HP Compaq nc6230 Notebook Logo
B
Bonita Buie Posted on Dec 24, 2013
Will not turn on
When I plug my computer in the lights to start it blinks on and off. It wont stop as long as its plugged in
I dont have a remote for my tv and it wont turn on manually the led light blinks 9 times and stops and starts again what should i do?
The blinking lights are a service code. You should first try to unplug your TV and leave it unplugged for at least 4 hours... then plug it back in again.
If the blinking light is still there and no picture, time to have the TV serviced. Good luck!
My aspire aoa150 wont start up. turns on but screen remains black
This is bios problem. need to update bios.
Downlaod the bios file from this site.. extract into a formated usb .. plug the charger ... and plug the usb .. keep pressing FN+ESC button then turn on the laptop u can see light is blinking .when light stop blinking relase buttons wait for 5 min ..system will restart.. and u can see display.. Thanks
http://macles.blogspot.com/p/acer-aspire-one-bios.htm
When i try to charge my pantech duo, the light starts blinking and it wont charge
when you plug in your phone and it starts blinking let it sit that way for a bit then take the plug out of the wall while it is blinking it should stop blinking and turn on then put the plug back in the wall
hope this works for ya =)
1helpful
Toshiba Satellite A200 -AH9 Wont Turn On.
maybe you have power conection problem
your problem maybe on the circuit after the battery
so you must check your circuit
or you can contact your Laptop manufucturers
Camera does not respond when turned on or when plugged in to recharge.
I followed the advice of my Fixya adviser--remove the battery for 3 minutes then plug the USB cable into a different port on my computer and plus in the camera. I did that and turned the camera on as advised but the green light still did not blink. The adviser did not respond when I asked what to do next so I disconnected the camera from the computer and plugged it into the charger. This time the first blue light started blinking (nothing happened when I tried it before following the Fixya advice). I left the camera to charge all night and eventually, after about 12 hours, it did.
Seems O.K. now.
We had thunder storms my tv 65613 has a green blinking light wont star
Good Day,mikeybecerra; TV wont come on mb try these 6 items, please pay attention to the blinking light (it's a code) : 1. Check for no 8.4 volts DC at pin 3 of PC9A10 on the Power PCB, if low or missing replace PC9A10 part # 268P058020. 2. LED does not blink at plug in. Check for 3.3-volts DC at connector RF pin 3 (system reset) if low or missing suspect the reset switch S7L20 part # 432P109010 on the Control PCB. 3. LED does not stop blinking after plug in. Verify the standby supplies, 12-volts at connector KA pin 17, 6-volts at KA pin 18 and the 28-volts at KA pin 19, if the supplies are present suspect the DM PCB part # 934C067001 4. LED does not stop blinking after plug in. Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM PCB, if they are bad replace them with part # 181P734030 (680 UFD 16 V). LED stops blinking after 70 seconds of plug in but will not power on. 5. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector RF pin 4 and 5 on the Signal PCB if low suspect problems with the switches/buttons on the Control PCB part # 935D736001 6. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector RF pin 4 and 5 check good suspect the E2P PCB part # 934C061001. Good Luck, big IRISH.
Computer wont start
replace your bios battery
Lg. screen tv mitsubishi HDTV 1080 SERIES INTEGRATED
i went to turn on the tv and the power button don't work
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
