Question about Intel D865GBF Motherboard
My power distibtion is demaged after power failuure. The power is not reached on on/oof switch because my power supply for start motherboard is demaged after main supply failure. Please send me guide and parts no. to repair my mainboard supply system. My email addreess in anwar1hassan@yahoo.com
    Problem Solver:
  • 6 Answers
Unplug your power supply from the mother board.
Using a volt meter check for voltage at the plug.
Some power supplies have an internal fuse that
may have blown.The fuse is accessable by removing the cover on the supply(MAKE SURE IT IS UNPLUGED) some times simply changing the fuse will do the trick. if not replace the Power Supply
Posted on Jun 06, 2009
My Intel E54926 motherboard won't switch on,the power supply works on another board,power led light is on when I plug my power supply in,which shows it has power but still no power to switch it on?
Things to check : bent or missing pins on the processor. Power switch on the case may have jumped a pin if you have removed it . Make sure the 4 pin power cable is fully seated on the motherboard if it is used.
If none of these places are the problem, then it's possible there are too many domed electrolytic capacitors on the motherboard which would stop the power ok signal from the motherboard from reaching the power supply.
Oct 16, 2016 | Intel Computers & Internet
I have a an35n ultra v1.1 motherboard I power on my tower,it does power on but it wont post I dont see anything wrong with cap's cpu was tested and checks out Power supply is good Tryed a new video card...
Hello Phenom, Hi.... to properly run/test a motherboard, you need to make sure this parts are good with no doubt functioning. 1. the power supply, 2. Memory, 3. keyboard, 4. Processor with FAN 5. PC speaker(built on-board or the thumb speaker) and 6. monitor How to test. First remove all motherboard connections. Now reconnect the following. 1. make sure that the power supply 20/24 pin is connected properly to the motherboard (and please test this power supply before making connections. To test independently short green wire to ground and plug the unit. you should see the fan spin) 2. make sure that the 4 pin 12volt power connector is also plug in nice and tight. 3. clean the memory slot using a clean paint brush and the module (DDR/2) terminals (the contacts) using an eraser, 4. connect the keyboard, 5. make sure there is a PC speaker connected. 6. connect the power switch of the front panel, 7. Connect a monitor on the VGA port 8. Power on the PC. 8. Look at the keyboard lights 3 LED momentarily. num lock + caps lock + scroll lock and after several seconds 1 LED light, num lock only. If you reach this part you should also hear a beep. then the POST will appear. If you don't reach this part, start again from the top. do this several times. Still no response? you motherboard is bad.
Jan 07, 2011 | Shuttle AN35N Motherboard
My Emachine T 3626 i got new motherboard, new power supply.new cpu fan and now is not working , i conect everthing but the power lec and power sw dont come out the only way is to turn oof from the...
1) The eMachines T3626 uses an ESC MCP61SM-GM motherboard,
http://support.gateway.com/s//MOTHERBD/Shared/4006233R/4006233Rnv.shtml
Click on > Product Views
Now click on > P- Front Panel Connector
http://support.gateway.com/s/MOTHERBD/Shared/4006233R/4006233Rmvr18.shtml
Did you connect the cables, (Wires), from the Front Panel to the Front Panel Connector, correctly?
Looking at the Front Panel Connector, observe where it has > 2, at the bottom.
(Right above the small round object with the Orange dot in it)
This is the Bottom of the Front Panel Connector
The pins are in Two columns.
The column on the Right side is numbered > Even
The column on the Left side is numbered > Odd
Starting at the Bottom going Up on the Right side,
Pins 1, 3, 5, 7, and 9
Starting at the Bottom going Up on the Ledt side,
Pins 2, 4, 6, 8, and there is NO Pin 10.
A) Pins 1 and 3 are for the HarDDrive Activity LED light
B) Pins 5 and 7 are for the Reset switch. (IF one is used)
C) Pin 9 is for the 5+ power
D) Pins 2 and 4 are for the Power On LED light
E) Pins 6 and 8 are for the Power On switch
F) There is NO Pin 10
Let me know in a Comment.
Dec 01, 2010 | E-Machines eMachines Desktop PC
Cpu fan running but the mother board does not respond
Remove/disconnect everything (Ram, Cables, Power Supply, Battery, Processor, Pci cards, Display cards if there's one, etc.) from the motherboard, and after while, reconnect/put them on the motherboard again. Make sure you correctly installed the Ram and it's working. Also don't forget to connect both the power supply cables (20 pins connector and 4 pins connector) to the board. Now reboot your system, can you hear anything (beeps)? If this doesn't help, your nearest culprit to the problem is Display card. Good luck
May 21, 2010 | MSI K8MM-V Motherboard
Power supply problem
Hello
Im using the intel dg33bu board with an intel core 2 ,3ghz.
When i built the pc i upgraded to a 450watt power supply.
Try a 450watt supply.Consult intel on the proper specs.
Apr 15, 2010 | Intel DG31PR Motherboard
My Toshiba 32wlt58 wont start up. The standby light works and it appears to have power but I do not have the remote, and cannot work out how to start it up. I have tried te power button at the top but only...
it problem on power supply its demage may be some of components are demage such as capacitor or rectifire demage or mosfac please you go to a service center and repear it by a good technician in your area.
Nov 22, 2009 | Toshiba 32WLT58 32 in. LCD Television
PC doesn't boot up.
Use jumper to reset cmos. Test or replace cmos battery.Unplug evthing( HDD,CD,DVD,FLoppy) try to start barebone. Test voltage from power supply to motherboard. Try different ram. Good Luck.
Nov 21, 2009 | EliteGroup Lga 775 GF7100PVT-M3/MCP73T-M3...
My Dell Dimension 3000 PC won't start when I push the power button
A.Bad Power On switch. (Behind the Power On button)
B.Bad power supply
C.Power supply cables have come loose inside the computer.
1.Power supply to motherboard. (20-pin connector on motherboard)
This connector has two pins in it for Soft Power On. The power supply does not connect directly to the Power On switch. The power supply connects to the motherboard, and turns on via Soft Power On.
ADVISEMENT!!
ALWAYS have the computer unplugged from power before reaching inside!
ALWAYS work on a table. DO NOT work on a bed, or directly on a carpet floor. These are high areas for Static electricity! Static electricity will silently burn out computer hardware components. You may not see it or feel it.
Touch the metal frame of the computer case, to relieve your body of static, BEFORE you reach inside.
Sep 30, 2009 | Dell Dimension 3000 PC Desktop
Motherboard of model no FZ210C is demage what to
ask wat motherboard it is and get it replaced
Aug 26, 2009 | Sony VAIO VGN-FZ210C/E Notebook
Hi, I can't get my new Brother MFC-7420 to start up. Installed the software, everything is connected and seems to power up, but no display on the printer. Menu/Set button produces NO display. Any ideas??
yes your printer is problem power adopter i mean power supply or motherboard is demage some times ac fuse is burning please replace it then solve your problem
Aug 17, 2009 | Brother MFC 7420 All-In-One Laser Printer
Intel D865GBF Motherboard Logo
130 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
