Question about Olympus D-535 Zoom / C370 Zoom Digital Camera
My olumpus XD-Picture Card is stuck in my laptop. It is the kind you pop in, and then press slightly to eject. It does not respond to being slightly pressed (pushed) to eject. I have been unable to dislodge it with tweezers, and it is a snug fit so tilting the computer does not work (gravity is useless since it is not loose).
It's fixed. I took a key-chain-size Kroger card, cut it so that it could fit into the slot under the card, put a piece of tape so that the sticky side sort of grabbed the card, took the tweezers and pushed down slightly on the top of the card while pushing up with the Kroger card, and by using these two implements pulled the card out. Someone else had the idea for the key-chain size card and tape, but it took the tweezers as well in order to grab the card & pull it out. Thanks!
Posted on May 17, 2009
Xd picture card will not click into place on Olympus e-420. Results in prompt "card reader error."
Are you sure it is a xD card and not an SDXC?
Then there should be a little arrow, pointing in the direction it should be going while inserting.
Try to eject the card and reinsert the card.
If you never used a xD card, and nobody else ever tried to put something in the slot, the card should go in smooth.
After placing the card, don't forget to format the card in the camera.
Sep 18, 2014 | Olympus E-420 Digital Camera
How do you remove stuck disk
If holding down the eject button on the keyboard when restarting doesn't work, then the easiest way is to insert a business card of credit card into the CD-Slot. Slide it in until it 'pops' the CD up slightly, whic release it. You can then use tweezers or similar to pull the CD gently from the laptop.
Nov 26, 2013 | Apple MacBook Pro Laptop Computer with...
Will not eject DVD is working is stuck I think I might need to open laptop
Power down the laptop and restart it. As soon as it restarts press the open button on the dvd drive and it will open. You may have to try a few times but it will work.
Sep 29, 2009 | Dell Studio 1737 Laptop
How does the media card reader work on the side of the hp pavilion dv4. It is supposed to allow for a ms/pro but it just kind of falls in. It almost looks like an adapter is supposed to fit in the slot
The Digital Media Slot supports the following digital card formats:
● Memory Stick (MS)
● Memory Stick Pro (MSP)
● MultiMediaCard (MMC)
● Secure Digital Input/Output (SD I/O)
● Secure Digital (SD) Memory Card
● xD-Picture Card (XD)
● xD-Picture Card (XD) Type H
● xD-Picture Card (XD) Type M
Here's how to use the memory card reader:
Jul 14, 2009 | HP Pavilion dv4-1140go Laptop
XD card seems to have damaged card slot, won't boot anymore
I accidently inserted my xD card into my Fuji Finepix s5000 and i bent all the things inside to get it out... it is possible to replace to slot, or get it fixed? Please someone help
May 09, 2009 | Toshiba Satellite A105-S4074 Notebook
How do you put in a sd card in the hp mini to display my pictures
Kindly read through the following ,link, that gives you the correct procedure to put the memory card in your computer and the compatible card list aswell.
According to the product manual , the follwing types of memory cards are compatable with your system
● Memory Stick (MS)
http://h10032.www1.hp.com/ctg/Manual/c00766888.pdf
Thanks
Proton
Nov 30, 2008 | HP Pavilion dv6000z Notebook
Xd card won't eject
is it your camera have a service warranty?...why dont you try to go in that place where you buy that camera..thanks.
Feb 20, 2008 | Olympus FE-190 Digital Camera
XD Memory Card stuck in media adaptor of M45-s331
This link should help.
http://www.irisvista.com/tech/laptops/Toshiba_Satellite_M35/take_apart_notebook_1.htm
If this helps, please take the time to return and mark this as "solved"
Many thanks!
Ron-
Nov 09, 2007 | Toshiba Satellite M35-S320 Notebook
What.....
I think I had the same problem as you... I found it was a power issue. I needed stronger batteries. Lithiums worked well.
Oct 23, 2007 | Olympus Camedia Stylus 300 Digital Camera
Olympus D-535 Zoom / C370 Zoom Digital Camera Logo
147 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
