Question about Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television
Power 5 time blinks
I have a panasonic PT-47WX54 with a blinking red power light. it blinks 5 times....what exactly does that error code mean? & how can I fix.
  • 50 Answers
The blinking code means something is wrong with some components.
It is usually caused by over heating compenents.
Remove the back panel and blow out all the dust using compressed air.
Then vacuum.
Posted on Mar 10, 2010
What causes my Panasonic HDTV model PT-60LCX64 to start flashing green then red however never powers on.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Aug 24, 2017 | Panasonic Televison & Video
I have panasonic hdtv pt-59cl14 wont turn on when push power button the lamp light blinks red then the power button flashes yellow/orange 8 times then repeats . Any suggestions
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Dec 09, 2015 | Panasonic Televison & Video
Why does power light comes on but blinks tv dont come on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jul 30, 2014 | Panasonic PT-50LC13 Television
How to repair HDTV 50 inch TV red light stay on an blink model number is pt-47wx34j how to fix
The set has two common error codes: watch the red light blinking and count the sequence-----3 blinks is most common and is short protection--that one is fairly easy to fix---second most common is 5 blinks which means a short on the 140 volt line--that one is more complex to fix.
Which or neither?
Jun 06, 2012 | Panasonic Televison & Video
The red "on" light is blinking and the TV
a suggestion: unplug set and try to turn on again; if power light blinks does it blink in a sequence?
3 blinks repeated will mean a problem in the Convergence area.
5 blinks repeated will mean a short on the 140 volt line.
These are the two most common error codes.
SD TECH
Aug 31, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Tv will not turn on. red light on front of tv next to on/off button blinks
COUNT THE BLINKS.
3 BLINKS AND A PAUSE AND 3 BLINKS IS MOST COMMON.
5 BLINKS AND A PAUSE AND 5 BLINKS IS ALSO COMMON.
let me know the error code (blinks) and I will tell you what it means.
SD TECH
Jun 10, 2010 | Panasonic PT-53WX42 53" Rear Projection...
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Power - Red light
You need to open the TV and use compressed air to blow out all the dust from the components.
May 17, 2009 | Panasonic PT-50DL54 50" Rear Projection...
The tv wont turn on
hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
Dec 14, 2008 | Panasonic PT-44LCX65 Television
Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television Logo
433 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
