Question about Belkin (F5D72304F5D7000) Router
Conect the router?
I just bought the belkin f5d7234-4 v3 and i have no clue how to set it up. i jst called a tech person for belkin and they didnt help. i also have dsl...so i need to use that as well.
help me before i lose my mind.
    President:
  • 2,559 Answers
1. Unplug your DSL modem’s power supply.
Find the cable connecting your modem and computer.
Unplug it from the modem and plug it into the gray port
on the Belkin Router.
If you are replacing an existing router, find the cable
connecting the computer and old router. Disconnect it from
the old router and plug it into the gray port on the new router.
2. Connect the new cable (provided in the box) to the yellow
port on the Router.
Plug the other end into the modem.
3. Plug in your modem’s power supply. Wait 60 seconds for the
modem to start up.
Plug the Router’s power supply into a wall outlet, and the
other end into the black port on the Belkin Router.
As the Router wakes up, lights will come on; recheck your
connections if the “power” and one of the “wired” lights
are not lit up in green after 20 seconds.
4. Locate the CD in this guide and insert it into your computer.
The Setup Assistant should appear automatically.
If it doesn’t, open the CD in My Computer and double-click on the
“Setup Assistant” icon.It will guide you through he rest of the setup.
If you need more help please post back,If this help please rate as a fixya.
Posted on May 17, 2009
I have a belkin -n1 wireless router.. it is a great router because it works all the way through the house. the only problem with it is that i cant update my xbox with it, neither by wire or wirless. if it...
first check whether the gaming ports for xbox have been forwarded in the belkin router or not....if not do it first....if you dont know the port numbers call xbox support and get the list of port numbers to be forwarded....
then enable DMZ for the ip address of XBOX in belkin router...
then enable UPNP in belkin router....
atlast Disable firewall in belkin router.... your XBOX will go online and GET UPDATE..... you can call belkin tech support of your country to assist you to forward ports for XBOX in belkin router... if you reside in USA/Newzealand/Australia/Canada you can call this toll free 1800 2 BELKIN(235546)...... or you can call my personal mobile... Im from India country code +91 Mobile number 9003593572
Apr 09, 2010 | Microsoft Wireless Network Adapter Xbox...
My wireless adapter light is green, yet i cant connect to xbox live!
Apr 08, 2010 | Microsoft Wireless Network Adapter Xbox...
I have a Belkin F5D8233-4v3 router. I can get just one wired port to work. I use both wireless and wired connections. Could this be a hardware or software problem?
That's a fairly new router, you shouldn't be having those issues. Make sure you're identifying the uplink port, the quickstart guide with router should help with that.
If everything is wired correctly, it could be either firmware of hardware. Might want to try calling Belkin or even where you bought it from to see if you can exchange. Sounds like you got a defective unit. Alternately, try going to Belkin's website and downloading and installing the latest firmware for the router. If that doesn't do it, then you have a hardware failure, and Belkin should owe you a new router, that router claims a lifetime warranty.
There is a new firmware v4, sounds like you have v3, check here:
http://en-us-support.belkin.com/app/answers/detail/a_id/521/kw/F5D8233/r_id/166
Feb 04, 2010 | Belkin Computers & Internet
I use to be able to conect to my company vpn, since i added my belkin wireless G router (fd7230-4)for my sons laptop i am no longer able to do so. Any help would be welcomed. My IT guy says that our...
See if Belkin has a firewall setting in the routers control panel. You have to log on to the routers address to find out. In order to access a linksys control panel you have to put 192,168.1.1 in to internet explorers address bar. The user name by default is Admin and password is the password. Try doing a google search for the belkin log on address to use.
Jul 01, 2009 | Belkin (F5D7230-4) Router (587009)
Connect router to playstation 3
You need to first plug the DSL modem into the router. log on to the router. Configure the router byusing the user name and password as supplied by your dsl provider. once the router connects to your dsl provider, you should be able to connect your playstation to the wireless network.
Jun 02, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Cant get online wireless'ly
The procedure is 1st. to connect the LAN cable to the router (not to the LAN port marked WAN) and use the browser to configure the Belkin router for the wireless settings.
In the wireless setup change the SSID from the default SSID to what you like., set up encryption (if your wireless card supports WAP then use WAP encryption, if not use WEP 128bit)
Also change the administrator password (write it down and put it in a safe place).
you can disconnect the LAN cable from the computer and router.
If you had not installed the wireless driver for you wireless card, do so now.
Connect the LAN cable to the WAN port on the router and the other end to the Hughesnet.
Now configure the wireless card with the SSID and the encryption that was set on the router.
If all goes well you should see your router and get on to the Internet.
Get back to me with error messages if you have problems.
May 22, 2009 | Dell Inspiron 4150 Notebook
I have a belkin wireless g router and my nat settings are strict?
I understand your problem..To fix this issue all you have to do is,You should open the x- box port numbers on the belkin router(please call tech support for assistance),
And also i would suggest you to assign static ip on x-box on belkin range(192.168.2....) then you need to enter same number on router under DMZ. It may be quiet difficult for you to do all this.please call toll free number"belkin".
Dec 17, 2008 | Belkin (F5D7230-4) Router (587009)
Wireless conection with xbox 360
does it have a firewall built in on the belkin?
im assuming it has a port blocked on the firewall settings.
Dec 02, 2007 | Video Game Consoles & Games
Belkin (F5D72304F5D7000) Router Logo
324 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
