Question about Frigidaire FSC23F7D Side by Side Refrigerator
Bypassing a filter
How can one bypass the water filter on a Kenmore Elite A.K.A. Frigidaire Prof Series side by side fridge? The cartridge is the push and click type, right in the front top of the fridge. It's flat and wide but at $50 a pop, it's a waste of money. Besides, it needs changing every month and a half. Or be prepared to sit and wait for a full glass of filtered water.
What gives?
Many thanks,
John
  • garitha Oct 17, 2007
    Thanks for the info. Who knew that it was going to be that easy to get rid of one of my biggest pet-peeves! I have the part (filter by-pass) on-hand and will be using it later tonight. Now all i have to do is add an inexpensive filtration system (say, two stage) to get filtered water with a decent flow rate!
    Thanks again,
  • 473 Answers
They do make a bypass for this which you can get at http://www3.sears.com/.  Will need to know the entire model # from the sticker on the inside of the fridge.  If you have trouble let me know.  I would the the model # also to help further.  Also, it may say something about it in the owners manual.  Let me what you find.
Posted on Oct 17, 2007
SOURCE:
On my Frigidaire Gallery side by side refrigerator, my filter keeps popping out. When it is engaged, I get water but no ice.
replacement water filter keeps popping out of fridge - Shop ...
www.shopyourway.com > Manage My Life > Questions
Kenmore fridge water filter replacement #9911 looks a little different than the last one and pops out after a few minutes of installation ... How do I fix my Kenmore water filterthat keeps popping out? ... Side-by-Side Refrigerator - Stainless Steel.Missing: gallery
Frigidaire Pure Source 2 water filter keeps popping out. - Fixya
www.fixya.com/support/t2000027-frigidaire_pure_source_2_water_filter
... filter keeps popping out. I am posting this again because there were no responses to - Refrigerators question. ... I am trying to replace my water filter with a newFrigidaire Pure Source 2. I have a side by side Frigidaire. I removed the old ... When I press the water lever the Pure Source 2 filter pops out. I called Frigidaire and ...
Dec 26, 2015 | Frigidaire Refrigerators
Have a Kenmore Elite Side by Side and there is water running down the side of the fridge which appears to be coming from the water filter. Already changed it twice.
Did you flush the system after changing the filter? Air can cause water to leak if it not flushed after each filter change. It takes about 6 to 7 minutes to get all the air flushed out. I hope that helps...
Nov 12, 2014 | Kenmore Elite Side By Side Refrigerator -...
Repairman made service call and checked out the frigidaire. Said everything was ok except there was a leak in the inside water filter housing unit, so he went ahead and bypassed the filter since we have...
The filter under the sink should have nothing to do with the water supply to the icemaker. The "repairman" probably cut off the icemaker water supply by "bypassing" the filter.
Jan 08, 2014 | Frigidaire FGHB2844L (27.8 cu. ft.) French...
The water from the fridge filter cartridge is murky brown. I put a new one in and it is still brown. Tried bypassing the filter and water is clear. Put the filter back on and brown water returned. The...
If the filter replacement was done in accordance with the instructions provided, you should have no trouble. If you did everything correctly, then you may need a visit from a technician. I would recommend not using the filtered until the issue is resolved.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Oct 15, 2017 | KitchenAid KSRB25FKSS Side by Side...
The water stopped coming out of the water dispenser and the ice maker will not make and drop ice. The line from the house to the fridge is not clogged, the lines to the icemaker do not appear clogged.
Sounds like someone accidentally locked you out. If you see a RED light lit above the touch pad.
To Lock Out Press the LOCK Touch Pad for 3-5 seconds. A Red light will appear above
the Touch Pad.
To Unlock
Press the LOCK Touch Pad for 3-5 seconds until the Red light above the
Touch Pad goes out.
Other possibilities:
Household water line valve is not open. -open valve
Freezer door is not closed-Close door tight
Ice & water filter cartridge is clogged-replace filter
Front filter not fully installed, if equipped-Push filter until you hear a CLICK. filter should be FLUSH with cabinet
Here is a link to the user manual.
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/241572801en.pdf
Hope this helps
Thanks
Please rate FIXYA
May 26, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
Were is water filter in refrigerator
The water filter is located inside the fresh food section. In the top right hand up front as soon as you open the door it has a push button to eject the cartridge or it is in the back of fridge section in a plastic cup that easily unscrews. A new filter can be purchased at a hardware store or local appliance repair store. they can also be ordered online.
Oct 26, 2010 | Frigidaire FRS6R5EMB Side by Side...
Can't find user's manual but need to install
There are two places to look for the filter .. under thye door at the bottom of the fridge, there should be a button to push to release the filter cartridge, OR ,, with the door open in the upper right hand corner ..
May 09, 2010 | Frigidaire 26.0 cu. ft. Side-By-Side...
I just installed a new MSWF water filter cartridge on my GE Profile refrigerator. After pushing the reset button, there is no water flow at all. I can hear the pump humming. I tried removing and...
Tried new filter. Thought water line frozen. Problem solved by bypassing the water filter. Now that I'm working without filter I will troubleshoot the filter receptacle.
May 04, 2010 | GE Profile 25.5 Cu. Ft. Side-by-Side...
How can I change the water filter on a frigidaire fridge
Hi, The filter is in the upper right hand corner of the fresh food section. Turn the filter cup counter clockwise to remove it. There will be a filter cartridge in the cup that you replace.
Please let me know if this has been helpfull or if I can assist you further
Thanks
Vic
Jul 17, 2009 | Frigidaire FRS6R5EMB Side by Side...
Frigidaire FSC23F7D Side by Side Refrigerator Logo
448 people viewed this question
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Sal De
Thomas F. Schneider
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
