Question about Garden
B&S 3.0 HP-80202-1830-01 Carburetor Problem
I have a B&S 3.0 HP-80202-1830-01 on an older sidewalk edger that starts and runs fine when cold. As the motor heats it will not run without choke. I have disassembled and cleaned the carb. All passages were clean and will pass carb cleaner and air. I have checked for air leaks by spraying wd40 and starting fluid around the carb during running - no air leaks. The carb is unusual, with no float and no bowl. Rather, it has a diaphram with spring and two "flaps" that seems to pump fuel. Once it heats up (after about 2 minutes) it will run only at part choke. Adjusting the mixture screw seems to have very little affect. Advice?
  • 63 Answers
SOURCE: Motor will not start
For some reason the engine is flooded. To make it start do the following: turn the choke off, hold the throttle wide open and crank it until it starts.Do not push the primer bulb first. It already has more fuel than it can burn. It will smoke more than usual until it burns out the excess fuel. You may also have a carb problem but this should allow the engine to start so it can be diagnosed.
Please rate this solution if it helps-
Posted on Mar 19, 2009
  • 109 Answers
SOURCE: Snapper SS312 weed eater. Cranks when primed but won't run
I am sorry to say this, but the compression for that type of engine should be atleast 120 psi. Remove the muffler and look at the cylinder, it is scarred beyond repair.
Posted on Apr 22, 2009
  • 54 Answers
SOURCE: Need to know how to rebuild the carb on a 3.0 hp
The carb sounds like a vacu-jet, very easy to rebuild. Remove it from the tank but be careful not to damage the siphon tube. Then make sure to check for foreign matter in the tank (big problem with this system), clean and flush it. The idle screw is easy, the other is set by going from idle to full throttle quickly and adjusting it just so it doesn't stumble
Posted on Apr 26, 2010
  • 150 Answers
SOURCE: runs on starting fluid, not
Try spraying a little gas where you spray starter fluid. If it runs you may have to install diaphram kit. If it has a choke can get around primer not working.
Posted on Oct 01, 2010
jdhnmi
  • 143 Answers
SOURCE: Briggs & Stratton motor- Model 422447 Type
most carbs have tiny little holes in them for gas to flow through and as gas runs through it leaves behind a deposit like scale or plaque on your teeth . It only takes a little scale in one of those holes to prevent the proper gas flow usually the bowl on the bottom of of the carb has two holes in the screw that holds the bowl on it is usually a 7/16 1/2 0r 9/16 screw new models are plastic and have a spring clip on them. remove the screw and see if the whole are blocked if they are get some carb cleaner and go to home depot and go to the welding section and look for a torch tip cleaner it looks like a round wire with ridges on it it is in a little aluminum case 1 inch wide 3 inches wide use that to clean out any holes . the build up in the carb will look yellow and come off with carb cleaner use a paper towel to rubb any thick stuff remember we are talking about a pin sized hole wont take much to clogg even i one particle of scale will close the hole . hope this helps write back for more questions
Posted on Mar 07, 2011
B&S Model: 303447-1078-31 16hp stops running after warm-up
bad coil it will seem like a fuel issue and the spark will look fine threw the spark plug but with a real spark tester you will see it is a yellow spark instead of blue replace coil and thank me
Jul 04, 2012 | Briggs & Stratton Briggs Stratton Intek V...
I have a Husqvarna edger model E125,when i start the edger the choke is on and the engine runs fine but when i hit the throdle tne engine stalls.
The carburetor is dirty and you will have to take it apart and clean it and all the little holes and passages. If you are mechanically inclined this is not terribly difficult.
Sep 17, 2011 | Husqvarna Garden
Edger Model 143711022 is hard to start. When primed when gas is poured in the spark plug opening, will finally start and then surges\r\nand when placed out of choke position will run for a while and cut...
Edgers tend not to get a lot of use so the fuel ends up sitting in the carburetor and go bad. I would recommend draining the old fuel, including from the carburetor and try starting again with fresh fuel. If you still have problems running, then you likely have trash in the carburetor. To fix it you have to take apart the carburetor and clean it, making sure to clean out all the passages and holes.
I hope this helps you to get it going.
