Question about Insignia Digital-to-Analog Converter for Analog TVs
Sound problems with recording to vcr using converter box
I have an analog tv and an older vcr. I hooked up the converter box and was able to make timer recordings but the sound was totally un-listenable..garbled and way too low to hear even with the volume at full blast. Is there something wrong with my connection? Bad cables?
Also, to solve my problem with wanting to record one station and watch another after the transition, if I buy a digital tv and use the converter box just for the vcr, will that solve the problem? If so, how do I hook everything up? My TV only has the one hookup for coaxial cable...
I've gone to best buy and other places and I've gotten so many different answers to questions and what I've come to realize is the staff at the stores really have no idea what will happen after the transition..
  • Insignia Master
  • 5,017 Answers
If your TV has no scart connection, no HDMI connection, then to be honest I would get a new set. There are plenty of good second hand models around, which will be better than your old set and come with a digital tuner built in.
As for the VCR, that should have a scart socket and so should the converter box. Once connected via the scart socket you should be be able to record the shows easily. If the converter box comes with a volume control, you might need to set that up to get it right. If the VCR has two scart sockets use the second one to connect the box. Use the first to connect to the TV for viewing your recordings only.
If it has only one scart, then look around on Amazon for one of these scart switching boxers.
sound problems with recording to vcr using convert - scart box-2ezdezzc42qgaoqqik1m5pt1-2-0.jpg
Posted on Mar 20, 2017
4 Suggested Answers
  • 36 Answers
SOURCE: wish to record on analog VCR and not affect digital TV reception
I don't think it will affect the digital TV reception, but if you try to use the VCR built-in tuner it is still analog and you won't be able to record digital channels that way. If your digital TV converter has video-out and audio-out connectors, then you can connect those to the corresponding connectors on your VCR to record.
Posted on Dec 28, 2008
  • 22 Answers
SOURCE: Want to continue to record on my VCR after digital hookup
You have to use the RCA plugs on the back of the converter box and the tv (red,yellow and white). Or you can attach the antenna wire to box and then attach the wire that comes with the converter that is listed as to the tv and instead attach it to the antenna in on the vcr. The converter box will determine which channel your vcr will get a singal to record from. Your VCR for every program will be set to channel 3 or 4 (depending on what your converter box is set to broadcast on). Make sure the power saver on the converter box is turned off as if you want to record a program in say 4 hours, if the converter box turns off in 2, your vcr will have nothing to record.
I ran seperate coaxible cable to the tv from vcr and unplug the tv converter box everytime I want to watch the vcr. You can also use the RCA cord to send the signal from the vcr to the tv and use the input signal to watch your recorded programs. I had static showing up everytime I played it through the second converter box thus I solved it by running a seperate coax line. I don't know if you will have this problem, just wanted you to be aware.
Posted on Jun 02, 2009
  • 4 Answers
SOURCE: vcr hooked up, no audio
this info is not correct...you need a triple rca cablr....red is right, white is left and yellow is audio......if you conect it all up and still get no sound...try another rca triple colored cable...
Posted on Jun 27, 2009
How do I hook up my old VCR to an insignia tv?
You will need a converter to record onto a VCR. I can't remember the when the FCC require VCR to have digital, but I know yours old enough it has an analog tuner. Take your antenna connection to the in on the converter box, then you can take the out from the converter box to the in on the vcr and finally take the out to tv to the tv. To record you have to have the vcr on 3 or 4 and use the converter box to do the channel changing.
Another way would be take the in to the converter and use RCA cables to the line in on the vcr, and line out to the to the tv. This will give you stereo sound.
Aug 10, 2009 | Panasonic Televison & Video
Vcr hooked up, no audio
From the VCR to the tv if you have RCA cables its kind of hit and miss where the audio cord goes. Only one of the jacks are for sound but it has to be plugged in to the right input. Audio is usually the white one. Just keep touching it to inputs until you hear sound start to come out of the speakers. Hope it helps.
Jun 27, 2009 | Insignia Digital-to-Analog Converter for...
How to record mutliple programs with a converter box
You will not be able to record like you used to: http://www.ezdigitaltv.com/VCRs_and_Converter_Boxes.html There are some boxes that have a timer, but not many.
Jun 14, 2009 | Insignia Digital-to-Analog Converter for...
Ambiuous Information out there
I kind of think the people that wrote the manuals didn't bother hooking up a unit. Here is some help.
The converter box is nothing more then a tv tuner that picks up a digital signal and converts it into analog so your tv can view it.
The vcr, to record programs has to be set to channel 3 or 4 (whatever the converter box is broadcasting on) to record. The converter for the vcr will have to set to whatever channel you want to record from every time you use the vcr and left on as this is the only was the vcr can pick up a signal. Make sure the power saver on the converter box is set to off.
If your tv converter box has digital pass through, all you have to do is turn the tv converter box off and it your tv should pick up the singal from your vcr when you play tapes. You also use this method to access the menu on the vcr.
Jun 04, 2009 | Insignia Digital-to-Analog Converter for...
Vcr hooked to tv and converter box. Will not record digital chann
The vcr has to be set to channel 3 or 4. The converter box has to set to the channel you want to record the show from and left on during the time that the vcr is recording or you will get no recordings.
Apr 19, 2009 | Philips Magnavox DVD/VCR Dual Player
Hook up analog vcr to hd tv
You must have a converter box for the tv and for the vcr. Set the vcr to receive chanel 3 and set the converter box to the digital chanel you want to record. Put a splitter on the antenae out and route one to the tv converter box and one to the vcr converter box. GOOD TO GO.
Apr 11, 2009 | Sanyo Televison & Video
Timer record on vcr/dvd attached to digital convtr box
You have to set the vcr to channel 3 or 4 (whatever the converter box is set to broadcast on). The signal to record has to come through the converter box. Since the VCR only has a analog tuner, it cannot pick up any digital channels on it's own.
Mar 29, 2009 | Sansui VRDVD5000 DVD Recorder/VCR
Getting my VCR to record from the TV with a converter box hookup
Hook up antenna to converter box then from that out to the vcr's input (red,white, yellow connections are better than coaxial).
Jan 20, 2009 | Insignia Digital-to-Analog Converter for...
Wish to record on analog VCR and not affect digital TV reception
Dec 28, 2008 | Insignia Digital-to-Analog Converter for...
How to connect my dvd & vcr with the converter box
Here is my setup.
1) Separate DVD player 2) Separate VCR 3) Digital to Analog Converter box 4) Analog TV 5) Rabbit ears (UHF/VHF) antenna
The antenna goes into the converter box.   The RF-output of the converter goes into the RF-Input of the VCR The DVD output goes into the front input jacks of the VCR The VCR RF-output goes into the TV RF-Input The VCR Line output goes into the front of the TV
To watch DVDs, we turn on the DVD player, turn on the VCR, and set the VCR channel to L2, and tune the TV to channel 3.  The converter is off.
To auto record on the VCR, the converter must be tuned to the station being recorded.  The converted must be turned on, the TV can be off.
To watch VCR tapes, turn the TV and VCR on.  The TV is set to channel 3.  Just press play on the VCR.
To Watch TV.   Turn the TV and converter on.  The TV is set to channel 3.   Change the stations using the converter.
May 06, 2008 | Insignia Digital-to-Analog Converter for...
Insignia Digital-to-Analog Converter for Analog TVs Logo
102 people viewed this question
Top Insignia Audio Players & Recorders Experts
Curt Larson
Level 1 Expert
Steven Wander
Steven Wander
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
