Try ohming out the themostates and hi limit fuse... if you dont have a ohm meter you can hook the wires together with a small piece of wire and by pass them to see if thats the problem or not
If one of the two thermal fuses are blown you will not
get heat. Thermal fuses blow (and are
not resetable, they must be replaced) when the machine gets too hot. Often this is caused by not enough air flow
through the machine. Check and make sure
your exhaust vent is not clogged. Clean
it the best you can to get all the lint, dead mice, bird nests, etc. out. Also make sure air is blowing out of the
machine when it is turned on. If not you
have a blower problem. The thermal fuses are located on the element casing. They each have two wires coming out of
them. They are about 3/4 inch round with
screw ears on the sides so they are about 1 1/2 inch long and about an inch
across. With a multimeter, check the
continuity across the terminals. If
there is no continuity the fuse needs to be replaced.
Hi
If your dryer is not heating, then check if the power cord is plugged into the wall. It may be loose or disconnected. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working. Now, check whether the heating element in your gas dryer is burned out by using an ohm meter to check for continuity. If the continuity is not there then you would need to replace the element. After checking the element, check out the thermal fuse to see if it's burned out. The thermal fuse is attached to the exhaust duct on the back panel of the gas dryer. It's usually surrounded by a black resin material situated in a housing made of white plastic. If the fuse looks like it
brand new dryer wont heat up?
also how you hook up the yellow green & white (could be hooked up wrong)will that cause it to not heat up?
