Question about RCA F36645 TV
DVD/TV Combo - Won't read DVD
My RCA TV/DVD combo won't read my DVD to play it.
What can I do myself to repair it ?
    Genius:
  • RCA Master
  • 1,550 Answers
Compra el disco limpiador de laser que vende Radio Shack,si con eso se soluciona tu problema que bueno si no llevalo a un centro de reparaciones.
Posted on Mar 20, 2008
It's not working what can I do to program one for all controller to rca tv
HI,
The One For All 3 Device Universal Remote Control is preprogrammed at the factory to operate an RCA TV, a Toshiba DVD player, and a Motorola cable box. To control devices other than the default brands, perform the following steps; otherwise skip this section:
HOW TO PROGRAM
1.Turn on a desired device (e.g.,VCR or DVD player) and, if applicable, insert media (e.g., cassette or disc)
NOTE: Please read steps 2 through 4 completely before proceeding. Highlight or write down the codes and device you wish to program before starting step.
( CHECK THE BELLOW ADDED LINK TO FIND THE CODE )
2.On the remote control, press a device key once (i.e., DVD/VCR, CBL/SAT, or TV).
NOTE: To program control of a VCR, PVR (or DVR), TV/VCR Combo, or TV/VCR/DVD Player Combo press DVD/VCRonce. After programming a VCR Combo device, you will be able to control channel selection, volume, and VCR functions.
NOTE: To program control of a DVD Player, DVD Player/VCR Combo, or TV/DVD Player Combo, press DVD/VCRonce. After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR) Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR) Combo, press CBL/SATonce.
3. Press and hold SET until the LED (red light) blinks twice, then release SET
4. Use the Manufacturer's Codes (starting on page 18) to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly, the LED will blink twice.
NOTE: If the LEDdid not blink twice, repeat steps 2 through 4 and enter the same code again.
5.Aim the remote control at the device and press POWER once. The device should turn off.
If it does not, repeat steps 2 through 5, trying each code for your brand until you find one that works. If it still doesn't work, try Searching For next code.
NOTE: If the device does not have a POWER key, press PLAY
6. Repeat steps 1 through 5 for each device you want to control. For future reference, write down each working device code following.
Electronics Equipment Repair Center ONE FOR ALL URC3021 UNIVERSAL REMOTE...
Jan 25, 2015 | RCA Televison & Video
Dvd won't eject from RCA tv/Dvd combo
While hitting the eject button use a small flat screwdriver or butter knife to ease door open, probably the rubberband like belt broke or the gears jammed up!
Jun 17, 2012 | RCA 22LA45RQD 22-Inches 720p LCD TV -Black
RCA L32WD26D TV/DVD/HD Combo - dvd wont eject
Hello
Check the loading motor and loading belt. If loading motor has damaged, or loding belt has broken or loose. the in-out tray mechanism won't work well.
Mar 03, 2012 | RCA L32WD26D HDTV/DVD Combo
Apex DVD/Tv combo GT2015DV won't play dvd's
Something is wrong..crbr799 your DVD-TV has a TV-DVD button on the right front to switch from TV to DVD play...OPEN button on left side ,place DVD in tray, close & press PLAY...
I something simulator that needs the remote control for the SPECIAL functions....by the way the ORIGINAL r\c is $135 to $155, a replacement ($35) will turn the TV\DVD on ( which you can do without the r\c) and NOT function with anything else.
P.S. they will try to sell you universal r\c that work with the CABLE boxes, the ones that you pay a monthly fee!!
Aug 11, 2011 | Apex Digital Televison & Video
I have an LCD/ DVD combo and the DVD won't come out. The tv still reads the DVD but won't eject it. I've tried on the remote and the unit :(
then there is a problem with your cd case .........................................................
ON THE BACK OF DVD THERE IS A WIRE OR SUM PIECE PULLED IT BY USING SOM CLIP THEN THE DVD'S DOOR OPEN EASILY..........
Aug 07, 2011 | Televison & Video
My Sony CDRWDVD CRX880A ATA Device won't read Dvd's I'm trying to make burn a movie on there and it won't load the disk it says " Let windows help me choose a disk" because D:/...
The
CRX880A is a cd writer and DVD reader it doesn't record dvd only plays them
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Thanks for using Fixya.
Jul 03, 2011 | Sony CRX880A CD-RW/DVD-ROM Combo Drive
When I try to watch a dvd it tells me inproper disk.... It worked fine for a year and a half then all the sudden won't play dvds
Try to clean the lens of your dvd player. Buy a cleaner for the lens. If the problem still experiencing after cleaning, you need to bring it to the repair shop for further checking. Maybe there's a part inside the player that need to replaced.
May 09, 2011 | RCA L26HD32D 26 in. LCD HDTV/DVD Combo
Remote won`t operate tv stuck on channel 99 w/ no signal showing
Some units have a little hole where you can insert a straightened paper clip and manually retract the DVD.
Make sure the power is turned off first.
"Your mileage may vary."
Jun 30, 2010 | Mintek DTV-263 26 in. TV/DVD Combo
RCA D52W136D 52 in. TV/DVD Combo dvd does not play
did you try to get a dvd cleaner to clean out your dvd player.
Feb 13, 2010 | RCA D52W136D 52 in. TV/DVD Combo
Only works when playing a DVD.
This is an easy and quick fix.
What you will need:
RCA cables (audio)
( possibly Line out converter )
Your television is either going to need Video Out, or if you have a VCR or VCR/DVD combo connected to your television. Assuming that you have a VCR combo, the way your tv should be set up is on the back of the vcr combo, your cable will run into the coaxial IN and then you have another cable running from Coaxial OUT to your tv. If you have it set up like this, then the DVD / VCR combo will have RCA Audio / video out ports on the back side. Run RCA cables from the DVD / VCR output to the surround sound INPUT. If you already have your inputs in use on the surround sound, Radioshack has RCA splitters for about $1.50 each, you might need to pick some of them up so you dont have to go through the trouble of reaching behind it all the time to disconnect and reconnect whatever your trying to connect. Now if you dont have the DVD / VCR combo, then your TV "MUST" have RCA Outputs. if it doesnt, then the only way that your going to have your surround sound connected to your tv is to take the TV apart and get a RCA "Line output converter" and wire it to the left / right channels of your tv. From what I've read, i think this is what your trying to do so I hope this helps
Feb 19, 2008 | Durabrand STS92 System
Open Questions:
See all RCA F36645 TV Questions
RCA F36645 TV Logo
189 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
