Question about Microsoft Windows Vista Home Basic Edition
I had to reinstall Windows Vista. When I did so my computer lost a significant amount of volume output from both the speakers and the headphones. I have tried increasing the decibel output on the mp3 files themselves and that has not helped. Is there a way to increase the system volume in Windows Vista Home Basic beyond the 100 volume mark? (Without upgrading speakers or sound card). All volume is at 100 on speakers, mp3 player, headphones, and system volume. It is simply significantly softer volume than it was before the format. Thanks
  • 59 Answers
You can use Partition Assistant to extend your Windows Vista system volume. you can refert to this artilce:http://www.disk-partition.com/resource/free-partition-magic-for-windows7.html
Posted on Dec 11, 2012
  • 91 Answers
The format shouldn't have made a difference with the system volume? Try to Reboot PC, and when windows appear, hit F8 key constantly until you here a beep. You are now in the Repair/safe mode/system restore. This is where you need to perform the system restore. This should work..
Posted on May 17, 2009
Why is there no sound?
Kindly follow the below steps :
No sound in Windows Windows Help
it applies for Windows Vista, Win 7 and Win 8.
Jul 16, 2015 | Acer Aspire One D270-1865
I dont have sound in my pc.i dont know where to fix my problem
If you sue external speakers or headphones, follow these instructions. If you have a notebook computer & are using the onboard speakers, skip to the *Windows section below.
You can start by checking your speakers, if any. Make sure they are powered on and functional. You may also want to test there speakers on a different computer just to make sure.
If the speakers work on a different computer but YOURS still does not have sound, try a known-working set of headphones. Make sure the jack is seated correctly as it may be loose.
*Windows:
Check the volume controls on in Windows. If windows does not have any volume controls, then chances are, the sound drivers are not installed. Check your computer manual to find out what model it is, then visit the manufacturer's website to download the appropriate drivers and software for the sound card.
Note that if you have used external speakers or headphones anytime before this issue started, you may have to re-plug the device & unplug it again & allow Windows to detect that it's unplugged (for HD-capable audio devices in Windows Vista or 7).
If you do have HD audio in Windows Vista or 7, right-click on the volume control in the notification tray on the bottom-right corner of your screen and select "Playback devices"...
... then make sure you choose the appropriate output device (whatever it is that you actually use: Speakers, headphones, HDTV output, etc).
Aug 12, 2011 | Computers & Internet
My view sonic monitor has no sound
Troubleshooting Sound Issues Verify that the audio cable is connected to the AUDIO OUT or LINE OUT output on the Sound Card and plugged into the AUDIO IN or LINE IN of the Monitor.   Make sure there are no cables connected to the Headphone Jack (located next to the AUDIO IN port) on the monitor. If there is, please disconnect that cable and try the speakers again. Connecting a cable to the Headphone Jack disables the speakers. If there is no cable connected into the Headphone Jack, test a pair of headphones into that jack to see if you can hear sound out of the headphones. If you are able to hear sound out of the headphones, disconnect the headphones and try the speakers again.   Verify that the Mute on the monitor is not on or the Volume is not turned down.    Verify that the Mute on the computer is not on or the Volume is not turned down.<    If there is still no audio from the monitor's speakers, connect the Audio cable to another audio source like a portable CD player or tape player headphone output. If audio can be heard through the monitor's speakers, then there may be an issue with the computers sound card.    Connect another set of computer speakers (if available) or headphones to the AUDIO OUT or LINE OUT output on the Sound Card. If NO audio can be heard then there is an issue with the sound card. Verify with the computer's manufacturer for additional assistance.   LCD TVs Troubleshooting No Sound from a LCD TV No Sound when using RGB (when connected to a PC) Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the computer. Note: On the N1700W use the GREEN mini-jack; on this model Audio is SHARED between DVI and RGB, there is only 1 audio channel for data connections. The N1700w is designed to take a 1.0v RMS audio signal for optimal sound quality.   Confirm that both the LCD TV Mute and Windows Mute are off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the monitor or remote to confirm the Volume is not set to zero.   Confirm that PC volume is sufficient by using Windows/Macintosh Volume adjustment settings.   Try plugging another audio source such as a CD or Cassette Player directly into the Audio port on the LCD TV to confirm the speakers work, or try plugging headphones or external speakers into the sound card on the Computer. If the Headphones or External Speakers do not work, contact the manufacturer of your Computer for further support. No Sound when using S-Video/Composite/ Component Video Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the S-Video, Composite, or Component Video device.   Confirm Mute is off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the LCD TV or Remote to confirm the Volume is not set to zero.   Try plugging headphones or external speakers into the audio port on the S-Video, Composite, or Component Video device. If the Headphones or External Speakers do not work, contact the manufacturer of your S-Video, Composite, or Component Video device.   Note: Some ViewSonic monitors do not include speakers.
