Question about Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
One touch button is not working if i press i could enter but it shows shows me your partion is different with company
  • jpedirect May 11, 2010
    Hi, there is a family 3000 N100, Type is 0768, and model, example 02U , please provide me model info so I can research it.
    I have another question, do you know if this hard drive is the original, or has it been replaced before? When you purchased was it new or a refurbished laptop?
    Problem Solver:
  • 5 Answers
Most laptops these days come with a recovery drive. the contents contain alll the information that was in your machine the day you brought it. you somehow managed to corrupt the partition or delete its files. i'd suggest that you restore its contents from a backup if you made one or you could take it to the store you got it from and have them do it for you. also usually laptops come with recovery disks so you must check if u have those you might not need to use the one button recovery
Posted on Jun 09, 2009
Putting numbers in the memory and editing
To store numbers in memory do the following
(Make sure the phone is in standby and not in TALK mode)
2.) Press the memory button on the handset or base.
3.) Press the desired memory location button (0 through 9 number keys) or
use the CID-VOL (- or + ) buttons on the handset or CID/rev or CID/skip)
buttons on the base to scroll to desired memory location. If the memory
location is occupied, the stored name and number displays. If the
memory location is unoccupied, EMPTY shows in the display.
4.) Press the memory button again. The display shows ENTER NAME.
5.) Use the base or cordless handset touch-tone pad to enter a name (up to
15 characters).
6.) Press the memory button again to save your selection. The display
shows ENTER TEL NUMBR.
7. Enter the area code followed by the
telephone number (up to 24 digits, including pauses) and press the
memory button again to save your selection. The unit beeps to confirm.
8. To enter another name and number in a different memory location,
return to step 1 and repeat the process.
Manual available HERE
Jun 17, 2011 | Uniden Cordless Phone
How do I set and save a fax number as a speed dial
You can download the User Manual from here (temporary link): http://dl.dropbox.com/u/1322442/CANON%20CFX-L4000.pdf
Here is a transcript:
Storing Numbers for One-Touch Speed Dialing
Your Canon fax can store up to 120 phone numbers: up to 20 of your most frequently used numbers can be stored for One-Touch Speed dialing, and an additional 100 numbers can be stored for Coded Speed Dialing.
1. Press SET and DATA REGISTRATION
The display will show:
DATA REGISTRATION
1. SPEED DIAL SETUP
2. Press SET twice.
1-TOUCH SPD DIAL
01
3. Use the search buttons (up and down symbols) to select a One-Touch Speed Dialing button between 01 and 20.
1-TOUCH SPD DIAL
[1...7]
??¢ You can also do this by pressing FUNCTION, then pressing the One-Touch Speed Dialing button, then pressing FUNCTION again.
??¢ If a number is already stored at the button you select, that number appears.
??¢ If the button you select is registered for Group Dialing, GROUP DIAL appears.
4. Press SET twice. Use the numeric buttons to enter the fax number you want to store.
TELEPHONE NUMBER
TEL =
??¢ Press SPACE to enter spaces between numbers. (Spaces are optional and are ignored during dialing.)
??¢ If you want to clear a number or a mistaken entry, press CLEAR.
??¢ To enter a pause in the number, press PAUSE one or more times
Sep 22, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
How do i store numbers? there is no manual.
DATA REGISTRATION
1 .SPEED DIAL SETUP
2. Press SET twice.
1-TOUCH SPD DIAL
01
1-TOUCH SPD DIAL
[1...7]
TELEPHONE NUMBER
TEL =
Sep 17, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
How do I save a number
You can download the User Manual from here (temporary link): http://dl.dropbox.com/u/1322442/CANON CFX-L4000.pdf
DATA REGISTRATION
1 .SPEED DIAL SETUP
2. Press SET twice.
1-TOUCH SPD DIAL
01
1-TOUCH SPD DIAL
[1...7]
• You can also do this by pressing FUNCTION, then pressing the One-Touch Speed Dialing button, then pressing FUNCTION again.
• If a number is already stored at the button you select, that number appears.
