Question about Refrigerators
Whirlpool ET22DK NOT Cooling
Have a Whirlpool ET22DK - runs fine, but not cooling at all. I tool the rear panel off and completely vaccumed the dust so everything is clean. Also took the panel off inside the rear of freezer and the coils weren't frozen.
What could be causing the fridge to not be cold (just stopped blowing cold one day...)???
  • 3 more comments
  • mahrcas May 17, 2009
    Fans in the rear panel and in the freezer are running, and there was no frost whatsoever when I removed the panel in the freezer (clean as a whistle).
    Which component is the compressor so I can go check it?
    The condenser is warm to the touch, and there is not frost on the evaporator (assuming we're talking about the evaporator in the freezer).
    The fridge was unplugged for about a month until today when I took the panel off and started cleaning everything. It's only been plugged in for about 4 hours. I took the panel inside the freezer off and it is clean, flan is running, but no cold air. I am getting a few drops of water through the drain tube on the back (next to the condenser fan).
    Fridge is older than 5 years...
    I'll have it run overnight. if there's no frost then I'll toss it, however, if there is some frost, what should I check next?
    Vic,
    Will definitely rate your performance, and you've been a great help. Is it possible that it just needs R134, or how do I know that it indeed needs a compressor (assuming it doesn't frost at all by morning)? The fridge was at my work (not home) and when it stopped blowing cold they gave it to me so I don't have the entire story on it.
    Could it be stuck on something like the defrost cycle? Not sure how to check that. Basically want to check everything I can before tossing it since its in otherwise perfect condition. Thanks!
    I let the refrigerator run overnight. Both fans are still running, there is NO frost whatsoever on the condenser (inside the freezer panel), and the compressor (black bottle? next to fan on back of fridge) is no longer warm to the touch.
    No funny noises, etc... simply not getting cold at all.
    President:
  • 1,136 Answers
Hi, Is the compressor running at all? Are the fans running? Whe you took the rear panel off in the freezer, was there any frost on it at all?
Vic
Posted on May 17, 2009
  • 3 more comments
  • Victor
    Victor May 17, 2009
    It is the motor down under the frig. It is dome shape and is black next to the condensor fan motor. It should be warm to the touch. If it is running and there is no frost at all on the evaporator...... NOT good news. Is it under 5 years old?
  • Victor
    Victor May 17, 2009
    Let it run for about two hours. Just rest the freezer panel against the evaporator. If in two hours you still have no frost (even a film of frost) you will probably need to replace the frig. It is alot of money to have someone change the compressor.
  • Victor
    Victor May 17, 2009
    If the evaporator totaly frosts, you should be ok. If it frosts now and in two weeks you get to much frost, then you need to check defrost cycle.
    Good luck
    Please feel free to rate my perfomance so that I know how I am doing.
    Thanks
  • Victor
    Victor May 17, 2009
    If it is stucck in defrost, the compressor or fans will not run. If it needs R134, that means there is a leak and will continue to leak unless patched. I hate to say but, if it doesn't frost, you are better off to toss it.
    Vic
  • Victor
    Victor May 17, 2009
    Sounds like you will need a new frig. The compressor is bad.
  • 585 Answers
All indications are that this system is low on refrigerant. There is a leak somewhere in the system in order for this to happen. You can evacuate and recharge the system if you have access to the right equipment, but it will eventually fail again if the leak is not located and sealed.
Vaccum door lnot working replacing cooling coil
be looking at connections as well as emissions controls see if hoses were left off somewhere..
Dec 23, 2013 | Mercedes-Benz S-Class Cars & Trucks
Model # ET22DK, water is collecting underneath the crisper drawers.
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 15, 2011 | Whirlpool Refrigerators
Model ET22DK or ET22DM water collecting inside refrig
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 15, 2011 | Whirlpool Refrigerators
After about minutes of running the computer just
this sounds like an overheating problem.
First thing i would check would be the CPU fan. you will have to remove the side access panel on the case to check this.