Nov 23, 2010 | ViewSonic E70f 17" CRT Monitor
I bought my rca headphones a long time ago and haven't used them in years. I was wondering, how do I hook them up to my computer. And what all I need to do to hook them to my computer.
Just plug the RCA Headphones Base Station into the headphone or speaker jack on the back of your computer (the headphone or speaker jack usually being green in color), and turn the volume up in Microsoft Windows to about 75%, then adjust the volume control on your headphones to a comfortable level. (p.s. even if you don't use Microsoft Windows, turn the volume up to about 75%, as most computer sound chips are very similar in their output level.)
Nov 13, 2009 | RCA WHP150C Consumer Headphones
Sir ihave c795tu laptap in this system only support vista but iam using windows xp.all fuctions are perfectly worked but headphones are connect the output of actual speakers are also coming
Double right click on the speaker icon in the taskbar tray. Then turn the speaker volume all the way down and adjust the headphone volume to the level you would like it. That way you will get sound coming rom the headphones only and not the speakers.
Nov 11, 2009 | Compaq Presario 700 470024-192 Notebook
I just moved my stepson's computer and I *think* I hooked up the speakers right. It is a 3pc Insignia speaker set with the floor sub. He had headphones plugged in before. We removed the headphons, and now...
If u have been supplied with a driver cd u  should probably try running the disc instead of sutomatic driver installation by vista.Or maybe u got the jacks mixed up.
check it out.
Mar 08, 2009 | Insignia 2.1 Speaker System (3-Piece)
Polk speakers with Windows Vista don't work
I doubt the speakers need a driver. Is there output from the soundcard? Connect the speakers to an alternate audio source, such as the headphone jack of a CD player or radio. If the
speakers produce sound, the problem is probably
with your soundcard. Recheck your soundcard
installation and setup procedure. Consult the sound
card’s manual. Check the “mute” and “volume” controls on your
soundcard or media player software and keyboard.
Are the speakers connected properly? Make sure the
plugs are securely connected in the proper location
according to their colorcoding and the diagram on th
front of this manual. Make sure the left speaker wire
with the white stripe is connected to the (+) speaker
terminal on the subwoofer.
Dec 03, 2008 | Polk Audio AMR50 Computer Speakers
Internal speakers - no sound
hii ther
how r u???
this model is not VERY compatable with vista even acer company say it is :D
but u can go to acer.com and see the teh latest update on ur driver for vista
don't just update the driver from teh windows wizerd update
u take care and havefun
salammmmmmmm {bye in arabic}
Nov 17, 2008 | Acer Aspire 5100 Notebook
Using headphones with Logitech X-230 speakers
I really don't know, because some of the newer gadgets come with fixed volume control due to law suits, ect. Try to see if you can bring you TV menu up and see what the sound setting is.
Dec 25, 2007 | Logitech X-230 Computer Speakers
Lost sound output
Computer Sound Card Help A sound card or audio board which allows computers to output audio signals through .... CH000208, Missing or lost sound in Windows 95 / 98 / ME / 2K / XP ...
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | Acer Aspire 5100-3357 Notebook
Microsoft Windows Vista Home Basic Edition Logo
75 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
