Question about Canon Office Equipment & Supplies
Canon copier - switching between default setting
Copiers come with default settings. But usually to make copies of different sizes with different orientation, a temporary settings is made, to suite the need.
This temporary setting automatically resets itself to default setting, if the mechine is left idle for 2 minutes.
Can this be made manual or can the idle time be increased to 10 minutes or above. ??? if yes - how ???
can any body help me with this - ??
  • 149 Answers
You can usually adjust the timer settings via the additional functions screen and select 'timer settings' and within there you can set 'return to standby timer' this will help you. The way to access this mode varies from machine to machine but if you have a key with a head and a star inside it, that will get you into the additional functions screen.
Posted on Jul 06, 2009
  • Jay Otaigbe
    Jay Otaigbe Jul 07, 2009
    Sorry, correction, the setting you need is called 'change auto clear time' and you can set 0-9. '0' leaves the auto clear off and 1-9 is the number of minutes before it auto clears. If you leave it off just press the reset key to clear manually. Just take heed that this will now retain any settings of the previous user including tray designation and special features!
It give messages like wrong paper size why
go into settings and adjust to the paper size in use--normally a4
Mar 28, 2015 | Canon Imagerunner 1600 Copier. 16 Pages...
If I want to copy & paste from the internet my Canon Pixma MG3200 only prints the size of a postage stamp on A4. It used to be OK. What's wrong with my settings?
Default setting on printer itself must be set to passport photo size if from a computer go to devices and printers and look at printing preferences check paper size
Jan 08, 2015 | Canon Office Equipment & Supplies
I want to reset my ir 2318 canon printer to factory settings
Ok my what you need to do is first go into service mode by pressing asterisk key(*) on control panel and then press2& 8 simultaneously on numeric key pad and press asterisk key again.Other screen will appear with following main screen: copier.sorter,feeder,etc.Go copier another screen will appear go to function touch it then go to clear all then switch off machine then on again.In this way you will have cleared them ram then do paper size registration by going to CST intermediate screan put different sizes of paper in the ADF one at time keep pressing ok for each size selected.After you are through exit service mode by switching off machine.
Jul 25, 2012 | Office Equipment & Supplies
Paper keeps jamming
I would look to see if the paper tray's Dials are set to the correct paper size as the paper in the paper tray.. LTR size set to LTR or LTR-R set to LTR-R if the dial is set to the wrong size the copier will jam all the time. Due to a timing issue, the copier thinks it has one size, but actually is try to make a copy on different size... Good Luck
Jun 08, 2012 | Canon imageRunner C3100N Copier
When I attempt to copy a document-8in. X 11in- and have the copy menu set to -"original size auto detect,the printer persistently prints a smaller document size,usually 4" X 5". I have...
Try to reset your Lexmark X4650 settings to factory defaults. On the printer operator panel, press Setup -> select Defaults -> select Set Default -> select Use Factory -> press OK. Then try to make a copy again.
I hope this information has been helpful. Thanks.
Jan 06, 2011 | Lexmark X4690 Wireless InkJet Printer
We have 2 Canon ImageRunner 3320N copiers, but they are behaving differently when they are being used as a scanner. On one copier, when scanning a double sided paper it will automatically scan each side....
it is in the copier settings. one is actually set up to automaticly do doublesided copies as a default. while the other one is only set up to do singlesided copies
first while on the main copy screen change the setting how you want the copier setup ..... double sided printing, black and white, or how ever you want your defaults to be set up
then you will need to goto the additional functions button and under copy settings you will need scroll down to the second page.
there you will want to hit the standard setting button then click the store button, then click yes... now it will default to the double sided copies.....
hopefully this will fix the problem if not get back to me
Jun 18, 2010 | Canon ImageRunner 3320N Copier
It keeps defaulting to the copy function
all copiers by default go to copy, this can be set usually in operator/user parameters
Mar 17, 2010 | Canon ImageRUNNER 1670F Copier
How do i set paper sizes on my canon ir2016i printer
Open the paper drawer
Remove the paper
There is a blue paper size plate,that keep the paper in the correct posision,Push it to the front and downwarts.The paper plate should come loose from the tray.Put it back in the openning for the A4.The openning for the A4 papersize is mark inside the paper tray.
Now set the blue papersize dail to A4 paper .
Then you are ready to copy with A4 paper.
Feb 19, 2009 | Canon iR 2016i Black and White Copier
HP6110 default paper size for copying
Yes, manually set your paper size using A4 or begin with A4 and leave it on auto (default) it will try and match it.
Instructions...
  • Press Menu
  • Option 1
  • Option 2
  • Select copy Setup
  • Select paper size
  • Hit the black triangle until the size you want displays
  • Then hit enter.
Dec 08, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Copyer problem
Go to the Control Panel, open Printers and Faxes, right click on the icon for your Canon, choose Properties.
Since the offered settings can differ from one model to another, you may have to look at any tabs shown to find the default setting for paper type but it will probably be under 'Advanced.' Check through the various settings and you should find settings influencing which paper size the printer should use and expect.
Oct 18, 2008 | Canon PIXMA MP150 All-In-One InkJet...
116 people viewed this question
old marine
old marine
