Question about Dryers
Hi, i'm trying to fix a dyer. The drum in the unit disattached.
Hi, i'm trying to fix a dyer. The drum became disattached from the back of unit. Addition to this, i found that the belt snapped from it which probably was the main cause of it. Does the drum get welded/soldered in from the front of the unit after putting the belt around it? What is the best way to do this?
Thanks.
  • 98 Answers
The drum must move freely you will see a felt ring on the front and bac of the housing the drum rides on thatmake sure the felt is on the outside of the deum
Posted on May 17, 2009
    President:
  • 1,136 Answers
Hi, What make/model# is this so I can assist you further?
Vic
Tumble dyer catches the clothes
hi have good look for splits in drum had couple gone at back were heat enters
Mar 29, 2013 | Hotpoint Dryers
Mod.ADP951/3WH Upper spray arm totally disattached itself and fell down
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Jan 13, 2011 | Dishwashers
Hi. The telescope itself became disattached from the tripod. How do I connect it again? There seems to be a screw, but it is not screwing in tight. THanks. Maria.
The female end may be stripped. You will need to re-tap the threads, and probably also buy a replacement bolt at any well stocked hardware store.
Aug 26, 2010 | Bausch and Lomb Discoverer 78-1600...
Machine turns on but doesnt spin and dry clothes, what can be the problem
my dyer has a belt that broke it goes all the way around the drum and goes around the motor than to a tension spring if you take apart from back access panel unplug before attempting to fix look and see if the belt broke or came off tension pulley
Jan 27, 2010 | LG DLG5988 Gas Dryer
Drum noise
Did you ever figure this out??? Ours just started doing this
Nov 29, 2009 | LG Dryers
How do I balance the drum in the dryer. I vacuumed the interior of the dyer to clean it and all was ok. When I whent to start it the motor locked up and the drum was not turning. I removed the drum belt...
Did you pull the drum out when cleaning this unit, if so the when you put it back in you got it off the wheels in the rear or the sliders/wheels on the front. Either way pull the from panel again and as you do pay close attention to how the drum is sitting on the front frame and rear supports. You may have damaged the drum, check to make sure that you didn't split the drum.
Sep 29, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore 970 C81062 10 Electric Dyer WILL NOT
It sounds like the drum may be stuck. Turn the dryer on with the door open, just keep the button pushed. Then try to turn the drum by hand, and see if it will start to turn.
Jun 04, 2009 | Dryers
When dyer runs it makes a squealling noise like abad bearing>
Could be felt pads and nylon glides on the front drum support are deteriorated.
Could be a sticky build up on the rear drum rollers.
Could be a worn belt tension roller.
Unplug the dryer.
Remove the front panel.
Remove the front drum support.
Remove the belt and drum
Inspect the items listed above.
Replace as needed.
Mar 11, 2009 | Maytag Dryers
Dryers Logo
55 people viewed this question
Top Dryers Experts
