispenser, or a cheap dispenser with the same pump. No Dice! No parts and New dispensers started at about $35. I called Moen and to see about buying a new pump, and it turns out my faucet has a lifetime warranty. New pump on the way at no charge.
Posted on Jul 22, 2010
    Sergeant:
    Champion:
  • 225 Answers
Posted on May 17, 2009
I need replacement part for bath sink cartridge 4570
The Moen 1225 or 1200 cartridges are the same except the 1200 is brass in stead of plastic. They will fit most Moen single handle faucets. If it is a two-handle faucet, the 1224 cartridge will fit most two-handle models unless it is a fancy widespread faucet more than about 15 years old. I don't know the model numbers for those cartridges. All of these cartridges require a removal tool if you can't get them out with a pair of pliers.
Dec 09, 2011 | Moen Soap & Lotion Dispenser 3910S
How do i replace gasket on moen facuet in bathroom sink
On a Moen Faucet the set screw is behind the little "blue and red plastic tab", remove this tab very carefully with a small flat screwdriver. Then you should be able to see the set screw. make sure to turn of the water supply under the sink first. The set screw will probably be an "allen head" type and you will need an allen head wrench. This is a hex shaped 6-sided tool in a rod shape and is available at your local hardware in a set. Next you will need the model # of your faucet and take this to your local hardware to match with a repare kit. Moen usually has a lifetime warranty and if you have your paperwork just call Moen directly and they will send you a free replacement kit, free shipping too. The kit has installation instructions with it.
Mar 24, 2010 | Moen 7437 Chateau Single Hole Kitchen...
How do I get to the valve cartridge to replace it?
how to replace moen cartridge for two handle kitchen faucet ... cartridge for two handle kitchen faucet exporters,how to replace moen cartridge for two handle kitchen faucet suppliers,how to replace moen cartridge ...cn-faucet.com/ kp-how-to-replace-moen-cartridge-for-two-handle...
Mar 17, 2010 | Moen Bathroom Sink Faucet - 4-inch...
Moen faucet removal
you will have two mounting nuts at each end and two water line to disconnect for removal under the sink on any faucet made
Feb 13, 2010 | Moen 7310 Legend Single-Handle Kitchen...
The kitchen sink makes a loud popping noise
Try removing the aerator on the faucet. If that resolves the popping sound, try replacing it with one that allows for a higher flow of water. (Also the existing aerator may be clogged).
Jan 05, 2010 | Moen 87555C Trianna Single Handle Pulldown...
I have the above soap dispenser the 3910S in stainless. I have 2 of them in my granite counter in the kitchen. They both do not pump anymore. What do I do ? One is missing the plastic piece that goes...
I would call Moen at 1-800-buy-moen. Depending on weather or not it is under warranty or not, you may be able to get free replancement parts. If the pump mechanism is what is broken, and it is not under warranty, I think they are about $12 from moen.
Dec 26, 2009 | Moen Soap & Lotion Dispenser 3910S
I have a moen pull out kitchen faucet that leaks
You have a bad internal o-ring or the sprayer o-ring is leaking, if you look under the sink turn it off and then turn it back on, if you see it leaking out the center shft where the water pipes go into then the faucet may have a broken pipe or loose pipe. check and tell me where it's leaking at. You can buy kits to repiar them they are inexpensive.
Aug 30, 2009 | Moen 87555C Trianna Single Handle Pulldown...
The spout on built-in chrome sink soap dispenser fell out
The only good solution here is to purchase a new pump.. Sorry
Kurt
Mar 21, 2009 | Home
Kitchen sink soap dispenser won't pump
soap may be too thick or pump tube may not be touching soap in dispencer. try pumping same soap from cup
Mar 08, 2009 | Plumbing
Soap dispenser pump pricefister
Here is the link to installing a Price Pfister Soap dispenser:
Soap Dispenser
Hope this helps!
Nov 23, 2008 | Price Pfister Home
Moen Soap & Lotion Dispenser 3910S Logo
5,533 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
