Question about Apple iPod nano
Scroll Wheel Won't Work-I Did Reset&Upgrade - Apple iPod nano
  • 3 more comments
  • Anonymous Nov 02, 2007
    my i-pod naneo's scroll wheel wont work.
    i've left it off for a couple weeks now, it works for about 5 mins they the scroller will stop working.
    Help?
  • Anonymous Nov 12, 2007
    I have tried resetting it by pushing the select and menu button. I still can't get the wheel click to work. What to do?/
  • Anonymous Jul 12, 2008
    my ipod nano wheel does not work, does anyone know how to fix this?
  • lexjo Sep 27, 2008
    i just bought this ipod two days ago and the scroll wheel wont move what do i do and it wont reset
  • Anonymous Oct 17, 2008
    same w/ this pos
  • 515 Answers
If reseting and upgrading do not work, you might have physical damaged. There are tiny little ribbon cables inside the unit, which are about the width of a hair strand, and damage very easily when pressed too hard - which is something everyone does the first time that scroll wheel doesn't work. There really isn't much you can do, other than getting it repaired.
Jsut make sure you tried to install the correct updater file first - LOCATED HERE - although it should not affect the scroll wheel - however, you it doesn't hurt to try!
Hope This Helps!
- TWEAK A/V LAB
Posted on Nov 10, 2007
Scrolling problem
your scroll wheel is most likely of track
Jul 14, 2013 | Dynex Wireless Optical Mouse
Tip
How to reset Canon MP600 printer to the factory settings?
1. Press the HOME button.2. Use the Easy-Scroll Wheel or the right / left arrow to select [Settings], then press the button.
3. Use the Easy-Scroll Wheel or the right / left arrow to select [Device settings], then press the button.
4. Use the Easy-Scroll Wheel (B) or the up / down arrow to select [Reset settings], then press the button.
5. Use the Easy-Scroll wheel or the up / down arrow to select [Yes] on the confirmation screen and then press .
6. Press the button to return to the HOME menu.
This will help.Good Luck
on Mar 10, 2010 | Office Equipment & Supplies
What I'm trying to scroll, won't scroll as fast as I want it to.
If you click the start menu, then click control panel, and select mouse, you will get a pop up window, one of the tabs at the top of this window is 'wheel' there you will see an option to change the number of lines the wheel will scroll with each notch
hope this helps.
May 30, 2011 | Logitech Cordless Mouse
Before a recent upgrade to explorer 9 there was displayed a butron in the lower right of the screen which alowed and easy change in the font size after the upgrade the button is gone and all font is very...
Try holding Control and using the scroll wheel on the mouse.
If you don't have a scroll wheel on the mouse, try CTRL + to increase font size and CTRL - to decrease.
Mar 18, 2011 | Microsoft Windows 7 Professional Upgrade...
Reset to factory settings blackberry curve
Whether you are ready to upgrade your blackberry, give it to someone else or throw it out all together, you should make sure that any personal data has been removed first. Here's an easy way to ensure that you are not throwing out, giving away, or selling a phone with your data still on it.
  • 1
    From your blackberry, scroll down to the options icon. (This is the icon shaped like a wrench) Push in the trackball or the scroll wheel to select this.
  • 2
    Once you are in the options menu, scroll down to the security option and press in the trackball or scroll wheel to enter into the security options menu.
  • 3
    Once in the security options menu, locate the general settings option and press in the trackball or scroll wheel to enter the general settings menu.
  • 4
    Great! Now you should be in the General Settings menu. At this point you can press the menu button on the blackberry. Its the button next to the green phone button. Once you press the menu button on the blackberry, you will see a menu come up. scroll to the "Wipe Handheld" option and press in the trackbacll or scroll wheel to confirm your selection. There will also be an option to remove all 3rd party applications. Check this option to remove those as well.
  • Oct 02, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
    Install the correct print head
    You can clear the errors in your printer in three reset procedures.
    Reset it manually
    1. Turn off the printer
    2. Press and hold the Resume Button, an indicator light green
    3. Press and hold the Power button
    4. While holding the Power button, release the Resume button
    5. While holding the Power button, press the Resume button twice
    6. Release the Power button
    7. Press the Resume buttons four times
    8. Press the Power button to confirm the operation
    9. Turn off the printer
    Reset canon mp600 to factory setting (if the first procedure did not work)
    1. Press the Home button
    2. Use the Easy-Scroll Wheel or the right/left arrow to select Settings, and then press OK button.
    3. Use the Easy-Scroll Wheel or the right/left arrow to select Device settings, then press OK button.
    4. Use the Easy-Scroll Wheel (B) or the up/down arrow to select Reset Settings, then press the OK button.
    5. Use the Easy-Scroll Wheel or the up/down arrow to select Yes on the confirmation screen and then press OK
    6. Press the HOME button to return to the Home Menu
    Final reset (If errors did not clear and or another error appears this will clear it)
    1. Press and Hold the Resume button and wait until the printer self restart.
    2. Release the Resume button when the printer restart
    3. Wait until the printer fully initialize and try printing again.
    That will solve it.
    Please comeback and give some ratings.
    thank you for using Fixya.
    Aug 18, 2010 | Canon PIXMA MP600 all-In-One InkJet...
    Ipod nano 8GB doesn`t work
    Hold down the middle button and the top of the scroll wheel until you see the apple symbol. Keep holding the middle button then hold down the bottom of the scroll wheel. This will reset the iPod so that it will work. If the scroll wheel is still not working, take it to the place you purchased it or if it is in the area, find a local Apple Store and take it to them. They will be able to assist as well.
    Oct 27, 2009 | Apple iPod nano
    How do i reset my 7520
    ok i think this is how you do it ok you go to options on the homescreen then scroll to security options click on general settings and then click the track wheel once scroll down to master radio reset and if thats not it try all the same process but when you get to general setting setting click the track wheel and scroll to wipe handheld one should work good luck
    Jun 25, 2008 | RIM BlackBerry 7520 Handheld
    Scroll wheel not working
    Make sure the hold button is not pressed. If it is not in hold or lock position, then reset the player. If that fails your only two software options left are firmware upgrade (Creative website) and recovery - Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
    If these fail, the player must be replaced.
    -Tha Mp3 Doctor
    May 06, 2008 | Creative Labs ZEN V Plus MP3 Player
    Scroll Wheel does not work with some programs.
    If you set the mouse wheel to one page at a time for the scroll wheel and install the FF add-on SmoothWheel the scroll wheel will work fine, you can even use the FF add-on to change the scroll amount even more (with the SmoothWheel add-on install in FF the "one page at a time" isn't really one page it goes by the add-ons rules, which is 1/7's page.
    Feb 18, 2007 | HP (P2353AA) Mouse
    Apple iPod nano Logo
    3,531 people viewed this question
    Top Apple Audio Players & Recorders Experts
    Nagendra Baliga
    Mohamed Ismail
    Mohamed Ismail
    woodzowl307
    Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
