Question about Gateway FPD2275W LCD Monitor
Gateway LP2207 Monitor comes on with Gateway icon but will not stay on.
Gateway LP2207 Monitor comes on with gatrway icon but will not stay on
  • tazgal72 May 22, 2009
    my monitor comes on with the gateway icon but will not stay lit. When I put a bright light on it I can see the the image of the active desktop (it's not the ghost) I can see where the curser is moving and all. It just does not have the bright screen. Anyone else ever experience this prob? Should I take it in or just get a new one? I had liked this screen.
  • 4 Answers
Its most likely the light capacitor it can easily be fixed but if your going to buy one anyway dont go back to gateway they offer poor technical support
by light capacitor i mean the capacitor giving power to the light
Posted on May 22, 2009
Testimonial: "This was the problem, thanks for you help. "
    Novelist:
  • 159 Answers
If you don’t have the startup sound when you plug it in, the main board may be bad.
If your picture was pinkish or dark at the top or bottom when it was working then you may have 1 or more of the bulbs failing.
If your picture wasn't pinkish or dark at the top or bottom when it was working, then it sounds like probably the inverter may have went. They are light light bulbs and have life expectancies on the capacitors.
To get to the inverter:
remove the stand
Take the 3 screws out of the bottom rear edge (these hold the front trim),and the 4 big black ones at the middle of the back
the the trim then unsnaps. {Be aware of the small ribbon to the power button board on the right edge} Start at the bottom and release the trim usually by gripping it on the lcd screen side with your fingertips and pulling outward, then work your way up each side from the back where the front trim meets the rear case. Work from the bottom to the top (a pocket knife or thin putty knife will help release the catches) You can also sharpen the edge of a credit card-(plastic is a little safer)
Then unsnap the top edge (rocking it while lifting helps)
Disconnect the ribbon, (Tiny latch lifts up on a hinge and ribbon slides out)
Once trim is off, remove the 4 corner screws that hold the screen in. Then the screen will lift out with all the guts. You may have to use a screwdriver like a crowbar in the croners to start the screen to lift up.
You’ll then have to remove a bunch of screws including the speaker ones and the usb board ones and unplug the bulbs and wire to the screen
then the inverter is under the center area under the metal cover
Shout if you need more info.
If you email me a good picture of the inverter , I may be able to get a better idea if it is the inverter from a visual.
Thanks Fran
bammbamm@ptd.net
Posted on Jan 15, 2010
How do i get the sound to turn off on the monitor when i turn it on?
Hello Janine
Of course, if your particular monitor provide sound, (integrated) or the monitor has speakers, you can.
but if in the HUD menu, or visually you wont see any speakers, I fear not.
Carl
Mar 25, 2016 | Gateway LP2207 LCD Monitor
HOW DO I CONNECT A GATEWAY LP2207 TO GET THE AUDIO TO WORK?
Some monitors do not have speakers (my HP monitor does not). The sound has come out of some external speakers attached to the tower. Or maybe you need to access the monitors on-screen menu to turn the speakers on (if they have speakers). Or maybe you can access the monitor speaker control through the PCs Device Manager option (this is where all external components attache to the PC can be viewed, and sometimes changed).
Aug 13, 2014 | Gateway LP2207 LCD Monitor
Gateway LP2207 64 bit drivers
If you can't find the drivers anywhere else, do this: There is a UL Code listing on the back on the monitor's electrical ID tag on the back label. It has a number on it: UL (number). Go to the UL site and look up the number, it will tell you who actually made the monitor for Gateway. (Gateway doesn't
make monitors, it rebrands them.) Go to the mfr's site and download drivers for the monitor of the same size as yours using the 64 bit drivers. It will take a bit of slouthing, but can't be done successfully. (Ex. Sampo is actually Hitachi.)
Jun 30, 2014 | Gateway LP2207 LCD Monitor
You didn't mention what operating system you have.
You can check out the drivers here for the LP2207: http://www.driverplatform.com/file_lp2207-monitor.html
Additionally, you can get a lp2201 manual here: http://static.highspeedbackbone.net/pdf/Gateway_HD2201_Manual.pdf
Jun 30, 2014 | Gateway FPD2275W LCD Monitor
The light goes off the monitor and it dont turn on when i turn the computer on.
Are you saying when you end up holding the button on the side of the monitor so that the screen turns on solves the problem? more info could help!
Jan 31, 2014 | Gateway LP2207 LCD Monitor
KDS usa flat screen monitor model 780 2003
Shine a light on the screen and see if the Icons are there.. Could be a CCFL bad or inverter problem..
Jan 25, 2008 | Gateway FPD2275W LCD Monitor
Gateway FPD2275W LCD Monitor Logo
2,173 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