If the CPU cooling fan is covered in dust, and the spaces between the cooling fins on the heatsink (right underneath the CPU fan) are clogged with dust. it would cause this problem.
there is also a fan at the back of the computer inside the power supply that can get clogged with dust, and may possibly overheating and shutting off. if you look in the back of your computer and find where the power cord plugs in, the power supply cooling fan is right around there as well.
If there is a good buildup of dust, it would be best to have your computer professionally cleaned. Using a vaccum cleaner is not a good idea unless you are familiar with procedures of working with static sensitive components.
hope this helps
Feb 15, 2010 | Gateway LX6810-01 PC Desktop
My fridge is working fine but my freezer is not keeping the food frozen it is a kitchen aid side by side any help?
Cleaned the condensor coils? If not locate the coils either underneath (open both doors and remove the toe kick) or in the rear (remove the back panel). Use a vaccum or long brush to get any dust, hair or debris off these coils. These coils are allowing the refrigerant to cool down and if hair or dust is all over them they cant release the heat efficently. This kind of stuff will insulate the coils and the heat cant escape or release. Otherwise you are dealing with a freon issue. If the unit is running but not cooling correctly anylonger it probably has lost some freon and will continue to lose it. Hopefully this helps.
Jan 24, 2010 | Nor-Lake Norlake Refrigeration 4' x 6'...
Center of side by side very hot center between doors very hot whirlpool 25 cu. ft
If by the center bar, you mean the divider between the freezer and fridge sections, then the heat you're feeling is the built-in condensation heaters designed to keep moisture from forming on the exterior of the unit. These heaters also help to keep moisture from freezing on the inside of the door edges and in between the sides of the unit as well.
It's a normal function of modern, frost-free refridgerators, Some brands/models have an "energy saver" switch inside the fridge section that you can use to turn off the extra edge heaters, if you aren't experiencing excessive condensation forming on the outside of the unit.
Not all the heaters can be turned off even with fridges that have an energy saver switch, as the manufacturers engineer/determine where and how many edge heaters are needed to get the best performance out of their products.
With an energy saver switch, you turn it "ON" to actually turn off the surface heaters, and turn it "OFF" to have the heaters run constantly. Thus having it "ON" saves the energy that would be used to keep the heaters very warm. Some manufacturers have added electronic sensors to regulate these heaters, but not all makers have done this.
You should also clean the coils to help the fridge run better. As far as getting to the coils to clean them, if you have a long narrow crevice tool with your vaccum, you can try to use that to get underneath the unit to carefully get the dust out. I found that if you move the unit out where you can get to all sides, makes it easier to remove any dust on the back and underside of the fridge. Don't foget that you might have to remove the lower, back access panel to get at the compressor/coil assembly.
Just unplug the fridge first to keep from ruining your spouse's vaccum tool in the cooling fan blade, like I did once and never he-ad the end of it! (Not to mention the noise it makes - brought her running to see what I was doing!)
If that isn't possible, you can always use the blower end of a vaccum to blow out the coils, but it's a messy proposition at best. I've used a swiffer taped with some duct tape onto a long, thin dowel to get quite a bit of the dust the vac couldn't $uck out - I prefer that to blowing dust out as it's less messy.
Provided your fridge and freezer are cooling properly, you shouldn't have any issues with the warm center compartment divider causing you any problems.
Hope you find this Very Helpful and best regards!
Sep 17, 2009 | Whirlpool Refrigerators
Fridge not cooling freezer works fine?
hi im andy from ac refrigeration in south africa ur fridge is short of gas
Jul 29, 2009 | Refrigerators
Refrigerator not cooling although lights and sound are OK
your condensor had been chocked therefore the gas is not circulating. contact your service authority..... as because it cannot be done by your self.
Feb 27, 2009 | Whirlpool ED2FHEXN Side by Side...
I have a ed5fhgxkq00 side by side Whirlpool refridgerator that stopped cooling. It worked fine up until last night when we noticed that the ice was melting. Now it gets a little cool but not cool enough....
If the compressor has a fan next to it, be sure it is running. if the relay is clicking every few minutes it may need to be replced. contact local parts distributor.
Nov 04, 2007 | Whirlpool ED2FHSS Side by Side...
Refrigerators Logo
660 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
