Question about PPI DCX-1000.1 Car Audio Amplifier
Plugging it up
I need to know why it has to power plugs audiomasters here in town will hook it up but they are not familiar with the amp they dont understand y it has two plugs if its only a mono amp they are afraid of blowing the amp wat should i tell them
  • Anonymous Nov 25, 2007
    I dont know where to put the other wires 4 an output
  • 709 Answers
Dam Jaggy87, I think I would let them hold the amp and go somehere else. I would not want someone who doesnt understand putting anything in my car.
The Plugs may be Speaker level and Line level input.
Posted on Oct 23, 2007
Hi, i need to know the exact power plug so i dont have to run the pedal on battery power.i know i need a 9v power supply but i dont know the size of the jack that goes into pedal..many thanxs..
Unfortunately, battery jacks and plugs similar to the type you're describing do not have any real standardization - unlike the outlets and plugs in homes and businesses have.
You best bet is to either bring the plug / jack to a shop to match it or contact the instrument's manufacturer to obtain the connector specs for physical dimensions
Be sure to obtain the power requirements in either watts or amps so that you can obtain a power source capable of delivering what you need without overheating during longer periods of use. Adding 25% to 50% more amps or watts to the minimum required should provide years of trouble free service. Example: 9VDC at 50 watts should be supplied by a 9VDC 62 watts or even 75 watts; or in the case of a rating of 9VDC at 6 amps should be supplied by a 9VDC at 7.5 amps or even 9 amps. With DC powered devices, make sure you observe proper polarity! Good luck!
Mar 16, 2016 | Music
I have surround system but i dont know how to hook it up to the tv.
Hi wayne,
Youll have to be familiar with the colour RC cables. Red and white for right and left speakers. Sometimes it is also possible to plug in your surround sound through the headphone jack.
kc
Feb 21, 2011 | Televison & Video
Jensen CD-510K hooking a 200 watt amp to it.Need to know what wires need to use to hook it up
rca cables for audio and a remote wire. just plug the rca cables into the plugs in the back of the deck and the remote wire (i suggest buying a thicker (speaker wire size) gauge wire since it allows you to get more power out of the amp) to the blue remote wire coming from the deck. you will also need an 8 gauge power wire (12 inches to 12 feet depending on where the battery and amp are) and an 8 gauge ground wire (no longer than 24 inches).
Aug 18, 2010 | Jensen Car Audio & Video
Radio quit working when I hooked up a portable compressor lighter
The radio uses a five amp fuse, maybe 7.5 amp. pull them and look at them you tell they are blown
Jun 17, 2010 | 1995 Chrysler Town & Country
I have a kenwood kdc 233 cd player in my car but the remote wire aint working because i tried hooking up an amp i pit a light power tester on the remote wire but dont work and i dont think the input plugs...
as far as the remote wire a keyed power wire from under dash can be used its the same thing.if the remote wire is working it wont turn on your amp so are you sure thats not why your rcas dont work or have u hooked power to the remote on the amp.
Nov 09, 2009 | Car Audio & Video
I just dont know how to plug everything with it...Power button comes on if you move the amp...sparks if touches with a a screw....dont know which connections to put where
Black is ground(hook to a bolt going into metal on vehicle). Red is switched power(only on with ignition on). Yellow is power(power even if ignition is off). Blue is amp turn-on(located at radio and sends signal for amp to turn on). It is sparking because you do not have it grounded properly. You can damage your amp and or you car's electrical system....be careful. Always pull a main fuse or disconnect the battery when wiring a car audio system.
Sep 16, 2009 | Boss Car Audio & Video
No power---unable to turn on tv
There is no reset button on these new sets,your set has complete power problem since you have no lights no clicks,this might have happen because of lightning or power surge,either one creates a lot of damage,if you are familiar with tv service you can check the main fuse,he should be close to where the power cord comes in,if you find the fuse blown it needs to be replaced with an exact replacement for AMPS rating and VOLTS rating as well as size,if the fuse is blown black we might have more problems ahead in the circuit and it will blow up again as sonn as you plug the tv back in,if it blows again it will need a more involved repair,the problem could be in the primary side of the power supply,if you are not too familiar you should seek the help of a servicer a least for an estimate but if you suspect power surge or lighting damage dont invest any more on this set and get a new one.
Jul 10, 2008 | Norcent Technologies LT-2722 27 in. LCD...
Protection Light Is Coming On
try redoing the wires you might have wires touching somewhere if that dont stop it try new RCA wires
Jan 08, 2008 | Lanzar Vibe 235 Car Audio Amplifier
PPI DCX-1000.1 Car Audio Amplifier Logo
76 people viewed this question
Top PPI Car Audio & Video Experts
Jose Velazquez
Jose Velazquez
hoyzee1
Are you a PPI Car Audio and Video Expert? Answer questions, earn points and help others
