Question about Electrolux EW1000i Front Load Washer
Check hose error on electrolux wave touch washing machine
I just bought an electrolux wave touch washing machine and I'm starting it up running the installation cycle. It is giving me a check hose water hose error. The hot and cold are connected to the right place and there is no leaks. Please help!
  • Anonymous Mar 22, 2014
    I have an electrolux EWD 1419I and I have just had the belt replaced on it. After this It wouldn't start and I have checked for errors and it states error e51?
I'm sure nojallo1 has already fixed his but I just ran into the same problem and didn't find anything in my searches for a solution. The problem I had was the test cycle wasn't long enough to get hot water through my water lines so it could verify the hot and cold hoses were in the proper places. Solution: Turn the hot water on in all the sinks in your house until they have hot water running through them. This will prime your hot water line so it is full of hot water instead of cold water. Then run the install cycle again and it should be fine.
Posted on Jan 21, 2010
My top load electrolux washer machine, model MEX731CAS3 does not drain. it spins well and the cycle gets completed except the draining and centrifuging part. any suggestion?
The function of the pressure switch in the machine that gives a signal if the washing machine is full or empty with water.Spining cycle will start only if the machine is previously drain water and pressure switch overlapped to the empty position. Check everything about pressure switch and hydraulic circuit (tube and pressure chamber).
Dado
Jun 25, 2015 | Electrolux Washing Machines
What is the problem why water does not drain after rinse cycle?
Hello friend, thanks for your post!
I understand that your Electrolux washer is not draining properly. Some possibilities for your washer not draining could be an issue with the drain pump or control panel. You should additionally check the drain hose to make sure there are no restrictions. If your washer continues to not drain properly you should seek assistance from a professional to repair the appliance. I hope this is helpful. -Matt
Aug 12, 2014 | Electrolux Washing Machines
Electrolux dishwasher giving error code 1?
Good Morning Brian,
I understand that you are receiving an error code 1 on your Electrolux dishwasher, model# EWDW6505GS. Error 1 is stating that water has been detected underneath the tub. Check underneath your dishwasher by taking off the kick plate below the door. If you do not notice any water underneath the tub or any types of leaking, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker for 20-30 minutes. When the time has passed, restore power, and run any cycle. If you are still receiving error code 1, I suggest you contact your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
May 07, 2014 | Electrolux EWDW6505GS Fully Integrated...
Error code 1 Electrolux
I found that after 3 washes the flood well had enough water to activate the float switch thereby rendering the machine inoperable. What I done was drill a small hole in the plastic base well - the waster that drains out is minimal, not even noticed, but enough to keep the machine working.
Mar 28, 2014 | Electrolux EWDW6505G Fully Integrated...
Dishwasher isn't draining properly
check your piston and nut assembly has to have air tight seal to drain properly should be free moving if not replace it about $15 online
Dec 03, 2013 | Electrolux EWDW6505GS Fully Integrated...
I have an Electrolux wave touch front load washing machine which I am sure has a clogged drain pump filter. I am how to access it so that I can clean it?
I would definitely try to clean the drain pump, and coin trap if your unit is equipped with one.
To check for a restriction in the drain line you will need to follow the steps below:
1. Unplug the washer
2. Pull the washer out to tilt it back so you can
reach the screws below the front panel and
remove it. (You will need something to catch
the water once the hose is removed from
the bottom of washer)
3. Loosen the bolt with the sliver clamp on the
bottom of the washer. The water will begin to
come out while your loosening the clamp. (Do
not remove any GREEN clamps)
4. Once the water is out, you can stick your hand
inside the hose to clean it out.
Dec 24, 2012 | Electrolux EWFLS70JRR Washer
Ewdw6505gso electrolux. error 1. have turned off
the water will have leaked into the drip pan underneath, which is installed to protect your floors. Unfortunately, only way to get at it is to pull out dishwasher and remove 3 phillips screws that hold it on. In order to repair leaks, Electrolux came out with a "leak kit", which is part number 154769101. Comes with all parts that they had leak issues with
Mar 14, 2010 | Electrolux EWDW6505GS Fully Integrated...
New Install Went Fine Until E32 Message After Install Cycle - what the heck is an E32 error?
E32 indicates a problem with the pressure sensor. The service manual says to check the wiring (replace if bad), replace the sensor, if problems persist, replace the main circuit board.
There's a copy of the service manual inside the machine - remove two screws in the back and take off the top. The manual includes the error codes and the steps to take.
May 16, 2009 | Electrolux EIFLW55HIW Front Load Washer...
New Electrolux FL washer - will not fill with water
There are three main possibilities here. Firstly there may be a blockage that is stopping the water from flowing. Secondly there may be an item stuck in the pump chamber. Lastly the pump itself may be seized up. On machines that have their waste pipe connected under the kitchen sink it is always worth checking that the plumbing is not blocked with fat or lint at this junction. Check for kinking of the waste hose, this may of course release itself if you pull the machine forward. As for blockages and obstructions inside the machine itself it would be difficult to give any real guidance as there are so many models. If the pump is seized or defective the solution is nearly always the replacement of the whole pump.
May 03, 2009 | Electrolux EIFLW55HIW Front Load Washer...
Electrolux EW1000i Front Load Washer Logo
807 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
