Question about Xerox XG-91D 19" LCD Monitor
Xerox XG-91D When I first turn it on it comes on fine then after 2 or 3 seconds it goes blank then I can turn it off and on and it does the same thing. Why would it be doing this? I thought it might be a bad capacitor.
  • 9 more comments
  • nandkapoor00 Dec 27, 2007
    Hi, I got a Xerox monitor which displays picture for a while (2,3 sec) then goes off. Anyone can help me plz?
    When picture goes off , I click on/off button on the monitor and it shows the picture again for 40-45 seconds.
    How can i solve this problem????
    It is lcd monitor
    product no. XG-91D
    modleno. 900p
  • Anonymous Feb 08, 2008
    I am having this same exact problem with my Xerox XG-91D monitor. All of a sudden it just started doing this.
    When monitor is turned on
  • Anonymous Oct 10, 2008
    I have the same problem, mine's a Xerox XA7
  • marcins Jan 24, 2009
    turn on and after 3sec turn off itself
  • Anonymous Apr 14, 2009
    I have an xa7 19i the same thing happened, got told it was the capacitors and wasn't cost effective to fix it - shame really, it was a great monitor i think xerox were the only ones to have glass panels
  • Anonymous Apr 27, 2009
  • lindslake May 01, 2009
    When I switch on my computer the screen boots up as normal and then it would just go blank. You can switch it on and off after that and the screen remains blank.
  • Anonymous May 07, 2009
    ive got the same problem
  • wilbere
    wilbere May 09, 2009
    Same problem here with my Xerox XG-91D. I love the monitor, and am dismayed that it has started acting up. I think mine is out of warranty.
    Question: is it cost-effective to send this back for repair? Railandsail, how much, if anything, did your repair cost?
  • wilbere
    Problem Solver:
  • 3 Answers
Faulty capacitor(s) has ben mentioned by a computer repair man elsewhere in these solutions. I returned mine to the factory and was told they replaced an 'inverter' ?
Posted on Oct 17, 2007
SOURCE:
NO PICTURE
These are great monitors but the power supplies have a bad habit of failing. We have an article posted on our web site at: http://www.ccl-la.com/blog/index.php/xerox-xg-91d-monitor-repair/ That shows what goes out, how to get to the boards and a full parts list to do the repair. If you don't want to do the repair yourself we do offer a repair service, that information can be found here: http://www.ccl-la.com/blog/index.php/service-request-form/ If you have any questions please let us know.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Apr 30, 2010 | Xerox XG-91D 19" LCD Monitor
My Xerox XG-91D LCD Monitor start, display briefly (about 1 or 2 secs) then goes back. any solution in this case? mention that i use with a dvi-i adaptor on a vga graphic card. thx
I would try VGA to VGA hook up first to narrow down the problem before start taking the monitor apart.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). See example of failed monitors to get some ideas of what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Apr 01, 2010 | Xerox XG-91D 19" LCD Monitor
Xerox XG-19D LCD monitor goes black in 5 seconds
You may also have to check the IC/Transistors Inverter transfomer drivers, also should Ohm out the resistance of the transformers.
Mar 18, 2010 | Xerox XG-91D 19" LCD Monitor
Compatible with macbook?
Yes. if the macbook has DVI out. Do you have the correct adapter? DVI, you can't use the VGA adapter, you need the appel DVI out adapter.
Oct 04, 2008 | Xerox XG-91D 19" LCD Monitor
Logic board for xg-91d serial number E98Z5501032U
I can repair your Main logic board. I do repair work on ebay. my I.D. ecking767. Or search for Xerox under Computer and Networking
Nov 12, 2007 | Xerox XG-91D 19" LCD Monitor
Xerox XG-91D 19 in
it look like you need an inverter
Oct 11, 2007 | Xerox XG-91D 19" LCD Monitor
XG-91D (Black) 19 in. Flat Panel LCD Monitor
Partition shows up as a MS-DOS partition This utility is designed save information you may be working on when it goes into sleep mode or when your battery becomes low on power.
Computer questions and answers listing 700 - 800 CH000735, How do I disable the power, sleep, or wake buttons in Windows?
Good Luck, please dont for get to Vote, Thank You.
Aug 03, 2007 | Xerox XG-91D 19" LCD Monitor
Xerox XG-91D 19" LCD Monitor Logo
457 people viewed this question
Top Xerox Computers & Internet Experts
Aditya Agarwal
saurav777
Level 1 Expert
Jim LeVerso - IT...
Jim LeVerso - IT...
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
