Question about MPC Computers MicronPC power supply - 220 Watt (PWS00114706) Power Supply
Micronpc cpu will not turn on when pushing the
Micronpc cpu will not turn on when pushing the power button. The light above the power button is showing red when it normally shows green when on or yellow when in sleep mode. What could be the problem?
  • sjjppwalker May 22, 2009
    Solution wasn't clear. Could not understand what was being said. Thanks anyway.
  • 102 Answers
See ur ups is getting dead
i'm working with that one two
try to on it after sometimes keeping the switch on
"can u rate me, for my hint... please"
thanks
Posted on May 17, 2009
Push power button and the power light turns amber and lights up then shuts off. the light in back of the computer is light green and it starts to turn on then dies
The fact that ity is trying to start and shuts off after ..it seams that it is the CPU fan to blame ...If the fan fails to start the CPU will turn the computer down instantly due to the temperature limit ..(in 1 or 2 sec ) ..
so ...open it up ..and see if the fan is spinning ...on start ..and if it is not ...check the connection with the board or replace it ..
(by the way ..this may also be a CPU failure ..and need another one ) ..
Aug 31, 2011 | Dell Inspiron 518 Desktop Computer
Fisher Paykel DS605i single dishdrawer with a user-supplied integrate panel. There are three buttons on front. The left-hand button is power button; the center button is start/pause; and the right-hand...
Hello, Thank You for using FixYa. I will be helping you today.Are any of the cycle lights lighting up like rinse and normal and is the light on front blinking and pausing if so how many times is it blinking? Try turning the power off too the unit for five minutes and back on, because if the lid was open some or was stuck it can stop the unit from running.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jun 29, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Ford explorer Power seat will not move
Check the voltage from the cpu,if there is none,replace the cpu again.Hold seat to foward for 12 seconds then release,wait 20 seconds,see if it will reset.If not replace the cpu
Apr 04, 2010 | Ford Explorer Cars & Trucks
C500 Laptop won't come on power button just flashes
Have you tried attaching an external monitor when the LCD screen is disconnected from the motherboard? this connector is located under the keyboard strip – a piece of plastic just above the keyboard.
If it works, this way, then the video cable isn’t seated properly in the connector on the back of the screen. Plugging the video cable back in should fix the problem.
I don’t know how comfortable you are with taking apart laptops but I think that this information could be useful for you.
Source: http://www.asklaptopfreak.com/laptop-notebook-help/2006/08/08/laptop-powers-on-and-shuts-off-immediately/
Sep 28, 2009 | Compaq Computers & Internet
Computer power ON/OFF behavior is not as expected!
Hi...
If all the parts of your computers are fined functioning. This is a CPU problem witch is no display. Try to disassemble the CPU remove the heat sink the CPU and clean and insert it again. When you are now inserting the CPU be sure that you will put a thermal past in the heat sink so that the heat from the CPU are absorbed. If the heat will not be absorbed it will cause overheating.
Good luck! Thanks for using fixya.
Regards
ICmanServer
Aug 21, 2009 | Computers & Internet
Mother board light comes when I plug the board, but when I push the power button the light by the CPU blinks and the fan on the CPU turns a few times then nothing
It's probably a motherboard issue, since you can get power to the board, but it doesn't fully power up. I would replace the motherboard and see if the problem persists. I hope this helps!
Jul 15, 2009 | QDI Group QDI PlatiniX 4 Motherboard
Gateway MT3422 Screen will not turn on.
This solution worked for me. After Geek Squad had looked at it and said that there would be a new mother board needed. I can vouch for this solution. halo321@comcast.net
noavatar_s.gif captainmf
Rank:nonexpert_s.gif Apprentice
Rating: 75%, 2 votes
iam mohamad fakih from lebanon iv got the same problem but i solve it,the problem of this gateway is the high tempreture from the cpu this is what makes the damage
to fix it, easily just push the keyboard dawn hardly by your hand on the left side above the following keys:E,R,F,4,5 (u can use ur fist) push hardly and press power button and wait 4 seconds
and when the laptop comes on enter the windows and run aprogram that makes the cpu gets hot(a big game) this is to make the motherbaord become hot ,the heat of the cpu will automatically
solder the damaged bus in the motherboard . good luck
Mar 06, 2009 | Gateway MT3422 RTL Notebook
PC power switch needs repair or replacement
Hi There, You are safe to use a just a two wire connection switch rather then then original 7 wire connection. The difference is between the 7 wire allows you to turn the tower on and also reset the tower. if you know the correct connection for onlu turning the tower on, then you can use the 2 wire switch. You can also bring the tower to a PC repair shop, they would be able to replace the switch with a 7 wire switch. I am not sure how much they will charge you since they all make up their own price. Let me know the outcome. It would have been great if you could provide pictures. I would be able to guide you to do the repairs. Mike
Nov 04, 2008 | Computers & Internet
Compaq Presario 4400us
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
Jun 21, 2007 | Compaq (388746-001)...
Computers & Internet Logo
115 people viewed this question
Top MPC Computers Computers & Internet Experts
Paul Bade
Muggs01
Muggs01
Mark Gough
Are you a MPC Computers Computer and Internet Expert? Answer questions, earn points and help others