Aug 11, 2011 | Craftsman Gas Mini - Tiller/Edger
Hi, I have a craftsman 25cc weed wreck. always starts in first time(cold) then couldn't start second time; If starts in first time, after 2-3 minutes (engine warms up) engine automatic stops.
the warmth to the carburetor will cause dirt to expand inside causing this to happen. Usually after 2 to 3 years these caburetors are no longer good to use. A new one will be better to have to run your trimmer
Walbro makes these caburetors and nobody likes to service them for their size is small and the cost is far cheaper to replace than fix
Jul 07, 2011 | Craftsman 25cc Gas Line Trimmer
My car doesnt want to start up right away in the morning. Almost like its really cold out and it takes it a min. The rest of the day its fine runs great. Any ideas?
Reason 1 - Gasoline, like any other liquid, evaporates less when it is cold.You have seen this -- if you pour water onto a hot sidewalk it will evaporate a lot faster than it will from a cooler place like a shady sidewalk. When it gets really cold, gasoline evaporates slowly so it is harder to burn it (the gasoline must be vaporized to burn). Sometimes you will see people spray ether into their engines in cold weather to help them start -- ether evaporates better than gasoline in cold weather.
Reason 2 - Oil gets a lot thicker in cold weather. You probably know that cold pancake syrup or honey from the refrigator is a lot thicker than hot syrup or honey. Oil does the same thing. So when you try to start a cold engine, the engine has to push around the cold, gooey oil and that makes it harder for the engine to spin. In really cold places people must use synthetic motor oils because these oils stay liquid in cold temperatures.
Re ason 3 - Batteries have problems in cold weather, too. A battery is a can full of chemicals that produce electrons The chemical reactions inside of batteries take place more slowly when the battery is cold, so the battery produces fewer electrons. The starter motor therefore has less energy to work with when it tries to start the engine, and this causes the engine to crank slowly.
All three of these problems can make it impossible to start an engine in really cold weather. People either keep their cars in heated garages or use "block heaters" to get around these problems. A block heater is a little electric heater that you plug into the wall to keep the engine warm.
i hope it was convince answers
May 30, 2011 | Dodge Stratus Cars & Trucks
I can keep the 3.5 motor running for a couple mins by continuiously pushing the cold start primer, but wont run by itself. the edger only has been used a few hours over a couple years. do i need to buy a...
You shouldn't need a new carburetor. You just need to clean it. First, drain the gas out of the machine. You can do this by removing the fuel line where it attatches to the carburetor. Then, remove the bolt that holds the float bowl on the bottom of the carburetor. There will be an external washer on it. so be careful. The brass bolt that holds the bowl on the carburetor is also the main jet of the carburetor. There are very small holes in the bottom of the bolt and in the sides of it where the smooth section is. Clean it very well as these holes are very small. Reinstall the bolt after wiping clean the float bowl and reassemble. Careful with the carburetor body gasket that goes in between the bowl and the upper part of the carburetor body. make sure it is in place correctly all the way around. Add some fuel cleaner to your gas and run the machine..The built up gum and varnish in dried up gasoline is usually the cause of this problem. If an inline fuel filter isn't used, these same symptoms can develop also as water and trash enter the carburetor.
Oct 10, 2010 | Yard Machines Red Edger
Edger won't run. replaced fuel, air filter and spark plug. I thing fuel line is clogged. It starts fine but won't stay running.
Check your fuel filter in the fuel tank to make sure it is clean if it is then"
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
If the mower/weedeater is over a year old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Aug 23, 2010 | Craftsman Gas Mini - Tiller/Edger
Briggs & Stratton 3.5 HP engine won't start
You will have to remove the fuel bowl from bottom of carburetor and clean the varnish out of the carburetor.Take note that the screw on the bottom of the carburetor is a fuel metering jet,there are small passages in it that may need to be cleaned out with a small wire,be careful not to enlarge the holes in it,they are important for fuel metering correctly.You may have to soak it in carb cleaner. Be sure to use good carb cleaner. The brand name Berkebile 2+2 is the best followed by Gumout.
Jul 31, 2009 | Garden
I bought a Sears edger #536 796526. It dies on me.
Hi Tom. You are not doing anything wrong. That being said, your edger has a slightly gummed up carbeurator. I would go to an auto parts store and get a can of a product called seafoam. this is a gasoline additive. Add one ounce per gallon of gas and use this as the fuel for your edger. You will solve your problem in just a few minutes after using this product, I believe. Give it a try and let me know.
Jun 13, 2009 | Craftsman Gas Mini - Tiller/Edger
Stops when given full throttle
Most likely carburetor needs adjustment.
May 15, 2009 | Garden
Garden Logo
154 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
