Compaq NC6320 laptop pc with "stringent" security power on password set. How do I get around this? RTC does not control this password.
  • tony price
    tony price May 23, 2009
    "Stringent" is a password that is not held by the power in the Real Time Clock. (RTC)
    This fix did not help me.
  • 2,005 Answers
Remove the laptop battery and the plug to your bios (small) battery on the motherboard wait about ten minutes then plug the bios battery back in power the computer back up using the power supply not the battery then: shutdown and, reboot again after you have reinserted your laptop (large) battery; you should have all passwords removed.
Posted on May 20, 2009
I bought a hp compacnc6230 lap top from amazon and it was refurbished i put the battery in and turned it on and it tells me power on-password key what can i do so i can get in it thank you
1. Remove the battery pack from the laptop.
2. Remove the real-time clock (RTC) battery
3. Wait approximately 5 minutes.
4. Replace the RTC battery and reassemble the computer. Do not put the battery pack back in yet.
5.Connect AC power to the computer.
6.Turn on the computer. All passwords and all CMOS settings have been cleared.
Jul 01, 2011 | HP Compaq nc6320 Notebook
Forgot my power on password
Remove the battery and to the power cord.
Remove the two screws that secure the keyboard. After removing the keyboard, remove the battery “RTC” to stop providing energy to epprom BIOS. After the upgrade or downgrade, or any repair, leave the Laptop for 5 minutes, without any source of energy.
Then connect only the power cord without battery and without the battery “RTC” of the Bios.
then turn on the pc without the battery and press f10 change the admin password put the battery of the laptop again not the rtc battery then save changes and exit, reeboot with the win xp disk inside , change boot order and done i garantied it work install xp and then connect the rtc battery done. jajaja easy
Aug 11, 2009 | HP Compaq nx6110 Notebook
Bios Password
Disconnect the RTC battery and all power for 30 min. Then reinstall the RTC, then all power.
Nov 02, 2008 | HP Compaq nc6220 Notebook
HP Compaq nc6320 PC bios password
Ok, as long as the high security level has not been set in the bios then the following will work to reset / disable the bios password.
1. Remove the battery and mains adapter.
2. Remove the memory cover on the back of the laptop and remove the 2 keyboard screws.
3. Open the laptop and at the top of the keyboard you will see 4 sliding tabs. They are located between the 'Esc & F1 keys' 'F4 & F5 keys' 'F8 & F9 keys' and 'F12 & delete keys'. Slide these down and lift the keyboard up and pull forward slightly so as to disengauge the bottom lugs. Be carefull as there is a ribbon cable at the bottom that does not need to be tugged or removed.
4. You will now see at the bottom behind the keyboard a small battery connected to the motherboard. Gently pull the small white plug upwards untill it is removed from the board.
5. Wait 5 minutes and re-connect the small battery plug.
6. Re-install the keyboard and push back the clips. You do not need to replace the screws yet.
7. Apply the DC jack and power on - DO NOT INSTALL THE MAIN BATTERY.
8. Turn the laptop on while pressing f10 repeatedly but slowly - Do not hold it.
9. If high security is disabled you should now be in the setup screen, select 'Restore Defaults' and press F10 to save.
10. The password is now removed.
If this does not work then HP say that there is no other way to reset it. Im not sure about that, there probably is by some method of de-soldering the bios chip. However the above method worked for me so I hope it does for you. Please rate if you have any luck.
Sparkyuiop.
Sep 10, 2008 | HP Compaq nc6320 Notebook
HP nc6320 BIOS Power on Password
You Have to Remove RTC battery ( Cmos ) battery.
Connect Ac Power to the computer. Do not reinsert any batteries at this time
Turn On the computer
all the passwords and all the cmos setting have be cleared.
Aug 12, 2008 | HP Compaq nc6320 Notebook
Describe your HP Compaq nc6320 PC Notebook Problem
i have a Compaq nc6320 when i plug in the power cord the electricity led doesn't want to turn on i have changed the cords and the adapters and i doesn't power on or even charge the battery, did any one have an idea what to do in this problem?
Mar 31, 2008 | HP Compaq nc6320 Notebook
Big problem
to clear cosmos(reset bios) remove rtc battery for a few minutes then replace ;restoring bios to factory set.
battery looks like large digital watch battery.usually located(but not always) underneath keyboard.
Mar 18, 2008 | HP Compaq nc6320 Notebook
Don't know the Power on Password
Is the bios protected by the same password, usually it isnt. If you can get on the bios you can disable that HDD password. Other than that I dont know much about HP's and their set ups, sorry.
Jan 26, 2008 | HP Compaq nc6320 Notebook
Computers & Internet Logo
206 people viewed this question
David Payne
David Payne
