Question about RCA DRC8295N DVD Recorder/VCR
My dvd/vcr reorder all of sudden fails to see a neg. dvd disk. I have used the same type for 4 years without a problem.I am able to play a movie on the dvd tray but it won't see a neg. disk to record. It says wrong type disk or a dirty one. Neither is the case. Please advise,thank you, Al
  • aslade May 17, 2009
    I have removed the unit from service. I took the cover off and it is spotless inside.(No dust at all). I made sure the laser "slide" worked well.I dusted the laser eye with a lint free cloth.Still does not reconize the dvd type that I have used for 4 years.However I can play a movie (dvd)with no problem on this player.Now what? Al
  • 3,741 Answers
Its the problem of the main circuit board in the unit.actually the neg.disk requires more power from the board then normal disks.the actual system is when you insert normal disk the laser lens which you called eye.that reads the normal inserted disk from siome particular distance.but when you insert neg.disk in the player ,at that time the laser lens comes more nearer to the neg.disk then normal disk.so in your player the lens is not moving more near to read the neg. disk.this is happening because of main board.as its not giving the command to the laser lens to function when neg.disk is inserted. so the error comes up as wrong type or dirty disks. in this problem on the main board sometimes there is not a single burnt spot.but internally the tracks get short.this can only be checked by multimeter.this can be easily got repqaired by a local repair center.who is familiar with electronics parts repair and knows how to use meltimeter and soldering iron.also the cost will be negligible. to much usage of the player in this same condition also makes the laser lens weak.because when ever you insert the neg.disk in the player the lens has to function.but due to main board problem the lens cannot read the disk and the pressure is applied on the lens every time.so to avoid further damage of board towards lens assembly get it repaired. this will help you. thanks.please do rate the solution.thank you for using fixya.keep updated.
Posted on May 17, 2009
    Genius:
  • 1,847 Answers
Firstly make sure that you are using te correct type od DVD.
Use a DVD lens cleaner to the clean the lens.
Let me know
Thanks
Kevin
My emerson ewr20v4 plays cds with music but not dvd with movies. It keeps displaying disk error
check and see if the dvd player needs to be cleaned. you can pick up contaminates from other dvd's or cd's get yourself a dvd disk cleaner and run it thru seveveral times . and try to play your money then.
May 09, 2014 | Emerson EWR20V4 DVD Recorder/VCR
I get the disk dirty message when I try to play a DVD R disk that I just recorded with a Sony VRD-MC6 video converter. It states in the book that some players will not accept DVD R disks, is that what is...
IT MIGHT BE. BUT MOST OF THE NEWER PLAYERS WILL PLAY ALL TYPES OF DISKS. I WOULD FIRST TRY TO CHANGE YOU BRAND OF DVD R'S. I HAVE USED MEMOREX DVD+R FOR ALMOST 10 YEARS AND I HAVE ONLY HAD 3 BAD DISKS BUT I BURN ABOUT 4-8 MOVIES A WEEK. SO I COUNT MYSELF LUCKY. PLUS ANY ONE WHO BORROWS A MOVIE HAS NEVER COMPLAINED. HOPE THAT HELPS IF NOT SHOOT ME A RESPONSE AND I'LL GIVE YOU SOME MORE TIPS.
Feb 20, 2010 | Sony DVP-NC650V Multi-disc DVD Player
Dmr-ES30V Dvd plays pre record movies fine but I
Try a different brand of blank dvd+r or -r. you will find that your dvd machine is fussy on what discs it plays. More exspensive dvd players are fussy with what dvd discs you put in, as cheaper dvd players would virtualy play most types of dvds.
Dec 09, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
DVD movies not playing but CD-ROM games and CD's do?
With the disk inserted, 1) double-click on MyComputer, 2) right-click on the DVD, and select Auto Play from the resulting menu; a window will appear, 3) click on your favorite DVD playing software and 4) check the little box below to do the same every time you insert a movie (as it used to be).
Apr 15, 2009 | E-Machines eMachines Desktop PC
Dvd player only plays some movies
it might be sevral reasons:
1. Check if region code is the same for movies you playing and DVD player
2. If you using video CDs or copyed DVDs, player might be preventing to playback those kind of discs, due to copyright laws or due to different speed settings for DVD player and discks you using (for intsrance you player can playback DVD/CD+R, and you using DVD/CD-R, or mximum allowed playback speed is 16 you using disk recorded at 24, but this is in case you using burned/copied CD/DVDs)
3. Check it lens is durty. For that use CD/DVD lens cleaning disk
($6 in Walmart, if you are in US)
4. Check if movies you are have the same coloring system, i.e NTSC for US
5. Check CD/DVD for scratches, some DVD players can not playback scratched disks
Please kindly let me know if my information was helpfull for you or you need more info
Good Luck
Feb 01, 2009 | Philips Magnavox DVD/VCR Dual Player
Unable to play a DVD movie
Most probably the TV system is not compatible.
This VCR/DVD uses NTSC formate. Is the DVD in PAL formate. Also the Region code can be different. This DVD palys DVD-Disks with regional code 1 or All.
Dec 09, 2008 | GoVideo DVR4300 DVD Player/VCR
Disk error
It could be the lens on the laser. There are special cleaning disks for that.
Jun 18, 2017 | JVC DR-MV1S DVD Recorder/VCR
Dmr ez25eb
clean the lense and try otherwise you have to replace the lense..
Aug 03, 2008 | Panasonic DMRES30V DVD Recorder/VCR Combo
Samsung DVD-4600 DVD/VCR Player
My Smasung DVD/VCR Combo stopped reading DVDs because of a dirty read head. It started by only playing disks sometimes, and progressed to never playing disks. I assumed it was a dirty laser lens so I bought a lens cleaner set. Unfortunately my player wouldn't play the cleaner disk.
So I took it apart and cleaned the laser lens manually with some isopropyl alcohol (the clenser that came with my cleaning disk), and a lens cloth (that came with my glasses). Just open the case (starting with the screws in the back) and remove the snap in cross panel that obscures the lens of the DVD portion. Put a drop of cleanser on the lens and gently wipe it with the cloth.
Oh and by the way, I take no responsibility if you break your own player while following my instructions. My own DVD player was far out of warranty at the time I cracked it open.
Aug 16, 2007 | Samsung DVD-V4600 DVD Player/VCR
RCA DRC8295N DVD Recorder/VCR Logo
75 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
