Question about Intermatic T104M 208-277Volt 40-amp Timer Switch-Double Pole / Single Throw
Timer will lock up when it gets to the off switch...
Time dial, wiil move pass the off switch...ex. set off time at 8:00 pm...in the morning....timer is still shut off...timer reads 8:00pm, returned the time mecahanism, installed a new one and still having the same problem....
    Problem Solver:
  • 13 Answers
Sounds like you have the timer motor feeding through the points, be sure to have incoming power to timer motor so it is hot even when the timer is in the off cycle. If this does not help please post a model number and I will try to be more specific.
Posted on May 22, 2009
How to reset the hager EH711? Currently it is set to turn off the light at 7:30am and turn on at 7:30pm. I want to turn on at 7:30pm and turn off at 7:00am. thank you in advance.
Open following link for Hagar timers:
http://waterheatertimer.org/Hagar-timers-and-manuals.html
Hagar EH711 has segments located around the analog dial.
The dial rotates as time passes and the segments move tiny lever that turns Loan on-off.
The segments are pushed down and outward or up and inward to set on-off times.
The timer can be wired a couple different ways, so setting the segments up or down depends on how it was wired.
If you look at dial on your timer and see how segments are set now, that will give you the correct information.
If segments are down between 7:30am and 7:30 pm, then move those segments up-and-inward.
To check the timer after moving your segments, you can manually rotate dial clockwise and watch the load turn on-off. To set current time, rotate dial until current time lines up with arrowhead located on inner dial.
The slide switch has 3 positions. 0 = ON all the time; 1 = OFF all the time, and Auto = timer turns on-off depending how segments are set.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 14, 2011 | Hardware & Accessories
How do I operate the pins. I get the Current time and can set the on time but am confused about the off time because it seems like the off time ends up to be pm and I am turning it on in the am.
Open following link to see photos of pins and tabs:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Pins-tabs
Here's a generic instructions for plug-in timers.
Locate pins on dial: move 10 pins in a row. This will be for testing purpose.
Plug timer into outlet located on kitchen counter-top so you can see what is happening.
Turn lamp on. Plug lamp into timer.
Manually rotate dial clockwise and watch when lamp turns on-off.
This will tell you how to position the pins.
Most of these timers have a slide-switch.
Move the slide-switch one direction and then the other.
Manually rotate dial each time and see which way slide-switch should be positioned.
Set pins for on and off times.
Dark background is pm. Light background is am hours.
Final step is to set current time. Manually rotate dial until current time lines up with arrowhead located on inner dial.
As time passes, the dial rotates, and the pins click a lever that turns lamp on-and-off
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Feb 10, 2011 | Woods 3C 24 Hour Indoor Mechanical Timer...
Power was out last week . Our timer was set at 5 pm on and 12 midnight off. Now the lights are on at 8 am and off at 3 pm.Please help
You posted under Intermatic 24-hour mechanical timer.
When power goes out, the current time has to be reset.
Pull yellow dial outward, and then rotate dial until current time lines up with silver pointer.
Some folks mistakenly move the silver pointer when trying to set current time.
The silver pointer is stationary at the 6 o'clock position.
To see sample photos of timer:
http://www.amazon.com/Intermatic-T104-208-277-Volt-Mechanical-Switch/dp/tags-on-product/B000BQOX88
http://waterheatertimer.org/images/T-101-large-1390.jpg
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Model number of timer shows on inside of timer door.
This type of timer has on and off trippers attached to dial.
Dial rotates as time passes.
Trippers push a lever back and forth that opens-and-closes circuit to lights.
You can buy replacement clock motor and trippers at Grainger:
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
Feb 08, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
Got a brinks EZ- dial timer model42-1034B @ Walmart a few days ago can not seem to get it to work, Inst, seem so easy too. I read on some forum online someone thought the am/pm may be backwards to how it...
1) This Brinks timer is a bit lightweight for an appliance (unless for coffeemaker or tiny gerbil-feeding motor)
You might need 1/3 HP (horsepower) appliance timer like Woods 59201
http://waterheatertimer.org/Woods-timers-and-manuals.html#59201
http://www.amazon.com/Woods-59201-Appliance-Grounded-3-Prong/dp/B001Q9EFTQ
Intermatic HB113C is for heavier appliances
http://www.amazon.com/Intermatic-Hb113c/dp/B000GHKO6C
http://waterheatertimer.org/images/Intermatic-HB114C-plug-in-4.jpg
2) How to set the Brinks:
I will use lamp as example since you can easily test the timer using a lamp.
Turn lamp ON. Make sure bulb is good.
Leave lamp turned ON and plug lamp into timer.
Move slide switch one direction.
Plug timer into outlet.
Manually rotate timer dial clockwise and see if lamp turns on-off
Move slide switch other direction, and rotate dial clockwise again to see if lamp turns on-off.
Now you know which way switch has to be moved.
Push down trippers and rotate around dial until they line up with 1:00 on dark part of dial and 5:00 on dark part of dial. Dark is for pm hours.
Last step: Set current time: rotate dial clockwise until current time lines up with arrowhead located on inner dial
Dial rotates at time passes, trippers push lever that turns circuit on-off.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Jan 29, 2011 | Hampton Technologies Brinks Timer
How do I set a plug in timer GE 24 hour Model 15075? There are tiny switches for every hour and can be pushed towards the inner circle or pushed outward. And there is a turning arow near the center and a...
