Question about Samsung LE32R73BD 32 in. HD-Ready LCD Television
Surface scratches to LCD screen
I have come home from work to find a series of surface scratches on my LCD  screen....just deep enough to be felt with a fingernail being lightly brushed over them, but at the same time, very visible when the TV is off (ie screen is black).
Because I know they are there, I can also see one or two of them when the background is white (TV on).
I have googled for help to remove them and have come across the "white eraser" method or "petroleum jelly" application.
Have done neither as yet, would appreciate your help and advice please?
Kind Regards
Ive tried the vaseline method (petroleum jelly) and you must be sure not to apply too much on the screen or else it will smudge around the scratch and it is hard to buff out, but if you fill the scratch in and wipe off the excess around it, then it should be barely visible.
Posted on Jan 10, 2008
Tip
Best way to Fix Scratches on Your Radiant Smooth top Cooktop
Cooktops are in many homes and are a preferred kitchen appliance to many home owners. The Cook in the kitchen can appreciate the stylish look of a sleek radiant smooth top Cooktop . Many invest top dollar to have stainless steel appliances including the following: Refrigerator, Dishwasher and Compactor. Moreover, having a sharp looking Cooktop addition only compliments the style and design of any high end kitchen. Maintainence and care of such an essential attractive appliance such as a cooktop is important.
Here is the best way to fix scratches on your Radiant Smooth top Cooktop:
Step 1 - Prepare your Cooktop by cleaning the surface*Make sure the surface is cooled* Use a damp rag first and sweep of crumbs and food stuff. Use your favorite cleaner and rinse completely. Careful not to get moisture around knobs or switches. Dry off surface.
Step 2 -- Work on the scratch area
Run the sharp edge of a razor over the scratch around 3x and this will aid in smoothing out any raised ruff edges. Apply gentle pressure to the cooktop scratch area.
Step 3 - Apply A Cooktop Cleaner
Use a few drops of cooktop cleaner to the scratch area. Use a sponge to rub in cleaner. Use circular motions to allow scratch to absorb product. Run the razor edge over scratch again making sure not to apply to much pressure.
Step 4 -- Clean Cooktop surface again and remove cleaning product
Rise off cleaner and dry with a dry paper towel. Inspect scratch to test results. Repeat step 3 until you have desired results.
Special Note* Their are many ceramic cleaning products to choose from and many claim to be the best on the market. Be sure to choose one that has good reviews and then test the results. Special attention must be given to all radiant smooth top cooktops. Be sure to use only cookware that is recommend by the manufacturer. And be sure to clean spills as soon the cooktop is cooled to keep the appliance looking well. Deep scratches or pits cannot be removed or buffed out and may lead to a cracked cooktop.
on Dec 16, 2010 | Kenmore Elite 44173 30 in. Electric...
My flat screen is scratched how can I fix it
It is very difficult to polish the scratches out. If you apply too much pressure to the surface of the screen you will crack the glass surface and the LCD element, and you will then need to replace the LCD screen.
Oct 21, 2009 | Computers & Internet
MY 3 YEAR OLD DAUGHTER HAS JUST SCRATCHED MY SONY BRAVIA TV WITH A MAGNA DOODLE PEN. HOW CAN I GET RID OF THE SCRATCHES?
Clean the surface of the LCD screen with a barely damp cloth.
  • Step 2 Dry the screen with a soft, clean cloth.
  • Step 3 Rub a generous amount of petroleum jelly into the scratch using a cotton swab. The petroleum jelly should fill in the scratch and remain there.
  • Step 4 Immediately wipe the excess petroleum jelly off of the screen with a soft cloth being careful to leave some petroleum jelly inside the scratch to act as a patch or filler.
  • This scratch repair method is effective because of optical density. The optical density of petroleum jelly matches the plastic, LCD screen coating more closely than that of air.
  • To avoid future scratches or gouges, you might consider purchasing a LCD screen protector. These screen protectors are generally made of a thin, plastic film and affix to the screen without adhesives. Not only can they protect against scratches, but they also keep the screen free of dirt, oil and dust while simultaneously reducing glare.
  • When wiping the screen as described Step 4, avoid pressing too hard or you will inadvertently remove the petroleum jelly from inside the scratch.
  • Using petroleum jelly to fill a scratch on your LCD screen could void your screen's warranty. If you are concerned about warranty issues, consult your user's manual for more information.
  • Sep 16, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
    Sony hc-32 touch screen won't work
    When touch switches become nonworking then mostly its cause of connecting flexible ribbon wires between LCD board and camcorder main board that got cracked so touch buttons signal does not go to camcorder system control. Need to replace that flexible wire by qualified camera tech.
    Very rare cases I found touch buttons layer that is pasted and part of LCD becomes defective, do you see hard or deep scratch on LCD surface? if yes, then LCD screen will be replaced because touch button array is damaged.
    Thanks.
    Sep 16, 2009 | Sony DCR-HC32E DV Digital Camcorder
    Scratch on plasma screen
    You should be able to make the scratch become invisible using a white eraser. A pink one will work, but the white one works better. Just simply erase the scratch, it may take awhile, but your basically buffing the surface down even again making the scratch un-noticeable.
    Jun 21, 2009 | Panasonic TC-P50S1 50 in. Plasma LCD HDTV
    How do I fix a deep scratch on the screen, it is a wide scratch,maybe like a small toothpik size, when black background is on, it shows as a white scratch, I have tried vasoline, but it does not fill in...
    Unfortunately there isn't anything you can do. The LCD surface itself has been physically damaged and no longer works properly. This isn't simply a scratch. The only solution is to replace the display panel, and they are nearly impossible to find unless you are an authorized servicer working on a warranty repair. There are companies that sell parts removed from sets, but most sets are junked because of bad displays. Since the display is the single most expensive part, if you can find one it may not cost much more just to replace the TV. There's always a sale going on somewhere, and many online vendors as well.
    Jun 10, 2009 | Emerson LC320EM9 32 in. LCD HDTV
    Surface scratches in my black bathroom sinks
    You might try a vehicle buffer on them. If that doesn't work you will probably have to use a porcelain touch up kit that can be bought at your local hardware store.
    Mar 29, 2009 | Home
    Scratches / cuts in play surface
    ok this Is A Very Very Easy Fix all you need is either carpenter putty or mighty putty and you fill the cracks and sand it down. therefore creating a smooth surface and if you want put gloss to make it slick.
    Feb 08, 2009 | Harvard Xh 7000 Hockey Table
    My plasma tv has several really deep scratches on the screen, how can i go about repairing this?
    There are liquid solutions for filling LCD scratches
    it's basically a plastic material that fills the scratch.
    Big scratches are more of a problem. I am assuming that your
    Plasma screen has a glass surface and that it's only scratched,
    not physically broken. You may also try glass polishing compounds
    for filling and polishing chipped windshields. Be careful, try it on a small spot first to make sure that you don't dissolve any plastic anti-reflection coatings etc.
    Good luck
    Apr 18, 2008 | Computers & Internet
    Samsung LE32R73BD 32 in. HD-Ready LCD Television Logo
    290 people viewed this question
    Jerry Greenberg
    Jerry Greenberg
