Question about Cuisinart Brew Central 12-cup Coffee Maker
Water does not flow up to drip into the carafe. It is clean
The water does not flow up to drip into the carafe. I hve cleaned the unit and used vinegar and water. what can I do now?
  • 85 Answers
Hello sandyconti,
When the vinegar & water won't work, try the following:
I recently had this similar problem.
Your described problem may be one of two problems. Let's start with the easier solution first. In the DCC 1200 there is a filter "stick or column" in the left rear. Pull it out and remove the clogged carbon filter(s) that are in there. Shine a light into the receptacle and remove the debris in the bottom. It is likely that this is causing the problem with you machine needing to be started on multiple times. See if this solution works. If it does, you might run 8 cups of water and 4 cups of vinegar through to help decalcify the units plumbing. Do this once or twice and then rinse with at least one pot run-through of clean water. If this works then you are good to go.
Next, if this does not solve your problem we can do the following: unplug the unit and lay it on its back. You will need a #10 torx driver (hardware store if you don't have one) to remove the bottom cover plate. There are 4 torx screws holding it on. When removed, you will find 2 orange hoses. Carefully attempt to remove the left hose without splitting. I used a eyeglas screwdriver to loosen it up. If it splits, just cut off the split and stretch it to reconnect when time comes. As you look into the hose you will find a little black valve inside as well a some gunk. Clean it all out with a fine wire as best you can. Rinse well. Attempt to reconnect the hose back onto the pipe. Slip the pipe clamp back into place. Replace the cover and screws and you should be good to go again. This is not as daunting as it may seem. You can do it. :o) Good luck! If this answer helps, please leave positive feedback for me. Much appreciated. Regards, NormanZ
Posted on Jul 09, 2009
If you don't have the torx screwdriver at hand suggested by norm49629 , or don't consider yourself handy with tools, here's another solution I stumbled upon. It requires a vacuum cleaner attachment with a small opening, such as much be used to **** dust from, say, a computer keyboard.
Ideal is the Rainbow (TM) system, since it is water based anyway, and you'll probably pull up some water. When you pull out the carbon filter "column," there is a tiny hole where the water enters after going through the filter. You will probably need a flashlight to illuminate the area to locate the hole, perhaps held by someone else. Place the vacuum cleaner attachment over the hole. You can usually tell by sound if the attachment has achieved suction. It required two separate sessions for me, each about a minute in time, and I got a lot of coffee grounds out. Run water through the coffeemaker several times to clean it out.
Posted on Sep 12, 2011
Water overflows from coffee container and does not drip into carafe. plunger is working something is keeping water from flowing through to carafe.
You may have the wrong size carafe. Try sitting something under the carafe; something that wont burn on the hotplate. Maybe thick enough to give a 1/8 inch lift or so. If this fixes the problem, you are using the wrong carafe. Try using a wet washcloth. Fold a couple times. Wetting it is just to avoid damage from the hot plate.
Mar 26, 2015 | Coffee Makers & Espresso Machines
How do I run the clean cycle?
I assume you mean descaling the coffee maker when the Clean indicator flashes after a brewing cycle. You can use a packaged descaling product or white vinegar. For the packaged descaling agent, follow the package directions for the ratio of product and water. If you are using vinegar, fill the carafe with a 50:50 mixture of water and vinegar.
Remove the water filter and remove any coffee and coffee filter from the brew basket. Make sure the unit is plugged in and turned on. Pour the descaling mix from the carafe into the water tank and then place the carafe in the coffee maker. You have 10 seconds to program the cleaning mode or the unit will return to the standby mode. The next step depends on the type of carafe. For a machine with the glass carafe, press Mode 6 times. Otherwise for a unit with the thermal carafe, press Mode 5 times. The Clean indicator will blink. Press Program/Set followed by the + or - button to select Clean On. Press and hold Program/Set until you hear the beep. Press Brew and wait for the cycle to complete (the Clean indicator will go off). Then do two brewing cycles with water but no coffee or coffee filter. Discard the fluid from the coffee maker from all three cycles. Wash the brew basket and then reinstall the water filter.
