Question about Sylvania SA210 15 Amp Zip-Set Digital Outdoor Timer with Three Outlets
How do i set the timer on a sylvania sa210 timer?
How do I set the timer (on/off) for this timer?
2 Suggested Answers
  • 10865 Answers
SOURCE: need instruction sheet
Your unit has a lifetime warranty. Go to this website to get the instructions in PDF format:
http://www.hardwareinnovations.com/pdf/SA_210_IB61056_33.pdf GOODLUCK
SA 210 Zip Set Outdoor Digital Timer with 3 Outlets features a Zip-Set One-Step Set-up where you simply enter your area code and the timer is programmed. Your lights will automatically turn on at sunset, and auto-adjust for seasonal time changes. Other features include a random setting for added security, a 7-5-2 setting for full weeks, weekdays, or weekends. Battery back-up (batteries included) to save resetting time in the event of a power failure. It has 2 timed outlets, plus 1 extra untimed outlet for use with other products. It has an easy-to-read, large illuminated digital display, and 15 amp capacity. Lifetime warranty.
Product Description
Zip-Set™ Technology with One-Step™ Set-Up Two Timed Outlets + 1 Untimed Outlet Controls three Products Simultaneously Controls Outdoor Landscape, Security and Holiday Lighting, Pool/Spa Pumps and Engine Block Heaters Optional 4 On / 4 Off Settings Random Settings for Added Security 7-5-2 Feature allows you to set times based on the 7 Day full week, 5 Day work week, or 2 Day weekend Large Illuminated Easy-to-Read LCD Display & Keypad Battery Back-Up (battery included) saves resetting time in the event of a power failure Weatherproof 15 Amps Lifetime Warranty
Posted on Jan 23, 2009
Manuals
Copy following link for product manuals:
http://waterheatertimer.org/Sylvania-timers-and-manuals.html#SA210
Reset button appears to be small round button located below the 3 rows of other buttons
Jul 06, 2013 | Sylvania SA210 15 Amp Zip-Set Digital...
Timer is programed & is currently in off state but my stuff is still on
Specifically which timer do you have??
1) Reset timer to Clear programming, and then reprogram being careful to avoid overlaps and conflicts that can cause timer not operate as expected.
2) Move timer to different outlet.
3) Test outlet with circuit analyzer
4) Try plugging different load into timer. For example a light bulb instead of pump.
5) Check rating plate on timer and on pump to see if they are compatible.
For example Sylvania SA-210 outdoor timer is rated for 1/4 Hp at 120Volts
While Intermatic P1261 timer is rated for 2 Hp at 120volts
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#outdoor
Jul 17, 2012 | Sylvania SA210 15 Amp Zip-Set Digital...
On sa 210, when timer off (either from program or manually switched off) correct "bulb off" status is displayed on the indicator, but the power doesn't go off from the outlets. this problem...
Most digital timers can be restored by resetting timer and then reprogramming.
http://waterheatertimer.org/pdf/Sylvania-SA-210-Manual.pdf
Sylvania tech support: 888-548-4484
Sylvania timer has 1 year limited warranty.
Sylvania timer can be used for 1000W incandescent Loads and Motor loads up to 1/4Hp
All outdoor timers are susceptible to power surge from nearby lightning.
Timers are also affected by line noise and incorrect outlet polarity.
Test outlet with circuit analyzer. Use timer to control different Load on different outlet.
If more than one timer has same problem, then suspect can be line noise and outlet polarity.
Heavier-duty Intermatic HB8800RCL timer has limited lifetime warranty, and controls 1800 watts and 1/3 HP.
http://www.amazon.com/Intermatic-HB800RCL-Seven-Outdoor-Digital/dp/B001KBZUNK/ref=pd_cp_hi_2
Aug 05, 2011 | Sylvania SA210 15 Amp Zip-Set Digital...
Cant set my sylvania outdoor timer, says hit zip set and enter zipcode.i can only get 3 numbers in
Open following link for Sylvania timers.
3 numbers is correct.
77482 and 77468 will be inside same time zone.
So set 3 digits 774 and timer knows where you are astronomically.
The timer does not need your full mailing address zip.
Press red reset button.
Press mode button until ZIP icon displays.
Depress and HOLD clear zip-set button until display flashes.
Set first 3 area code numbers.
If zip set is not working correctly, then timer is defective.
Add a comment for more free help
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 01, 2011 | Zip Heaters Sylvania SA220 15 Amp Zip Set...
Need instruction sheet
Product Description
Dec 22, 2008 | Sylvania Hardware & Accessories
Sylvania SA210 15 Amp Zip-Set Digital Outdoor Timer with Three Outlets Logo
287 people viewed this question
Top Sylvania Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Sylvania Hardware and Accessory Expert? Answer questions, earn points and help others
