The washer will not change from wash to spin to rish to spin
    President:
  • 1,136 Answers
HI, Sounds like the timer has gone bad. Does it advance in any of the cycles?
Please get me the make/model# and I can look this up for you.
Vic
Posted on May 17, 2009
Brand new Bravos. Why doesn't it do the final spin?
NO ITS NOT UR DOOR SWITCH IF IT WAS IT WOULDNT SPIN ON ANY CYCLE. I SUSPECT U HAVE A TIMER THAT IS STICKING AND THE POINTS HAVE BURNED OR SEIZED
May 26, 2015 | Maytag Washing Machines
Washer stays in wash cycle will not spin out i changed control board no help
Isyour washing machine displaying an error code? If so, try using the owner's manual to decipher the code and you may beable to easily diagnose the problem. The problem could be as simple as the doorbeing slightly ajar, the machine is in pause mode, or the spin selector isstuck. Checkthe handy chart in the article Washingmachine won't advance to washer spin cycle for more possible reasons why your washingmachine won't advance to washer spin cycle-and some tricks for getting itworking again.
Aug 01, 2012 | Electrolux Washing Machines
My Kenmore washer will not spin or empty. Everything else works. Do I have to change the timer?
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jan 16, 2011 | Kenmore Washing Machines
Wont drain water
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Oct 16, 2010 | Samsung WF218AN Front Load Washer
Washer will not spin
There is a safety switch on the lid ... when it went out of balance perhaps the adjustment changed or it got damaged (loose wire etc.) BE SURE TO PULL THE PLUG BEFORE ATTEMPTING ANY REPAIRS
Oct 02, 2009 | Washing Machines
Washer doesn't spin
Hello skull1829 ,
Was the Clutch/One-way roller bearing changed out for dc/UC errors in your FAV6800AW/FAV9800AW?
If you start a Spin Only Cycle with an empty wash basket will the wash basket spin up CCW and complete the cycle? Lift the washer top from the base a few inches to observe the wash basket CCW rotation in spin cycle. If the clutch spring is broken or end pins of spring aren't seated the tumblers will rotate and the wash basket will rotate slowly CCW.
IF the wash basket won't spin up can you pull the front cover off and insure the motor will rotate the clutch pulley CCW in a Spin Only Cycle? Let’s try these few basic tests and get some feedback for troubleshooting.
Rich
Jun 13, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washer washes fine and the water drains but will only spin if you mess with the clothes making them perfectly balanced or you hand start the spin. Roper
sounds like the spin basket drive.. does it agitate ok? if yes get a new washer or change or get a repair man to change the spin basket drive.
May 02, 2009 | Roper RAB5232E
Spin Cycle Fails on Washer
This solution is 100% correct, change the : wax motor &control board.I'll be happy to guide you through this if you need me to.
Apr 23, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Dec 14, 2007 | Frigidaire GLTR1670A Front Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
