Question about Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
My pool pump stopped working - Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
  • 323 Answers
It probably has air in it. Loosen the plastic plug on the top until water runs out of it steadily Then close the plug and turn it back on. That should do it!
Posted on Jun 05, 2009
I have a Speck Pump, model E71, only a year old. It suddenly stopped working - it was fine at the start of the season. The problem is that it just hums when turned on.
Since it hums it has power. I believe there is a start capacitor on it, that or the start switch may have failed.
Speck Pumps Pool Pump Parts
usa speck pumps com
have Speck Pump model E71 only year old It suddenly stopped working it was...
Speck Pumps Pool Products Inc
Jul 02, 2016 | Speck Pumps Pool & Spa
My Zodiac pacer pool cleaner moves in small intervals and then stop, once I pull on the pype it moves and stops again after say 30 seconds?
these units work directly through the flow of water through the pump. they will not work properly if there is too much or too little. the problem is that as the unit picks up debris in the pool, the water flow will change. also, little holes in the hose will affect how it works. as well, if the chemical balance in the pool is wrong, the diaphragm will become rigid and affect performance. if your liner has water underneath it, the vac will pull and seal to the liner causing it to stop. this is a very common problem
Sep 20, 2014 | Zodiac Pacer Pool Cleaner
Pool time switches pool on, but off does not trip off, and can't do it manual. When I push it on off, the pool pump tries to stop but continutes running. Have to use breaker box.
Model number of timer is not known.
Is this new installation? Or installation that worked before and recently stopped working?
If the manual override lever on timer does not turn Load on-off, then 1) wiring is wrong or 2) timer has gone bad or 3) pump has a short.
I suspect a short since you say the pump 'tries to stop running.'
Copy following links for troubleshoot walk-thru, and correct wiring:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timers.html
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Jun 28, 2012 | Intermatic T104 24h 208-277v Mechanical...
I have a model 604 - one day the pool pump stopped working i dont know if its the pool filter or just the pump itself (the pool filter is dirty as havnt changed it over for nearly 5 weeks) if i buy a new...
No it won't. I stay in South Africa and bought the pool about 3 months ago. The impeller broke and there are NO aftermarket parts available. Buy a new pool!!! The only way of getting the same pump. I have checked on some other sites and a lot of the guys use a normal pool pump after they have experienced the same problem.
Mar 05, 2011 | Intex Krystal Clear Model 635 Pool Filter...
Hayward Self-Priming Pump with AO Smith 1 HP 56J frame motor. Stopped moving inground pool water. Added water to pump basket (low). Turned on pump, return jets sent "bubbles" into pool, stopped, then...
the pump must not have any air leaks in the suction side of it,, or it will just **** air and not water,,, water is very heavy you see, however i think its the impeller in the pump thats the problem,,,you should try to put water in the out let of the pump so you fill the pump with water first if its dryed out it may just wear out the impeller before it starts to **** water up, if this still dont work turn off the stop **** and strip out the pump to look at the impeller any wear on it and it will need a new one fitted
i hope this has help you, good luck
Nov 20, 2009 | AO Smith Pool Pump Motor Hayward Swimming...
My DE pool filter stops working after an hour? please help
Is your pool green? This will cause the filter to plug up. When you say stops working do you mean no water flo, passing dirt or are we talking about the pump not moving water? Can you clarify this problem some?spellcheck.gif
Aug 16, 2009 | Hayward EC-40 DE Pool Filter with pump
Pool pump starts then stops working
Your internal circuit breaker is shutting the motor down. When it overheats it breaks the flow of electricity to the motor. You need to replace your motor.
Jun 13, 2009 | Intex Wet Set Water Filtration Filter Pump...
Intex pool filter/ pump just stopped working
Try giving your pump more air circulation.
Turn off pump when not around it.(should only need to run for around 3 - 4 hours on a small (kid) pool 6 - 8 hours for standard house pool
You could put you pump on a timmer - set shut off time to just before you pump shuts down.
Check you pump (when not conected to mains power) - get some WD40 into it - (salt and metal no like each other)
Jun 09, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Will not pump when it has a filter in it
filters are too good for pump system.
These pool pumps seam to over heat fast, no quick fix.
* Try getting more air flow around pump.
* Only use pump when using pool or near by.
* Use a pool cover - will help stop dirt/rubbish getting into pool - less to filter.
Jun 02, 2009 | Intex Easy Set 1500 Gph Filter Swimming...
Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph Logo
647 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
