Battery not holding charge
My hp 6108nr laptop battery doesn't hold a charge. Do I need to purchase a new one?
    Sergeant:
  • 199 Answers
Your charger may be defect and may be not connected to pc or charger pin.if your charger is correct then battery life is expire and then new one purchase.
Posted on May 17, 2009
Hp 8440p battery won't hold a charge
Since you have replaced the battery and the ac adapter then there's a problem with your computer's motherboard. Get it serviced by a technician if he says that you need to replace the motherboard then you better buy a new laptop. Motherboards are expensive.
Apr 04, 2013 | HEWLETT-PACKARD Hewlett Packard HP...
My m2000 battery is not working
The possible causes are as follows:
Determine if the laptop battery is defective. While less than 1 percent of batteries are defective, the possibility is still there. If the battery is new and only charges some of the way, it may just require a BIOS update to charge fully. New batteries that refuse to charge at all may be defective. Purchase a new laptop battery to replace the defective one.
Test the laptop power adapter to see if it's faulty. Run the laptop directly from the laptop power adapter and without the battery. If the laptop does not work with the adapter plugged in, the adapter is dead and you will need to replace it. The laptop battery may refuse to charge if the adapter is faulty. Charge the battery with the laptop turned off.
Insert the laptop battery into another laptop to test it. If the laptop battery charges in another laptop, the laptop's motherboard may be bad. Replacing a motherboard in a computer can be very expensive. If the cost to fix the computer is not worth the cost of replacing the motherboard, consider purchasing a new laptop.
Reinstall the battery to ensure all connectors latch properly. The latch mechanism that holds the laptop battery should click into place. If the latch does not close, remove the battery and examine the compartment for signs of damage.
5
Troubleshoot the BIOS to determine if there is a hardware problem. Turn on the laptop and immediately enter BIOS setup by holding down the "Del" and "F1" or "F2" keys, depending on the make and model of the laptop. When the BIOS screen appears, see how long it takes for the battery to charge down. If the battery does not last as long as the BIOS setup, a hardware failure may be the problem.
http://www.aurabuy.com/cheap-12-cell-battery-for-hp-compaq-presario-b3300-c300-c500-m2000-paypal.html
Mar 31, 2013 | HP Compaq Presario V2000 Notebook
I have an HP G60-235X that I purchased a little more than a year ago. About 6 months ago, I began to notice less charge life in the battery and a very high temperature from the battery pack. Now, and...
You need a new battery. One or more cells is defective. Obviously it's unsafe to continue using a battery pack if it gets hot enough to cause burns, so remove the pack from the computer. You can continue to use the computer on AC power until you get a replacement battery.
You might try contacting HP to see if there's any kind of warranty accommodation they can make. I've found several mentions in various forums about batteries in similar models going bad and that HP replaced them, but they were all within a year of purchase. Can't hurt to ask, though.
Jul 09, 2011 | HP G60-235DX Notebook
Battery problem with HP Compaq Presario V2000 laptop
When batteries fail, they usually lose the cells inside them, which means that the cell is no longer able to function as a holding cell for power and therefore cannot do its job anymore, when a battery fails to hold and refuses charging it is bad and needs to be recycled. The flashing is telling you to purchase a new battery. The larger the number of cells in the battery, the longer and better it will perfrom,,RE: 6 cell, 9 cell, 12 cell.
Jan 13, 2010 | HP Compaq Presario V2000 Notebook
Battery doesn't charge.
the power supply may not be delivering the necessary power to charge your battery.
Jun 02, 2009 | HP Compaq nx9600 Notebook
The Battery in my Hp Laptop Pavilion ze4900 is
using the wrong ac adapter the e500 adapter is not the same voltage or watts!
Feb 26, 2009 | HP Computers & Internet
COmpaq Presario V5000 Battery will not hold charge
Problem with the motherboard connector that charge the battery.
Oct 03, 2008 | HP Compaq Presario V5000Z Notebook
Computers & Internet Logo
193 people viewed this question
David Payne
David Payne
