Question about Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac
Feather Lite Weedeater(Poulan)runs for 10 minutes, then stops.
Gas cap is clear.
  • Jim Parker
    Jim Parker May 17, 2009
    After the weed eater cools down, it will run again; but only for another 10 minutes.
  • Dwain Pippen May 11, 2010
    What are you asking?
  • 1,040 Answers
Haven't had the chance to work on it this weekend.Hope to have time this week some time. Thanks.
Posted on May 17, 2009
  • 376 Answers
It sounds like maybe your ignition coil my be overheating. The next time it quits, remove the sparkplug, reconnect the wire to it, hold it against the cylinder so that it is grounded and pull the rope and see if it has any spark jumping the gap. Try to find a dark place as the spark sometimes is hard to see in bright light. If that's your problem, it may be cheaper to buy a new one as they are relatively inexpensive.
  • jmaple200
    jmaple200 May 01, 2012
    mine did that and I finally took it apart. I found a clogged fuel screen under the bulb. Cleaned it out and now it runs fine. must have been dirty gas and a rotten fuel line that I also replaced.
How to spool the cutting wire
please see instructions on replacing the line on page 14 of the manual.
Make sure you buy the correct line size. Incorrect line size will cause lot of grief and frequent replacement.
http://www.poulanpro.com/ddoc/PPOO/PPOO2009_USen/PPOO2009_USen_PP025-545177327_952711878.pdf
Sep 02, 2014 | Poulan WEEDEATER FEATHER LITE 1500 GAS...
Won stay running
Needs a carb adjustment, cleaning, or possible rebuilt. Try adding a little seafoam and running at half choke for about 5 mins or longer this may clean it up nicely. also check the spark plug.
Nov 09, 2013 | Poulan WEEDEATER FEATHER LITE 1500 GAS...
I have a Poulan Prolink 150E weedeater. One day I was running it and it just stopped. I've changed the plug, thinking that was it, it wasn't. It's getting gas but not fire. Do you have any
If fuel is present and spark is good then it's air. Remove air filter and see if it starts. If so, it's time for a new one.
May 02, 2012 | Garden
Feather lite trimmer only runs on half throttle and idle dies on full throttle. unit is new
When I bought a new poulan gas trimmer, I had the same problem. Solution was to return it and get another one. They come with problems, even new. Just keep returning them until you get one that works correctly. Mine works great, but like I said, had to return it and get one that was right.
Jul 01, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Poulan 21cc weedeater - starts but won't stay running. I've cleaned all fuel lines, cleaned plug and has plenty of gas - but still won't start. runs for 2 or 3 seconds and dies. appears to not be getting...
On these types of motors that could be the problem, another thing to check is the primer bulb. I have had a primer bulb that had a small crack in it which went undetected for a while. These types of motors do not have a fuel pump and they work on a siphon type mechanism, if there is an air leak dealing with the gas tank anywhere, that is your problem.
Aug 11, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Need to know the gas to oil ratio for my feather lite weedeater. Model FL21
"Echo Power Blend Universal 2-Stroke Oil can be used in all of our 2-cycle air-cooled equipment ever made. You may also use this oil in any other brand of 2-cycle air cooled equipment, but it should always be mixed at the 50:1 ratio whether or not it was a 32:1 or 16:1 etc. machine. This oil is the highest quality 2-cycle oil on the market today. There is no need to have more than 1 tank of fuel for your 2-cycle equipment any more."
The above excerpt is from the Echo FAQs (6) here:
http://www.echo-usa.com/faqs/
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years.
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 17, 2010 | Echo Rapid Loader, Trimmer Head
Feather lite weedeater disconnected shaft and
You may not have the drive shaft seated all the way into the power head.
You will have to loosen up the drive shaft and push the shaft in but at the same time turning the trim head to fit it into the drive area, then tighten it back down.
Oct 03, 2009 | Poulan Garden
I have a Poulan PRO PP446T that Starts and runs great for about 10-15 minutes then is hard to start and won't idle without stalling, seems after is runs hot. has been tuned up by professional but still has...
Hey Don, I understand your frustration! Had the same problem years ago. Sounds like your gas tank is not breathing.Try this: Run the trimmer until it begins to stall out, then loosen the gas cap slightly. The trimmer should begin to run again. If it begins to run, then the gas cap is clogged. Clear the breather hole or purchase new gas cap. This should solve the problem.
Jim
May 01, 2009 | Garden
Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac Logo
1,262 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
