Question about McCulloch Garden
Not getting gas?? runs with a shot of starting fluid for about 7 seconds
I have a mini mac 120 the only way it will run is by giving it a shot of starting fluid. I don't think its getting gas how is gas delivered?
  • 398 Answers
Usually thru a tube with a filter( in the gas tank) on the end of it then to the carb and into the intake and gets sucked into the engine
Posted on May 17, 2009
Sears troubleshooting
I think you mean it wont run after running out of gas. You may have to remove the spark plug and shoot a small shot of starting fluid in the hole and replace the plug. Cranking means turning the engine with the starter motor.
Aug 15, 2014 | Garden
Looking for a users manual for a late 60's early 70's Mcculloch Mini Mac 35...any ideas?
i run my macs at 30.1 gas to oil and standard bar oil should be adequate, good luck finding a manual...
Jul 04, 2012 | McCulloch Garden
I have a 1994 chevrolet cavalier 2.2L problem is it cranks and gets spark to all cylinders, have tested with tester to be sure, but it does not turn over and start what else could it be?? please help
Is it getting fuel? Have you tested the fuel pressure? You may have a faulty fuel pump or fuel pump relay. Can you hear your fuel pump buzzing. Remove your gas cap and have someone turn the key to the run position while you have your ear near the open gas tank. You should hear the pump making a buzz. If you don't hear anything you have a bad fuel pump or problem in the electrical circuit to the pump. If you do hear it running you still need to check the pressure. If the pump is buzzing it still may not be working correctly. You could try giving it a shot of starting fluid and if it runs on the starting fluid you know you have a fuel related problem. Be careful with the starting fluid because it is very flamable.
Apr 22, 2011 | 1994 Chevrolet Cavalier
2007 honda crf 250. Sat for 1 1/2 yrs. won't start by cranking, or pushing.
Try a small shot (about a 2 second spray) of starting fluid in the air intake then cranking....
WARNING- DO NOT TRY AND KEEP IT RUNNING BY USING THE STARTING FLUID! It can damage your engine.
If your bike fires and runs for a bit, the most likely problem is your gas has gone "sour". You need to drain all the old gas out and properly dispose of it.
Over time, gas will cause a varnish buildup in your carb if it sits too long. You can try adding some carb cleaner to fresh gas, but the results will not be immediate. You may have to have the carb rebuilt.
When you store anything gas powered, there is an additive called Sta-bil that will act as a gasoline preservative for about a year.
Feb 13, 2011 | 2005 Honda CRF 250 R
What would cause the lawn mower to stop running when not out of gas? If you give it a few seconds and restart it it will run again for awhile then stops. I have noticed if I pump the primer a couple of...
Try using non-ethanol gas. It's death on small engines. Starter fluid gives it a boost if higher octane. Have a reputable repair place clean out the gunk, then use good gas. Best of luck finding non-ethanol. Boating marinas carry it.
Jul 20, 2010 | Mtd 22" Yard Machine Push Mower
99 gmc jimmy, been running okay till a few days ago. Drove it to eat, came back out and it won't start. Battery okay. Tries to turn over, but won't. Acts like out of gas, but half a tank.
Listen for the fuel pump prime cycle.
Have someone listen back by the gas tank....turn the key after it has been off for at least 10 seconds to run position....you should hear a WHIRRRR for about a second or 2.
If it is silent....you may need a fuel pump.
Next give it a shot of starter fluid...if it starts on that...you indeed have a fuel problem.No start....no spark.
If no start and you did hear a pump cycle....then it's most likely a no spark problem.......a common cause is the crank sensor and/or ignition module.
Sep 09, 2009 | 1999 GMC Jimmy
85' RX-7 Wont Stay running
have you checked the fuel filter for any dirt in it ??
Apr 12, 2009 | 1985 Mazda RX-7
My 2001 new Beetle will not stay running. It starts up, then 5-8 seconds later will sputter out and die. If I pump the gas peddle a bit after it starts, it trys to stay running longer but then sputters out...
Hi There,
Try this: You will need 2 people - Have someone Spray Starting Fluid in the throttle then start the car and have someone spray the fluid continuously into the throttle. If the car continues to run you have a fuel problem, but if it stalls out, replace the coil pak. Hope this helps and thank you for using FixYa!
Mar 04, 2009 | 2001 Volkswagen Beetle
7 month old mac mini freezing & being slow
Generally there are a variety of reasons that can consequently cause the freezing or slow issues on your Mac. Meanwhile, there are certain ways through which you can do to fix one by one. However, if you prefer a more efficient way to resolve, try an all-in-one Mac speed up software as it can help resolve all issues in just a few clicks. Learn more: http://www.howtospeedupmac.com/
Hope this helps!
Jan 20, 2008 | Apple Mac mini G4 Desktop
Garden Logo
151 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
