I have an older sanyo tv with no remote (lost it)and i cant shut off closed caption.I went into the menu on the tv with the button on the tv but there is no option for closed caption have any ideas?
i tried no help any other ideas?please help i ready to through it out the window!!i tried no help any other ideas?please help i ready to through it out the window!!
You can't post conmments that contain an email address.
Whe you throw it out of the window make sure the window is open and that nobody will get hit by it.Sorry I couldn't help you !Whe you throw it out of the window make sure the window is open and that nobody will get hit by it.Sorry I couldn't help you !
hi, For switching off the closed caption option do the following.
1. Press CC on the remote. • This will present the Closed Caption information display.
2. Press CC while the Closed Caption information is still on the screen. • Press repeatedly until you select the desired closed caption service as OFF. ok
Look at the tv bazel frame at the bottom of the tv have manual controls buttons look for button said Menu.Push that button go into tv menu look for functions said close captioning turn it on to CC1,2,3 so on.Now tv with programming have CC logo should have close captioning.Or try website like Remotes.com to buy an exact remote as ur original remote.
here is the manual
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=7eb82b548ada65fb3ed52985326223f4&modelid=311865&q=Sanyo+HT27546
go to the section
" MENU MAP "
on page 14
Fosg2000, Rate me please
Don't know on the Sanyo, but most TVs let you turn off the CC via the remote, either by a CC listing on the remote itself, or by going to the menu (menu button) which shows on the TV screen, then working your way through the menu to the closed captioning. That should let you turn it on or off.
Good luck.
Go into the setup menu and turn off closed captioning there, or just restore the factory presets. I believe this model has a menu button on the front of the tv.
You didn't ask for it, but here's a link to the user manual, in case you need it.
look on top and behind of the monitor you will find buttons for your TV then follow this steps:
The Setup menu lets you configure the TV to fit its surroundings and your preferences. To access the Setup menu, press MENU, and then select Setup from the Main Menu.closed caption options are:
CC Setting Lets you choose the way closed captioning information appears on the screen.
Off No captioning information displayed.
On Always Captioning information shown always, when available.
On When Muted Displays captioning information, when available, whenever the TV?s sound is muted by pressing the MUTE button. The captioning information is not displayed when the sound is not muted. Make sure all of the options for closed caption are off press exit and you are good to go.
I am sorry you don't. You will need the original remote. I have enclosed a link where you can see the original remote and order one if you want to. If you see the picture, there is a caption button on the remote to turn on and off the closed captions Good Luck. Here is the link
http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=DS24424&brand_pn=SANYO_DS24424&mode=large&uid=11872683567810
