Question about Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television
Sharpness I have a 52327 Rear projection Mitsubichi. Everything works great except the sharpness. The bar moves from 0 to 63, but the picture never changes. Has anyone had this problem and how do I fix it. Thanks
  • 42 Answers
As for the sharpness if the picture has no adjustment and is maximum sharpness you cannot improve it.
Posted on Jan 24, 2008
The picture is not as sharp as before, what do i need to do or replace to bring the sharpness back
Have your lamp replaced and it will regain sharpness once again.
If that does not help check if any lead from the panel have not melted off, then correct with a soldering iron if you see any.
Take care
Oct 15, 2010 | Philips 60PP9202 60" Rear Projection...
What should my picture setting be Brightness Color Picture Sharpness and Tint
the better effectiveness the colour settting should be average that is 50%, the sharpness on 70%, brightness on 60%, and tint on 50%.
Hope this will help...
May 31, 2010 | Philips 51PP9910 51" Rear Projection HDTV
Do the AKAI PTH 5498 TV's have replaceable lamps like you hear so much about for other rear projection TV's? And if so, any suggetions on where to find the lamps? I am hoping this can improve the sharpness...
No your model has three CRTs (picture Tubes) cleaning the mirror may help to restore the sharpness and brightness unless you have other issues. I would try cleaning the mirror first. Dont use windex, just a soft damp cloth with water then dry
Dec 20, 2009 | Akai PTH5498 54" Rear Projection...
Poor picture quality
Hello Paul. I have this same monitor, but rebranded, Access the service menu with the remote control:
With user’s RC
1. Power TV On
2. Press Menu button and call up User OSD Menu
3. Select Sound-> Balance
4. When Balance value is “0”,Enter 0->5->3 ->2 in sequence.
Note: If necessary, re-do number keys.
5. Factory OSD appears.
6. Press the standby button then AC turn off and restart the TV, which can exit factory
OSD menu.
Now you will be able to change the values for Red Green and Blue channels. I also hated this TV, but after adjusting the colors it's looking great! Hope you could fix it too! :)
Nov 16, 2009 | Televison & Video
Picture is dark and pictur not sharp
If the picture is dark the only thing that will cause that is a bad lamp. You will need part number 915P020010 to fix that.
Nov 11, 2009 | Mitsubishi WD-52327 52" Rear Projection...
How to clean Mitsubishi TV WD-52327 fliter
Remove the 2 screws in the access panel on the left rear side of the tv. You will see the filter behind it. Rinse the filter in warm water until clean. Lay it flat on a paper towel and fold the other half of the paper towel over it. Press gently on the towel to soak up most of the water, and install it in the tv.
Oct 10, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Dull picture in all situations
in the setting section click on picture and go to color warmth there you can change from cool to mediam and hot
Jun 23, 2009 | Philips 60PW9363 60" Rear Projection...
Have problems with mitsu wd-52327
check the current maybe high voltage occur or due to loose connection high amper occur.
Jun 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Too much green in picture cant fix using tint
Check to see if you have the colored leads comming from the CATV box switched or not hooked up.
You may just have no red. you also may have switched the red video and red audio leads.
Mar 22, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television Logo
69 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