• If the button you select is registered for Group Dialing, GROUP DIAL appears.
TELEPHONE NUMBER
TEL =
• Press SPACE to enter spaces between numbers. (Spaces are optional and are ignored during dialing.)
• If you want to clear a number or a mistaken entry, press CLEAR.
• To enter a pause in the number, press PAUSE one or more times
Aug 19, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
No internal hard disk found
Hi there.
Use the Vista CD to create the new partition, but first you have to delete the old partition first, (the 220GB partition not the 10GB one because that will be the recovery partition).
Get a calculator and work out your new partition, for example 50GB is 50x1024MB so that will be 51200MB.
When you have deleted the 220GB partition select NEW and input your newly worked out partition and carry on from there, to activate the other partition just format it.
Please post back with the results and for anymore help if needed.
Good luck and thanks for using FixYa!!
May 24, 2009 | Dell Inspiron 1525 Notebook
Ge model 27909 answering machine gives wrong time on playback
I found it on the manual, it was in programming section!
Date/Time
NOTE: Time set on handset will be transferred to the base unit automatically.
1. Make sure your phone is OFF (not in talk mode).
2. Press the menu button to go to the main menu and use cid/vol (3or4) button to scroll to Date/Time.
3. Press menu button to enter the menu. Year 2006 shows in the display.
4. Use the touch-tone pad to enter the last two digits of the current year (range: 00 to 99).
5. Press menu button to save the year setting and proceed to date setting.
6. Date 01/01 shows in the display. Use the touch-tone pad to enter two digits for current month and day respectively.
7. Press menu button to save the month/date setting and proceed to time setting.
8. Time 12:01p shows in the display. Use the touch-tone pad to enter four digits for current time and use cid/vol (3or4) button to toggle between "p" (pm) and "a" (am).
9. Press menu button to save the setting. Saved shows in the display.
NOTE: If you subscribe to Caller ID service, the current date/time is set automatically when you receive your first CID record and will override manually set date/time.
Jan 08, 2009 | GE Lands Phones
Garmin nuvi
Different parts of the screen do different things depending on the mode you're in. When you touch "speed" the trip screen appears as you've already noted. The 'Driving" icon does nothing until you've asked the GPS to take you someplace.
After you enter a route the "speed" icon changes to "arrival" (which will still bring up the trip screen) and the 'driving' icon will change to "Turn In." Touching "Turn In" will bring up a list of turns along with a small portion of the map (showing that particular turn) anytime you've entered a route.
Note you can also press the green banner on top of the map when you have a route set. You'll see a list of just the turns and the distance to each. Touching each of those turn boxes will show you the split screen offered after you touched the "turn in" button.
Cheers
Nov 15, 2008 | Garmin Nuvi 660 GPS Receiver
Corrupted Windows
hi
if u want to repair window xp
insert your cd in rom.
then restart your pc.press del key or any other key to enter your bios.set advanced option first boot rom.save your settings.then press any key to boot from cd.
after approx 5 min .
when ask u to press enter.
if u want repair xp to its recent condition press r and if u want new winxp press esc key.
then press F8 then u show your partion of drive.
press D to del selected partition.
after del all partion press c to create partion and set as u wish to manage your partition. then in c partition press enter to format the partition using quick fat32 or ntfs.
then follow the instruction .
Mar 21, 2008 | Computers & Internet
Compass wont work correctly
if your hands aren't straight when you use the compass try this to sync the hands.
1. Press and hold the middle button to enter T-Touch mode.
2. Press the centre area on the face twice to display 24hr/12hr
3. Press and hold the middle button to enter T-Touch mode untill screen says sync.The hands will face 1200.
4. Press either the upper (East) or lower (West) button to adjust the compass hands. They should both face 1200.
5. Press the middle button to get back to 'regular' compass mode. Note that your offset setting will still show in the digital area.
Oct 10, 2007 | Tissot T-Touch T33759851
Incorrect Fax Number showing on sent Faxes
the solution given is correct. happy faxing OMNIPRESENT
Oct 01, 2007 | HP LaserJet 3050 All-In-One Printer
Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
113 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
