Question about ASUS M3A78 Pro AMD 780G AM2+/AM2 Phenom FX/Phenom/Athlon /Sempron Socket AM2/AM2+ 5200 MHz PC2-8500 ... Motherboard
Upgraded cpu to phenom II X3 720 and ram gskill DDR-1066 2Gb sticks (2) on a asus m3a78 pro. everything comes on w/ pwr but, k/b mouseand moniter not working. asus claims this board is am3 compatible.
    Brigadier General:
  • 3,917 Answers
TRY TO INPUT TO THE BIOS AND CHECK VEDIO CARD FROM THERE
OR CHANGE THE PLACE OF THE MEMORY IN ANOTHER SLOT . the problem lies with the memory card my dear and I am pretty sure about this. Try changing the RAM or claim for warranty. I would have told you to use the eraser trick but I believe that this memory card is faulty and even if it works after using the eraser to remove the presence of static energy, you will not be able to use it for long
If you are using the round plugs (PS1) then mouse and keyboard sockets are different, probably keyboard socket is broken.
If you are using usb, and mouse works on same usb port, then keyboard is faulty , even if it works on a different PC, probably a faulty contact inside.
A keyboard is an inespensive part , better buy a new one.
Thank You
Posted on May 17, 2009
Lost a program after removing a RAM memory stick. How to restore it?
If the program was hard written to your hard disk drive then the chances of it "vanishing" after you remove a ram module is practically nil. I've seen weird thing like this happen before so Id probably start by scanning your system for virus's , spy/mal ware etc if you download a lot of free junk from the web. Was there a reason you removed the ram module in the first place?
Nov 24, 2013 | ASUS M3A78-EM AMD 780G Socket AM2+...
MB keeps beeping 1 long beep no boot.
Hello try to download the manual:
http://support.asus.com/download.aspx?SLanguage=en&p=1&s=4&m=CUSI-M&os=&hashedid=n/a
Select windows xp and open the manual folder
Click on global for download.
Unzip the file and you need adobe reader to read the content.
Here is a list of beep codes:
http://www.computerhope.com/beep.htm
This mainboard uses SD ram and it sounds like a ram problem.
If there is room for a ddr ram block you can`t use SD ram and DDR ram simultaneously.
Try to insert the old cpu again and upgrade the bios to support a bigger cpu. Not all cpu is supported.
Good luck
Dec 22, 2012 | ASUS SiS Chipset CUSI-M Motherboard
AMD Phenom-II is installed in Asus M4A78LT-MLE motherboard. While system is booting showing error message -" This CPU is not supported by this model. Please check CPU QVL on Asus website" Please...
the only phenom-II cpu's it supports are the 545 and 550 socket am3 1.01ghz. if you have anything other it will not run. here is complete cpu support list here
Nov 04, 2010 | ASUS M4A78LTM LE Motherboard
Amd processor upgrade
The M3N78-em mobo doesn't support AM3 processors. It is an AM2 / AM2+ platform. A wonderful GPU for you would be this. http://www.newegg.com/Product/Product.aspx?Item=N82E16814102858
If you have any other questions please write back in this thread. I will be happy to help you through your computer upgrade.
Jul 06, 2010 | ASUS M4A78T-E Motherboard with AMD Phenom...
Cpu fan runs at high speed all the time
the problem is that the mother board you are now using has a 4th wire that sences cpu temp this allow the heat sink fan to change speed to get this to work correctly you will need to replace the fan with a 4 wire style. what is happening is your not getting a temp siginal back to motherboard so the fan controller think it hot and send full power to fan alll the time the stock fan in hp systems is not very good any way .Get a good heat sink and fan to fit your new board ebay has them very cheap 5.00 to 20.00 this will all so increase you system temp and all get the proper cooling when you really need it.
Jun 10, 2009 | ASUS M3A78-CM AMD 780V AM2+ Phenom FX /...
Suggest Asus mother board
depending on the type of system you might want.
mid class with 4 to 8 gb ram I would choose M3A78-CM. Its a UATX (small platform) but its really stable.
upper class if you plan to use above 8gb ram. I would choose M4N78 PRO. It gives you a more PCI slots over the M3A78-CM and just as stable.
May 07, 2009 | Computers & Internet
Can i run ati radeon x1650 512 on asus k8N motherboard
Yes you can run the AGP version of the Radeon 1650 pro on your system. It is always best & recommended to upgrade memory in pairs. You could upgrade to `gb by purchasing a 1 gb kit which would be 512 x 2. That way you have a matching pair of RAM modules. As for a cpu upgrade you can go to the Asus website and see what cpu's are supported by your motherboard. Hope this helps & please remember to rate my answer. Thanks.
Jan 24, 2009 | ATI RADEON X1650 Graphic Card
ASUS M3A78 Pro AMD 780G AM2+/AM2 Phenom FX/Phenom/Athlon /Sempron Socket AM2/AM2+ 5200 MHz PC2-8500 ... Motherboard Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