If you notice an odd taste to the coffee when you next brew some, do at least one more rinse with water (remove the water filter and coffee grounds/filter).
KitchenAid manuals are available from their site: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD . The direct link to the manual for the Kitchenaid KCM223OB is http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10321647.pdf . See page 13 for the directions.
I hope this helps.
Jul 04, 2011 | KitchenAid KCM223OB
How do you clean coffee maker?
Start a cycle and run 4 ounces of white vinegar and 16 ounces of water through the coffee maker.
May 29, 2011 | Bunn NHB Coffee Maker
The clean light came on and I cannot find my manual to find out how to clen it. Plaeas help
Always turn coffeemaker OFF and remove the plug from the electrical outlet before cleaning. Lift up the reservoir cover. Remove and discard the paper filter and ground coffee. The filter basket can be washed in warm, soapy water and rinsed thoroughly, or cleaned in the upper rack of the dishwasher. Dry all parts after use. Do not put any water in the unit once the filter basket has been removed. Wipe the area under the filter basket with a damp cloth. Remove the carafe from the heating plate. Discard any remaining coffee. The carafe and lid can be washed in warm, soapy water and rinsed thoroughly, or placed in a dishwasher. The carafe and carafe lid should be placed on the upper rack only. Do not use any scouring agents or harsh cleansers on any part of the coffeemaker. Never immerse base unit in water or other liquid. To clean base, simply wipe with a clean, damp cloth and dry before storing. Fingerprints and other blemishes on the stainless steel housing can be washed off with soap and water or a nonabrasive cleaning solution. Wipe warming plate with a clean, damp cloth. Never use rough, abrasive materials or cleansers to clean the warming plate. Do not dry the inside of the water reservoir with a cloth, as lint may remain.
You can print the manual on this link:
http://www.cuisinart.com/share/pdf/manuals/dcc-1200.pdf
Feb 15, 2011 | Cuisinart DCC-1200 Coffee Maker
Coffee overflows onto the counter from time to time. Have a clean gold filter. It seems that the coffee doesn't flow threw the lid as fast as it used to. How do I clean inside the coffee pot lid? There...
I believe your problem is the filter basket holder is not seated correctly or the carafe is not completely inserted in the unit to push the brew pause lever up. The brew pause feature which stops the coffee from going into the carafe when you want a cup of coffee before the brew cycle is done. When you remove the carafe a spring lever stops the coffee from dripping into the carafe. When the carafe is inserted it must push the spring lever up to allow the coffee to flow into the carafe. If it is not the coffee will overflow and make a mess. The filter basket holder should be firmly seated in the unit so it will not have any play in it. Cuisinart recommends using a vinegar and water mixture but BrewRite Cleaner (Sodium Carbonate) available in the coffee section at Wallmart, Kamart and Target is fantastic. You can clean your carafe with BrewRite Cleaner and hot water by letting it soak a few minutes and rinsing. I will also clean your filter basket holder by soaking it as well and all your coffee residue will be gone with no scrubbing.
Jul 29, 2010 | Cuisinart DCC-1200 Coffee Maker
I have a FTX49 Mr Coffee Maker purchased 9 months ago. It just started to leak in the front area where the round burner casing meets the tall front face of the unit (the groove area on both sides??) What...
There is a lever in the back of the carafe area that pivots and controls a spring loaged valve on the bottom of the removeable filter basket. This lever breaks easily. Pull the filter basket out and you can see the lever hanging down into the carafe "bay". (assuming it's not broken off entirely).
When you pull the pot out during brewing, the lever swings forward and allows the valve on the bottom of the filter basket to close. This shuts off the flow of coffee to avoid drips. The plastic lever is held in place underneath the valve by two round tab "ears". One of these ears can break off, causing the level to hang at an angle. This means the filter valve never completely opens, even if the pot is pushed in all the way. During brewing, the filter basket can't drain into the pot fast enough and overflows.
