Question about GE GSS20IEP Side by Side Refrigerator
I hooked up my refrigerator and my ice maker to work. I've checked the waterline. But no water comes out of the dispenser and no ice is being made.
    Problem Solver:
  • 3 Answers
I had the same problem one time and there was something obstructing the fan under my frig and i blew thru it to icemaker with compressed air and it started working
Posted on May 17, 2009
My ice maker stopped working
Test the ice maker cycle button on the bottom of the ice maker, if it cycles and fills, replace the ice maker because that is bad. If it cycles and doesn't fill, you could have a few waterline related issues. Check the water pressure out of the dispenser. If it's very slow Unplug the unit for 24 hours, increase the water pressure to the unit , get all of the moisture out and see if it fills after you plug it back in. I bet it's the ice maker though.
Jan 22, 2015 | Samsung RF265AB (258 cu ft) Bottom Freezer...
My kenmore side by side is not making ice
when was the last time u change your water filter, if water is coming into the ice maker and it don,t make ice that means u have a defective ice maker, if no water comes into the ice maker check the water valve at the back of the refrigerator with an ohm meter for resistance if no resistance is present replace water valve,u should unplug water valve when checking
Jan 16, 2013 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Maytag side by side refrigerator with freezer on the bottom water is spraying everywhere when the ice machine comes on. It has the ice / water dispenser on the front. Any ideas?
Check the water line leading to the ice maker for kinks. Also check the filer and ice tray end of the waterline for obstructions or ice that might be deflecting the water to areas other than the ice tray. Let me know how you make out. :^)
May 01, 2012 | Maytag Refrigerators
Kenmore side by side model #515541 01--replaced water filter -water dispenser works great but no water coming into ice maker - what could be problem? we purchased this used-is there something we have to do...
I had the same problem. Sometimes the tray overfills and freezes in the little line that fills the ice cube tray.
I solved the problem by taking an ice pick and clearing the ice from the end of that little waterline until the water started flowing again.
Feb 10, 2011 | Kenmore 57029 Side by Side Refrigerator
The ice maker works and the water dispenser is not working. We noticed last week that the water wasn't coming out as cold and we changed the filter yesterday but it isn't working??
Check temp setting between 3 and 5 degree. And also check due to over frosting, waterline to dispenser clogged. And also check water hose is no dusty. Thanks.
Feb 07, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
No water to the ice maker
Check that the pipe that fills the ice maker is not iced up. Also check that the solenoid on the back (where the waterline hooks up) is making a humming noise when the ice maker calls for water.
Apr 30, 2010 | GE GSH22SGRSS Side by Side Refrigerator
Ice Maker Not Working
Hi: A lot of reverse osmosis systems don't supply enough water pressure to the ice maker to fill. Contact your manufactrue of your reverse osmosis system and see if it works with icemakers. I thind usually the require at least 20-30psi. Or hook your refrigerator to city pressure to see if it works. Also I don't know if you have just an ice maker or a water dispensing side by side, or your water quality. If you just have an icemaker, most chlorine will evaporate before the ice is frozen, any odors in the water will still be there. Good Luck, Jeff
May 26, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GE profile performance tfx30ppz ice dispenser not working
Had the same problem. The water line from the valve to the ice maker was cracked due to heat from the compressor.
Jan 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Kenmore Refrigerator stopped dispensing water
Either your water tank in the fridge froze up, the waterline that goes up the freezer door from the bottom hinge froze, or the switch that your glass hits is damaged. Do you hear any humming or noises when you put your glass up to get water?
Oct 27, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker wont make ice
It is quite possible that the water line which feeds the ice maker is frozen. Whirlpool manufactures a "REPLACEMENT" water line that solves this problem. Fortunatly our problem occured while the refrigerator was still under warranty. I would suggest that anyone owning a Whirlpool product purchase the longest extended warranty available! They USED to manufacture a quality product. But I guess they just don't care about the consumer any longer. It is all about money!!
May 16, 2007 | Whirlpool GD2SHGX Refrigerator
GE GSS20IEP Side by Side Refrigerator Logo
123 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
