Question about Frigidaire 30 in. Electric Gallery Series Self-Cleaning Double Wall Oven
F7 error code- what does this mean?
F7 error code on Frigidaire oven
  • donvkr May 24, 2009
    I have a GE built in double oven model JKP27WOW2WW and I;m getting an F7 code. Is this the EOC of possible something that I can correct myself?
  • Frigidaire Master
  • 8,220 Answers
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
Display Condition Remedy
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Posted on May 17, 2009
  • Dan Webster
    Dan Webster May 17, 2009
    EOC=electronic oven control= the most expensive dang part on the stove. Recommendation: replace this control as it is cheaper than buying another stove. Beware: do not run a 900 degreeF self cleaning oven mode again or just get ready to buy another. The delicate mexasiantronics cant stand the heat for 3 hours.
3 Suggested Answers
Powerman
  • 68 Answers
SOURCE: Oven error code
See my solution to OVENMAN/April 12, 2007. I have supplied my fix to over 650 individuals and have had a high reported success rate.
Posted on Apr 14, 2007
  • 254 Answers
SOURCE: what is error message F7 mean in GE Wall Oven?
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Posted on Jan 31, 2010
Frigidaire error code f27 Ovens
Most error codes can be cleared just by unplugging the unit and re-plugging it back in. If this doesn't clear it then I would go to Frigidaire's web site and search for tech support. I did some checking with Frigidaire and they don't show a code f27 I was wondering if maybe it was showing two codes F2 and F7? so it might look like F2,7?
Nov 18, 2015 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire plef398acb error code f7
Error F7 is a bad control board. It has to be replaced.
Jan 06, 2012 | Ovens
GE Profile Wall Oven Model#PT916S error code F7
U have a bad clock or your probe inside of oven is bad.I would replace your probe first .it looks like a rod sticking out inside back upper top .f7 I believe means its not reading up temp and getting to hot
Nov 10, 2011 | Ovens
My stove is beeping and is flashing F7. What does this mean, it is a built in oven.
The F7 error code means that a function key on the touchpad is shorted or stuck, the F7 can be cleared by pushing the clear/off button,if the error code returns the touchpad would need to be replaced.
GENE
Sep 10, 2011 | GE Ovens
I have a GE double wall oven. I have a F7 errot on display. I unplugged the ribbon cable and shortly recieved a F0 error code on both the upper and lower side of the display. I replaced the ERC. it...
The F7 error coode means either the ERC or touch pad is bad. Having already replaced the ERC,replace the touch pad(the part w/the ribbon cable)
Gene
Aug 04, 2011 | GE Ovens
We had a power outage and when the electricity was restored the oven is displaying an F1 and F7 code and is beeping the alarm, how do i stop this?
Hello, the F1 error code means internal logic failure (monitoring function) it sounds alarm and inhibit cook mode You can fix it by replacing the electronic range control (ERC)
F7 error code means the function key shorted for over 16 seconds, check for something pressing a key or preventing normal release of the key. You can fix it by replacing the electronic range control (ERC) if other component check normal.
Thanks
Jul 14, 2010 | Thermador CM302U Electric Double Oven
My oven has an error code of F7. what is the problem?
Hello there
Any time that you get the f7 error this means
F7 Shorted Clear/Off Key due to membrane switch, control or connector Shorted key panel membrane switch; Check Electronic Range Control (ERC)
repair or replace keypad switxh or erc circuit
Mar 23, 2010 | GE PT956CMCC Profile 30" Built-In Double...
Oven shows F7 error problem with irritating beeping sound
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
May 13, 2009 | GE Profile JKP56 Electric Double Oven
Range led flash code F7
Here is the error information for Fault Code F7
F7 Lock motor relay watchdog circuit is active when it should be off Microprocessor checking the operation of the EDC lock, relay failed. Replace EDC.
Hope this is helpful, I will also provide you a link to to a helpful site.
http://www.applianceaid.com/fault_codes.html
Mar 14, 2009 | Frigidaire FEB27S5A Electric Single Oven
Frigidaire 30 in. Electric Gallery Series Self-Cleaning Double Wall Oven Logo
2,650 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
