Question about Air Tools & Compressors
My compressor will only pump up to 50 lbs of presure no matter how long it runs. What is wrong. The guy I bought it from said it would pump 80 lbs but now it will not even do that. It should pump up to 150 lbs. What do I have to check or replace to fix it.
  • 27 Answers
Check for air leaks of course. I presume it is not too old so the piston should not be worn out.   It might be a defective valve on the air intake. If under warranty- take it back, it should easily do 80 lbs.
Posted on May 17, 2009
1996 chevy tahoe 5.7l vortec , fuel pressure is 50 psi and runs perfect but when you give it gas it bogs out and wont go
YOUR LUCKY IT RUNS AT ALL THAT IS LOW PRESURE LOOKS LIKE FULE PUMP TIME FULE PRESURE NEEDS TO CLOSER TO 60 LBS PLUS THATS WHY IT IS BOGGING OUT YOU CAN TRY CHANGING THE FUEL FILTER BUT IT LOOKS LIKE TIME FOR ANEW FULE PUMP HOW OLD IS THE PUMP AND WHAT IS THE MILAGE ON THE TAHOE 150K PLUS RIGHT OR MORE
Mar 03, 2011 | 1996 Chevrolet Tahoe
My current water tank was installed 12 years ago With Bladder. 1 hp motor. 80 gals. Water Pressure is consistantly low. When reset to 40-50 lbs, it drops shortly after back to thirty lbs in the house....
If I understand you, this is a water well. For pressure to drop, water must be going somewhere. If you see no leak in the tank, that is not the problem.
Check all outlets, faucets, toilets, showers, outside faucets, etc. If you see no leaks and the pressure is still dropping, there is a check valve either before the pump or in the well and this could be leaking back. Either way, the pressure should drop to zero unless the pump comes back on.
Gary
Jan 25, 2011 | Wel - Bilt Electric Portable Air...
Need to adjust Sq D 9013 GHG2
Here are the ranges your your pressure switch.
9013GHG2
Fluids / Pressure controlled Water or Air
Cut-0ut PSIG (bar) 60-200
Cut-In PSIG (bar) 40-170
Weight lbs (kg) 2 lbs (0.91) 2 lbs (0.91)
First set the cut out pressure turning the nut on the spring. To raise the pressure turn nut clockwise depressing the spring. Adjust this so you device stops at 110 psi. Remember when you raise the cutoutpressure the cut in pressure will also raise. When you get the cut out pressure at 110, then your cut in presure will be approx 90 psi (current 60psi +30psi you raised the cut out pressure). Now you can lower the cut in pressure but backing out the differential nut, the smaller size. Until the device cuts out aht the 80psi you want.
Jul 02, 2010 | Square D 9013FHG14J52M1X Air Compressor...
I have an IR Air Compressor #SS3 E. It want stop running/building up pressure. I am sure its the pressure relief valve, but there are 2. One at the presure regulator and the other at the pump and motor.How...
if it is lifting both valves I would say that the pressure switch (regulator as you call it) is defective, if you try to shut it off using the manual switch and it keeps running, I would say that the switch is welded shut. if it does not shut off by 125 psi then it is faulty. The pressure switch is what controls the motor in response to pressure in the tank.
Jan 31, 2010 | Ingersoll Rand Type 30 Reciprocating Air...
My compressor doesn't build enough pessure.
SOUNDS LIKE THE VALVES IN YOUR HEAD ARE NOT CLOSING ALL THE WAY. THEY ARE MOST LIKELY REED VALVES, THIN STRIPS OF METAL THAT OPEN AND CLOSE WHEN THE PISTON MOVES. MAKE SURE THEY ARE CLOSING ALL THE WAY (NOT CARBONED UP). DID YOU REMOVE THE HEAD AND DID YOU PUT BACK LIKE YOU FOUND IT. NOT TURNED OR FLIPPED OVER.
Mar 18, 2009 | Craftsman Air Tools & Compressors
96 intrapid 3.5
hi how are you?just because you hear the fuel pump running does not mean that it is pumping enough preasuer to the motor to open the injectors. you need 48 lbs with key on engine off and with the vacume line off the presure regulator.if you have enough presure then you will have to check for a good blue spark.the fuel presure test port is located just under the thermostat housing on the steel fuel rail.
Feb 02, 2009 | Dodge Intrepid Cars & Trucks
Air Tools & Compressors Logo
149 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
