Question about Sony STR-DE898 Receiver
Connecting pc audio to str-de898
This may be a silly question so hopefully the answer is simple :)
I am trying to connect my PC audio through the amplifier to my speakers (standard output; 3.5mm stereo to 2 RCA plugs) . I can get the sound to work but only in 'Phono' and not in 'video 1' or 'dvd' etc. The sound doesn't work when the amp is set to 'analog direct'. The problem is the sound quality is **** (not only at high volumes either). This is especially the case for bass. It isn't a problem with the amp or speakers as the wii (left and right rca connection) and DVD player (optical cable) produce perfect sound quality. I have tried two separate sound cards on the computer so I don't think this is the problem.
Any help would be great. I have previously had a computer setup and it worked fine (worse computer and sound card also) but I can't remember how/what settings I had it working with. I moved house so had to dismantle everything. Thanks
    Brigadier General:
  • 8,546 Answers
You're close. PHONO is NEVER the place to send Line Level signals. It is for the small output produced by a phono cartridge only. Google RIAA equalization to see why it sounds so bad when connected that way.
That you get sound through Phono at least proves your PC is producing an output. Now we have to figure out why your RECEIVER doesn't sense the program where it should be connected.
If you have another analog audio source that works on the receiver, temporarily connect the PC audio there to see how it sounds. Then think about why it doesn't work in MD/TAPE, SA-CD/CD, TV/SAT, DVD, or either Video IN. Any of those should work.
Posted on May 17, 2009
Where are the fuses located in a Sony STR-DE898 reciever?
they are located inside the unit next to the power transformer but be careful of the dangeroud voltage
Jan 02, 2011 | Sony STR-DE898 Receiver
I have to connect the RCA PLUG on a Center Speaker by Audio Research to the Center Speaker connections on my Sony Receiver, which requires two wires. What do I use... a RCA plug with ...? Thanks ...
A possible solution (but not the best) is to use a single RCA to RCA cable, however you should cut one end of the cable before the remaining RCA plug. Then you separe the wires, twist each of them and hook on your Sony receiver. A RCA cable is made of two wires or poles. I believe this will work. Good Luck.
Flavio/BRAZIL
Jun 08, 2010 | Sony STR-DE898 Receiver
Only 2ch sound on sony strde898
I understand that you have tried connecting different audio source to the Receiver as some of the audio source will output only 2 channel audio. I hope you have tried changing the Input mode and Input selector to get the surround sound.
Please disconnect the speakers with the receiver and clean the edges of receiver and speaker cables using solution like alcohol and try.
If the issue persists, please interchange the rear speakers with front speakers and vice versa and check if audio is coming to make sure that the speakers are working fine.
If the audio comes after replacing the speakers but not from surround speakers, the receiver requires service.
Sep 22, 2009 | Sony STR-DE898 Receiver
Is there a way to reset the STR DE898/B 7.1 channel Receiver
Reset can mean many things... Input/ output/surround/ or is it saying "Protect" on the display?
If that's the case, unplug, wait a minute, plug it back in and turn on. If it still say's Protect, disconnect the speaker wires and test again. Chances are you have a shorted wire or speaker. If you need something different, post a reply and I will help you further. Hope this helps
May 25, 2009 | Sony STR-DE898 Receiver
How to hard reset a sony str-DE898
I couldn't find anything about a Lock Code in the manual but here's the general setting-reset procedure:
Turn OFF the receiver
Hold down the I/0 for 5 seconds - "PUSH ENTER" appears on the display
Press ENTER
Apr 08, 2009 | Sony STR-DE898 Receiver
No sound
Have you got the speakers on as in the AorB speakers button? It should be located on the front of the amp.
Dec 30, 2008 | Sony STR-DE898 Receiver
Sony da333es : protector (fan) ;how do I fix this
It's warning you that the fan is dead or clogged. Look at it and possibly clean out the dust bunnies.
Dec 26, 2008 | Sony STR-DE898 Receiver
Sony receiver optical sound "unlock" str-de898
Just fixed it, The Optical cable wasnt properly plugged in on the other end.
Found the fix here:
http://esupport.sony.com/US/perl/model-home.pl?mdl=STRDE945&LOC=3
Oct 09, 2007 | Sony STR-DE898 Receiver
Sony STR-DE898 Receiver Logo
124 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