Following link has a close-up photo of on-off pins on GE 15075 timer
http://waterheatertimer.org/GE-timers-and-manuals.html#15075
Pins are located around timer dial
The pins divide 24-hour day into 1/2 hour segments
Pins are out for ON
Pins are inward for OFF
Notice that numbered dial is divided into dark and light areas ... the dark areas are PM, light areas AM.
For example you are connecting chicken coop lamp to this timer.
Turn lamp on and make sure bulb is working.
Set pins in and out as follows: all pins outward between 4:30 pm on light part of dial to 8:00 pm on dark part of dial. And then set all pins outward between 5:00am on dark part of dial to 7:00 am on light part of dial.
Move switch located on top to TIMER ON
Manually rotate timer dial clockwise to see lamp turn on and off.
Lastly, set current time: Manually rotate timer dial clockwise until current time lines up with arrowhead located on inner dial. So if current time is high noon, then rotate dial until 'sun' symbol located on light part of dial lines up with arrowhead.
As time passes, the timer dial rotates, and the pins click circuit on-off.
To override timer, move switch to outlet-on.
Jan 09, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
How do i set the Brinks 44-1040 timer?
Brinks 44-1040 is a 24-hour plug-in timer, with 1 on tripper and 1 off tripper.
Dial has 24 hours with each hour marked for am and pm times.
Push tripper down and rotate until tripper aligns with time you want for ON and OFF.
Rotate dial until current time lines up with arrowhead located on inner dial.
Plug lamp into timer. and plug timer into wall.
Move slide switch one direction or the other to control mode.
When switch is one direction, lamp in ON all the time.
Move switch other direction, and timer programs work.
Dial rotates as time passes, and trippers move on-off lever that turns lamp ON-and-OFF.
Dec 24, 2010 | Hampton Technologies Brinks Timer
How to set on at 4 pm and off at 7am
You posted under intermatic 1020 timer
If this is not your timer, add a comment
How to set timer.
Remove dial from body of timer.
So now the timer is apart in 2 pieces.
Silver ON trippers and brass OFF trippers can be removed.
Place trippers in times you want timer to operate.
In this case, set silver ON tripper at 4pm
Set brass OFF tripper at 7am
Timer comes with 2 pair of trippers, so you will only use one pair.
Save the extra pair of trippers for when 1st pair of trippers wears out.
Snap timer back together.
Manually rotate dial around to watch lights come on.
To set current time, rotate dial until current time lines up with mark.
Dial rotates with passing time.
Tripper rotates around with dial.
When tripper contacts on-off lever, it physically moves lever like turning light switch on-off.
ON tripper moves lever one direction.
OFF tripper moves lever opposite direction.
Manual E-1020
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/e1020%20-%20english.ashx
Dec 11, 2010 | Intermatic Timer E1020, Single pole/single...
I didn't get any instructions with my timer. It is a tork 601A I don't know how to set it. I think it looks great and just what I'm looking for. The case was sealed but no instructions. Thanks J Seel
Tork 601A outdoor timer manual:
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Timer has 1 125Volt receptacle located on bottom of timer
96 captive tabs located around timer dial allow times to be set each 15 minutes.
Move pins in-or-out with fingernail or pen to set timer on-off functions.
Minimum time setting is 15 minutes.
Maximum time setting 23 ¾ hours.
Set multiple ON/OFFs each day.
Timer repeats every 24-hours.
Dial is divided into daylight and nighttime hours.
Nighttime PM hours are on dark background.
Daylight hours are on light background.
To set timer, rotate dial clockwise until current time lines up with arrowhead located on inner dial. Reset time after power outage.
Manual ON/TIMER switch located on inner dial.
To override time and turn on Load, move override to ON position. To use timer functions, move override to TIMER position
Dec 02, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
Jst bought the house and there is a paragon 4100-0 light timer how do you reset the on-off times to approx. 5 pm on and 11 pm off ?
Paragon 4000 series timers are traditional electro-mechanical timers.
The dial rotates around like a clock as time passes
Black and silver tripper pins on attached to outer edge of dial.
Black tripper is Off
Silver tripper is ON
The tripper pins encounter a lever.
The On tripper pushes lever one direction, the Off tripper pushes lever opposite direction
Click manual override to switch lights by hand
To set current time, lift and rotate dial until current time lines up with black pointer.
Set your trippers on the dial next to the On and Off times you want.
Set silver tripper at 5:oo
Set black tripper at 11:oo
Minimum set time is 1 hour
e62b9e8.jpgParagon 4000 series
If this is not the correct timer, answer back with a description and I'll check my files
Oct 24, 2010 | Paragon 4001-00 24-hr Timer Control 120v...
I want to set the timer and I don't know how
The timer has a dial and an arrow pointing to a certain time. Turn the dial to the correct time of the day ex. it is 2 p.m. rotate the dial so as the arrow points at 2 p.m. Then their are some clips around the dial 2 or 4 or more has to be in pairs. If you want to start sprinkling at 3:00 pm and stop at 3:20 pm put one clip at 3:00 pm and the other clip at 3:20 pm. One clip turns the sprinkler on and the other turns it off.
Jan 24, 2010 | Intermatic R8806P101C -...
Intermatic T104M 208-277Volt 40-amp Timer Switch-Double Pole / Single Throw Logo
158 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
