Question about Refrigerators
GE Profile Door Stop Bracket Replacement
I have a GE Profile side by side that is about 9 years old and the right door (refrigeration) has started to swing open too far -- all the way to the wall. I have read up on this and believe that the problem is a broken door stop bracket. A few questions:
1. Does this sounds right?
2. If so, how do I replace it?
3. Is it the hinge at the bottom or top of the door and how difficult?
4. Will the door remain in place while switch out the hinge or do I need to unload and take it completely off.
5. Finally, how do I order the part? I searched on the GE site and couldn't find anything remotely helpful.
Thanks in advance!
Kerry
  • Kerrydon May 17, 2009
    Thanks!
    The model number is: TFX27PRXF WW
    President:
  • 1,136 Answers
Hi, get me the model# and I get you exact answers to all your questions. It is not a hard job.
Vic
Posted on May 17, 2009
  • Victor
    Victor May 18, 2009
    Hi, Part #'s are Hinge WR13X746 $22.95
    Lowwer hinge cam WR2X7512 $21.95
    Hinge stop WR2X9300 $7.95
    I would recommend changing all three of these. I have all of them on my web site www.whirlpoolpartssurplus.com
    Even tho yours is a GE, thay are on my site.
    Let me know if I can help further and I ask that you please give my site a chance.
    THanks
    Vic
How to remove freezer door with water/ice dispenser on GE profile TFH22PRSM
TAKE OFF KICKPLATE ON BOTTOM OF UNIT. UNHOOK WATER LINE FROM QUICK CONNECT UNDERNEATH. ON TOP OF FRIDGE THERE IS A COVER OVER THE DOOR BRACKET. REMOVE THAT COVER. THEN REMOVE THE 2 OR 3 SCREWS HOLDING BRACKET TO TOP OF FRIDGE. THEY USUALLY ARE 5/16TH SCREWS.MAKE SURE THE HAVE DOOR SHUT OR SOMEONE HOLDING THE DOOR WHEN DOING THIS. AFTER REVING SCREWS AND BRACKET LIFT DOOR UP OFF BOTTOM HINGE AND WATER LINE FROM DOOR WILL COME OUT WITH IT.
Jan 17, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
Temperature in refrigerator will not stay set. It keeps getting colder. I have a GE Artica model PSS27SGMD. It is a side by side with ice through the door. It is +- 9 years old
GE Artica had problems with the "Motherboards" originally installed. They have since switched manufacturers so my educated guess that is the problem.
Jan 08, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Freezer not geting cold
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
May 19, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
. I need the hinge door stop on the lower right side of refridge
The door stop part # WR02X10782 If this is for the refrig door , check the screw at the bottom of the door , to make sure it is not adjusted too high , bypassing the door stop . The same door stop is used on both doors .
May 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge Profile Stainless Steel Refrigerator panel replacement
You can replace the doors but you will think you bought a new frig when you see what they cost. Most come as an assembly and are very expensive.
Eric
Jun 29, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerator door is not shutting right
You need to replaced the door cam assembly on the bottom of the refrigerator side. It is probably cracked and hanging up.
Jan 04, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Not getting water from dispenser in door
The connector that is leaking is bad causing tubing to come out and leak. The reason it won't flow is it is iced up inside of the door and no, unfortunately, you can't disassemble the door to get to it. It requires a door replacement. The connector is part number WR02X10471 from www.geappliances.com or GE Factory Service Parts at 1-800-626-2002
Dec 20, 2008 | GE Profile¿ Arctica® Energy...
Side by side GE profile
I have a GE side by side refrigerater freezer. I thas the diagnostic center on the freezer door. The de symbol started flashing afew days ago and the refridgerater side isn't getting cold. the fan is on and doen't seem to cut off, If someone could steer me in the right direction I would appreciate it.
Jan 29, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge oven problem
Look for a microswitch connected to the lock mechanism at the back of the stove. The switch is probably broken.
Jun 07, 2007 | GE Profile JTP56 Electric Double Oven
Refrigerators Logo
492 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