I fixed mine by going ahead and removing the damaged lever and then wedging the valve open. The spring loaded valve has a little drip "Spout" which hangs underneath the filter basket that directs the coffee into the pot. You can push in on the back of the drip spout and wedge something into the two slots at the back to hold the valve open. This let the coffee flow freely during brewing.
Oct 15, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Not brewing. Add water and coffee, switch to the brew selection and the water/coffee does not flow. The machine heat ups and starts processing noise.
Make sure the lid is on the carafe.
Make sure you are not using a paper filter and a gold tone filter at the same time.
Make sure the carafe lid is down all the way and that the center knob of the carafe lid is making contact with the spring at the bottom of the filter basket.
If the above conditions have been met, then decalcify your coffeemaker by running 1/3 carafe worth of vinegar and 2/3 carafe worth of water through your coffeemaker - use the self-clean button to do this - will take about 35 minutes.
Aug 30, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Cusinart 12 cup grind and brew overflows with grinds and water
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Do not "pack" or otherwise overfill the cone/basket with grinds.
2. Ensure you are using the correct grind for an automatic drip coffee maker, neither too fine nor too course. (See instruction manual.)
3. Do not overfill with water. Use the carafe to pour water into the reservoir. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz. Note: Some coffee makers define as little as 5 oz as a cup.
4. Make sure the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Verify that the Pause 'n Serve button isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
8. Clean your machine with vinegar or as instructed by your user manual at least three times per year, more if your water supply is hard. A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew, to produce "off" tasting coffee, or to clog and overrun the filter basket as the water runs through the grinds.
9. Ensure that the coffee machine is sitting level on the counter.
Apr 02, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
Coffee overflowing and spilling out of the basket
Your coffee maker likely has the option where you can remove the carafe while it is brewing so that you can serve yourself in the middle of the brew. When you pull out the carafe in the middle of the brew, a small lever closes off the drip at the end of the basket (to keep the coffee from flowing onto the empty space where the carafe was on onto the burner).
Then when you replace the carafe, the lip of the carafe pushes against that lever and re-opens the valve so that the brew can now drip into the replaced carafe. Simple.
In your case, it appears that when you place the carafe onto the burner plate, it is not engaging that lever and opening up the valve; hence the valve stays closed and the brew fills over the basket and makes a mess, right?
So do this, pull out the carafe and look up where the pointed end of the basket drips into the carafe. You should see a lever, or plate that the carafe top lip hits when the carafe is placed into the burner plate. Once you find that lever, or plate, give it a push (like the carafe would) and see if it moves. if it does not, then that's your problem. It is stuck closed and won't allow the brew to exit the basket into the carafe. Clean it thoroughly if it is stuck and then see if works.
Mar 29, 2009 | Coffee Makers & Espresso Machines
Mr Coffee stopped brewing
Sounds like there are a couple of problems -
First, are you certain that the coffee basket is clean? If the coffee basket has a valve on the bottom that allows you to remove the carafe to pour a cup of coffee, make sure the valve is clean. Being dirty would cause it to trickle coffee slowly into the carafe, and will hold coffee in the basket too long.
2nd, you may need to flush the water heating system as they can become corroded with precipitated solids from the water.
To do this, mix 1 part vinegar to 2 parts water in the carafe. Pour into the coffee maker and tell it to make coffee. Do this a couple of times, using a fresh mix of vinegar and water each time. Pour the used mixture down the drain.
When you feel it is clean, follow it up with a fresh pot of water. Then wash and rinse the carafe.
The coffee maker is now ready for it's next use.
Jan 30, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Open Questions:
See all Cuisinart Brew Central 12-cup Coffee Maker Questions
Cuisinart Brew Central 12-cup Coffee Maker Logo
218 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
