Waterhaeter will not ignite
The waterheater will not ignite when water is going through it. Is there supposed to be a pilot light on at rest?
    New Friend:
  • 25 Answers
YES
Posted on May 17, 2009
We got the pilot lit but cant get it to lght whole gas flame
after the pilot is lit for about 30 seconds turn it to on. The rest of it should ignite within a few seconds. If it does not, you may have a bad thermocouple
Feb 10, 2016 | Heating & Cooling
Water heater pilot keeps going out. Relight and may stay lit for a day and then goes out again. Now won't even light at all. Has an igniter button. Also says to clean intake screen every 6 months. Where is...
the intake screen or as is called flame trap is located on the very bottom of the heater underneath. this is very important that you keep this clean or it will keep going out. this is the only way this heater has to get air to the burning chamber.
Nov 23, 2010 | RELIANCE ELECTRIC WATER HEATER
Atwood gas waterheater with white rodgers gas valve pilot hard to light and not a big enough flame to touch the thermocouple
I think you need to reposition the thermocouple, or adjust the pilot gas pressure by adjusting the pilot screw make sure it is still the recommended gas pressure of the system... please contact a HVAC tech if this things did not work.
Aug 18, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Kenmore waterheater piezo innotor won't re-light
air in the line, disconnect the pilot supply and hold the button until you smell gas coming from the valve, that will remove the air, as for the igniter, test it by removing the connection and hold it about 1/8" away from the conenction and click it, should see a spark
Sep 16, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Heater Problem
It is normal problem because u r heater is so old
out of company warranty so open it and clean it
NOTE
dont touch it after use means open it before use
means when it is not use in 1 hours because heater contain power in one hour after use
Jul 25, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Lp waterheater won't stay burning
check the pressure comming into the burner thru the gas valve, it has to have at keast 2,bs if not you might have to change the regulator
Jun 25, 2009 | Rheem 40 GAL Propane Water Heater 6YR...
Waterheater pilot light keeps going out
There are several things that can cause this, but the most likely cause is a dirty pilot light orifice, causing the pilot light to have a smaller weaker flame than it was designed for. This produces a weak flame that is easily susceptable to drafts, and a lower holding temperature on your safety capillary tube that controls the gas shutoff safety valve.
The orifice can be removed and cleaned on some models, removed and replaced on others. I would suggest a qualified serviceman be called, because gas service is usually beyond a typical handyman's area of expertise, and safety is a very important issue here.
Nov 14, 2008 | Water Heaters
Washing Machines Logo
64 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
