Question about Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac
Poulan 14" Chainsaw-Has no fire.
Is it possible that I could have burnt out the module ignition coil by using a fuel mixture of 50:1, when it requires 16:1 mixture?It ran for about 7-10 minutes, then stopped.
  • Jim Parker
    Jim Parker May 17, 2009
    I didn't think so but I had to ask. 16:1 to 32:1 is in the manual, depending on the oil used. And yes, it has been years. It's a Poulan 2000 AV. I've had it for about fifteen years or so. Do you have any other ideas? I know it's extremely rare that this particular part would go out.
  • 376 Answers
No. That would have nothing to do with it. Too lean a mixture would have just seized the engine from lack of lubrication. That saw probably is meant to burn 40:1 anyway. 50:1 wouldn't hurt it in that length of time either. Where did you get 16:1 as the mixture? It's been years since anything was made that used that.
Posted on May 17, 2009
  • Dwain Pippen May 17, 2009
    Have you checked for spark by removing plug, so that it's easy to pull, and going directly to ground on the cylinder with the wire? A spark tester would be best for this or use a known good sparkplug and watch for spark to jump gap while holding it against the cylinder
Poulan chainsaw
There is two wires from the ignition unit, an earth cut out and an earth return, by pulling both wires away from the ignition unit will diss connect the switch completely, crank the engine at normal start speed to check for a spark.
Feb 14, 2014 | Garden
The car motor wont start, the coil is not sending fire to the disterbutor,bypassed the coil to the batery and still no fire to the coil what's the problem?
Hello, Bridget! I am sorry that I couldn't help you sooner but I have been ill.
I got hit by lightening in my home that bruise me up and burnt my feet (this is the third time over 50 years now). Then I got that infamous cantaloupe but which isn't good for ones health.
The ignition system comprises of the van computer, ignition module, coil, distributor with two major component inside of the distributor--high voltage rotators cap, and the module pick-up coil, coil wire, plug wires, spark plugs. Also, all the sensor that are sending different types of signals to the computer, such as; air/fuel mixture, ambient temp, air flow, throttle position, engine temp, ATM pressure, humidity, altitude, barometric pressure, CO2 mixture, vacuum negative pressure, etc. GB...stewbison
Oct 15, 2011 | 1994 Plymouth Voyager
My micro xxv has been idle for several years, now I 'd like to get it going again. Do I need to do more than fresh fuel?
Absolutely! Check to make sure that you are getting fire at the plug before moving on to my Tips. If you don't get spark at the plug, then you have a bad Ignition Coil (Module).
Here are a couple of my Tips that you will definitely need to check: http://www.fixya.com/support/r6078121-fuel_line_relacement_trimmer_weedeater
Jim
Aug 14, 2011 | Poulan 14" Chainsaw
I have a 14" Woodshark Poulan chainsaw. I put in
Poulan Chainsaws are pretty well all powered by two stroke engines. My best guess is that you have the fuel mixture incorrect (it should be a 1:40 ratio of oil to gas). if the fuel mixture is not the problem then your choke is messed up. If you haven't tried already try and find the sweet spot in the choke where it will run.
Mar 04, 2011 | Poulan 14" Chainsaw
Pro 42CC 2 Cycle Chainsaw, 18": how does this module work, what is the circutry ?"...
If you are speaking of the ignition module, the flywheel magnets induce a high voltage from an internal coil through a diode and into a capacitor and then the magnet position controls a transistor that discharges the capacitor into the ignition primary coil and that induces spark voltage into the ignition secondary coil which fires the plug. It requires several revolutions of the flywheel to charge the capacitor and why it takes several pulls of the starter to get the plug to fire regularly. That's a lot of action inside such a small package! Hope this helps!
May 18, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Gas/Oil Mixture, 50 to 1 or ?
All major manufacturers recommend 50:1;
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil or
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
with the exception of McCulloch and Poulan 40:1 and Chinese chainsaws 25:1.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 18, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
What is the fuel mixture for my new Poulan Pro 18'' chainsaw? It looks like 32:1 but not sure.Thanks! Don
If you use a mixture of 50:1 you can't go wrong.This is the industry standard and can be acheived by following the mixture guide lines one the bottle of oil.32:1 will make your saw smoke to the point of being almost unbearable and will foul the plug,so 50:1 is the mix your looking for.
Dec 15, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have an 18'' Poulan chain saw that won't start.
Take the wire of the spark plug,and see if it shocks you when the cord is pulled.If not there may be something wrong with your coil.(loose wire for example)If it does shock you,you may want to check out your piston rings,or the little air/fuel mixture valve between your carburetor,and cylinder.
Jun 05, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac Logo
377 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
