Question about Tascam Music
How to use a Tascam MTS-30 with TSR-8 Multitrack & a Midi Drum Machine ? does it it require hooking up to the 8th channel input on multi track as in a SMPTE device?
2 Suggested Answers
  • 10 Answers
SOURCE: Electronic drum kit, with USB out, problem
Sounds to me like you have the midi tracks outputting to the microsoft midi mapper or wavetable synth, which is built into the sound chip in your pc, and that this is conflicting with the mobilepre sound card - midi is just data, no audio, needs to drive some kind of synth. what you want to do is disable your internal sound card thru device manager, then just use the m-audio mobile pre as the input/output sound card in ASIO mode - you'll need to monitor via the headphone jack on the mobile pre or plug speakers into the line outs on the interface.
Then do tutorial 8 (in help files) on using soft synths - INSERT>SOFTSYNTHs creates a midi track and an audio track in a track folder.
Good luck.
The dude.
Posted on Aug 07, 2008
I am trying to connect my Korg M1 via my presonus interface into my Studio One program. HOw do I get connected after MIDI cables are hooked up?
Hope i did not miss understood...
If MIDI is hooked up there are only the audio signals left to connect...
Try to connect the audio outputs from the M1 to the DI´s of the interface via instrument line cables and routing them to/in your software...then set up midi channels for one instrument track that triggers the M1 and activate an audio track to record/monitor your incoming M1 audio signal
Mar 15, 2018 | Korg Music
Tascam 2488 neo mmc control
That seems to be in the midi time sync functions. In cakewalk under options find the midi settings and choose midi device. All of you clock and sync settings should be there. Also I think under the audio menu there are settings for folders and I think a tab for sync is there as well. I use Sonar, which is an upgrade of cakewalk but used cakewalk for a long time. I have it on another computer and will look later to see if I am forgetting something or remembered it wrong and let you know.
Mar 14, 2013 | Tascam 2488NEO 24 TRACK RECORDING...
Best way to connect two electronic drum modules together
use one MIDI cable connected to MIDI Thru jack
Jun 17, 2012 | Roland Music
I have the yamaha dtexpress and a midifase conect but cant get anny sound to the computer??????????????
try a midi loopback device or a viruual midi cable such as sonys virtual midi cable: http://www.johnrofrano.com/tutorials/virtualmidirouter.htm
i dont know if this one will work, you could also search for loopb1 and hubi's midi loopback device, one of these should work.
what you have to do is use one of these programs, or something similar, to connect your midi input to the soundcard's midi wavetable or to your midi/synth/sequencing software's midi input.
also, the drum machine should be set to output to midi channel 10. make sure that your software is set to recieve on midi channel 10, if applicable.
Nov 29, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
My problem is that I have an xr-20 an was wondering what would be the best "bang for my Buck" when it comes to a music program to make the beats transferable to CD at CD quality I'm trying to start slow...
If you are looking for a straight audio solution Audacity is free and you can do lots with it. I was looking for recording software and got Reaper myself. It is a multitrack audio and midi recording program. It is free to try out and around $70.00 for the licence. One example is if you have a midi to usb adapter you can output midi from your XR-20 through the adapter into your computer into a channel on Reaper, record it as a track and work with it after that. You can edit it as midi or you can also record the audio from the XR-20 onto a track. With VSTi there are free synths on the Internet that you can use as FX for the track and run them using the midi track that you recorded. You can also run sample players that way. Here are some useful links:http://audacity.sourceforge.net/ also http://www.reaper.fm/ In case you don't understand midi or recording here is another link to a site I highly recommend:http://recordingreview.com/ ( It is listed as an attack site but I can vouch for the owner that it is absolutely not.) I downloaded the free Killer Home Recording Setting Up pdf and it is a wealth of free info. This site also has detailed explanations of Midi etc. I am a member of the forum(It is free to join as are the forums at the other sites I recommended). Joining forums is also a great way to meet users of the same gear as you. They are usually quite willing to help you as they have all been using that gear.
Aug 23, 2010 | Music
Can't get Casio CTK 601 / 611 to function as MIDI Contrller
I'm not at home right now where all my manuals are so I'll try to explain with out. You will have to set it so that the keyboard is the slave device. Try setting it to Omni receive. It has to be able to listen for all midi channels at once. You have to write a sequence on your computer and hook it to your keyboard by using midi out on the computer to midi in on the keyboard in order for you to use the computer as a controller. If you need the keyboard to create the sequences then you have to hook the midi send on the keyboard to the midi in on the computer play/enter your notes into individual tracks in your software then assign channels, voices etc to each track and save the sequence. Then when you hook it up the other way the sequence will play just like an audio recording except the sound w2on't be there. What you have recorded by creating a sequence is a series of midi messages that the keyboard will receive if you have it set properly and hooked up ptroperly which it will translate into sound. This is a minimalist explanation at best. You will have to have a better understanding of not only your keyboard but also your software and midi in general. There are some pretty amazing things you can do with midi. For instance if you have a lighting controller that is midi capable you can i,mbed all the lighting scene changes for your song in order on one track. You can also control your guitar effects pedal to change effects automatically while your playing. Once you get a handle on it you are only limited by your imagination and your budget. Hope this helps in some way.
Jun 01, 2009 | Music
Control midi program sampletude
The Tascam has no midi In,Out or Thru so the answer is No.
Apr 21, 2009 | Tascam 2488mkii 24 Track Recording...
Is the Boss Dr-5 compatable with the Boss BR-1180 mini studio?
Midi doesn't actually "make sound". If your trying to record the patterns you made on the DR-5 to the recorder you need to use an audio output(I don't remember if they are RCA or 1/4" on the DR-5.) The midi output would be used to"trigger sounds" in another device that has sounds built in, or you could also trigger sounds in a program that supports midi input.
Mar 03, 2009 | Boss Micro BR Digital Recorder
Good luck.
The dude.
Aug 07, 2008 | Yamaha Dtxpress Iv Special Electronic Drum...
Music Logo
337 people viewed this question
Top Tascam Music Experts
Michial Gueffroy
Computer Links
drivealot
Are you a Tascam Music Expert? Answer questions, earn points and help others
