Question about Samsung RF265AA Bottom Freezer French Door Refrigerator
Samsung RFG297AA Thin Film of Ice Forming Under Deli Drawer
Samsung RFG297AA french door fridge has a thin layer of ice forming underneath the "pantry" (deli) drawer. The temp setting for the drawer is "chill". I have had this unit since 09/08. This situation just started occurring. I cleared the ice and it re-accumulated within 48 hours. I do not see any other signs of water/ice.
What could be the culprit? Any advice and insight is greatly appreciated!
    Master:
  • 585 Answers
My be an air leak,wipe/check all seals on doors and make sure doors are closing tight on seals.
Posted on Jul 24, 2017
SOURCE: deli drawer
Dear Master Tech: The model number is GLRT13TEB3. The problem is every time you try to open the deli drawer it falls straight down.
It is as if the tracks to hold it are too far apart? Also the tracks are part of the glass shelf.
Any help with this annoying problem would be much appreciated.
Thank-you, Nanc T.
Posted on Feb 17, 2008
SOURCE: I would like to order
repairclinic.com
Posted on Aug 02, 2008
  • 531 Answers
SOURCE: Food in Chef's Pantry drawer freezes, even on warmest setting
check the cold control or the door is not closing proper
Posted on Apr 01, 2009
SOURCE: samsung refrigerator freezer not freezing
I just returned the same fridge to Lowe's where I bought it using the warranty for the same problem. The temperature sensors went out, and everyone said the computer board needed to be replaced but no one could seem to get it together enough to order us one. Month later we are getting a new fridge.
Posted on Jul 28, 2009
  • 4793 Answers
SOURCE: water build up underneath deli tray drawer
clean drain hole regularly....
Posted on Feb 09, 2010
Why does ice keep forming in the bottom of the refrigerator
If you are referring to ice forming on the floor of the freezer, it's a result of a blocked defrost drain. Contact Maytag to send out an authorized service company to make repairs. There is a drain kit that is installed at no cost to you.
Sep 19, 2014 | Samsung RF265AA Bottom Freezer French Door...
Why is there ice in the bottom of the crisper?
Freezer /fridge water/ice in fridge
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Sep 07, 2014 | Samsung RF217ABPN Bottom Freezer French...
Ice under the deli drawer
it could be that u have a leak.. sometimes this happens when to much water is delivered to the ice tray and it overflows a little leaking into fridge. if that is happening then u most likely have a problem with the water inlet valve at the back of fridge, u can buy the part on line at appliancepros.com. good luck
Apr 13, 2014 | GE Refrigerators
Ice is forming under the freezer drawer what causes this
Clean your coils. Then defrost ice build up with a hair dryer. Good luck!
Apr 12, 2013 | Maytag MFI2568AES Stainless Steel Bottom...
Kfcs22evms ice under freezer door and water leaks out onto floor
Check for a clogged drain line at he bottom rear.
Oct 30, 2017 | Refrigerators
My Bottom freezer refrigerator with ice maker has ice built up and a thin layer of ice covers the base under the drawer. Could the tip of the pipe that fills the ice mold have frozen creating preassure and...
there should be a drain at the bottom under drawer. I suspect that it is obstructed. When unit goes into defrost mode ice melts and refrezzes due to obstruction
Sep 29, 2009 | LG LFX25960ST Stainless Steel French Door...
Leaking fridge
my maytag had cloged defrost drain cleaned drain all ok
Oct 28, 2007 | Refrigerators
Samsung RF265AA Bottom Freezer French Door Refrigerator Logo
718 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
