Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Set shuts of with led light blinking 6 times ---turns right back on when power button is pushed, but does it again a couple of hours later
Sony wega hd tv shuts off with led light blinking 6 times. turns right back on when you hit the power button but does the same thing again a couple of hours later
  • REAPERS-HELP May 17, 2009
    MY TELEVISION WILL WORK GREAT FOR AWHILE , THEN TURN ITSELF OFF . THE LIGHT BLINKS 6 TIMES IN REPETITION . IT WILL TURN RIGHT BACK ON , BUT WILL GIVE A QUICK AND LOUD STATIC SOUND . IT WILL WORK , BUT WILL SHUT OFF A FEW MINUTES LATER .
SOURCE: Sony FD Trinitron WEGA KV-36HS500 blinking red light 6 times
My Sony KV36HS500 Trinitron is doing the same thing. Last night the next street over was hit by lightning. The "7" blink pattern was happening, so like the manual stated, unplug it for 4 hours. Which I did. The t.v. is back up and running fine. It's a nice t.v., better than the plasma I paid over a grand for, that's already shot. It's a good t.v. and good that Sony put in the stand by protection to prevent the t.v. from dying an unnecessary young death. Patience, don't rush it, unplug the t.v. and leave it sit. Also, don't use a power strip, that was my mistake, and unplug your t.v. if storms are in the area, I was too lazy to and now I had to deal with this, in 8 years, only twice did this happen. I'd buy another one tomorrow if they still made them.
Posted on Jun 15, 2008
  • 61 Answers
SOURCE: Sony Wega 40" TV will not turn on, standby light blinks 6 times repeatedly
Hello,For model KV-40XBR800,
Pls check following area.
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high
turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
And NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks.
Good Luck
Dals123
Posted on Oct 15, 2008
SOURCE: Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Posted on Dec 01, 2008
SOURCE: Sony FD Trinitron WEGA KV-24FS100 24" TV On/Off problems
I think I have the solution for you. I have the same tv and it does the same thing when you turn on the power button on the remote when the tv turns on you hear a click then the red light flashes about 5 to 6 times then the tv comes on. on the remote there should be two buttons on top of the remote one says power and the other one says system hit the power button to turn on the tv when you hear the click and see the red light flashing then hit the system button which will turn off the tv then hit the power button again and it will turn the tv on without the red light flashing it should work
Posted on Jan 10, 2009
SOURCE: STANDBY LIGH BLINKING 9 times...
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
We need help...
Lori Nall
Posted on Jun 21, 2009
Sony Trinitron Wega Standby blinks & the TV won't turn on
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 12, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony grand wega
It may be a power supply fault
May 19, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
TV won't turn on, standby LED starts blinking
HI, this is the result of an unstable power sector in this unit. the fly back is malfunctioning and, you will need to replace it asap. i will list the part number below and a link to a site as well. you can purchase this part on-line if you wish.
FBT ASSY NX-4521//X4
Sony Part Number: 1-453-310-11
CLICK HERE TO ORDER
Jun 21, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Triniton Wega Model KV 32HS510. After pushing the power button,the tv starts to power up, then the standby light blinks 7 times then pauses before blinking 7 times again. It continues to do this,...
This is usually an indication of a failure in the scan amplifier sections. When the scan amplifiers or high voltage sections fail, the main power supply will usually also require servicing.
It is very common that the fly-back and high voltage multiplier and also the horizontal output stage fails in these sets. Along with it, the power supply will usually require to be serviced. On rare occasions, the vertical deflection amp fails.
Jerry G.
Jul 08, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
smack it on top a couple of times, it works for me :)
if ya cant duct it, smack it...
seriously...
Jun 29, 2008 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony - Projector TV won't turn
Sony TV;s will give a service code, count the blinks, eg; 2-6, light will blink X amount of times, hesitate & blink again so many times. Count and report back but, I would recomend to unplug the TV's power cord, to reset the TV's system. Unplug for at least 3 minutes. I hope this was helpful.
Jun 11, 2008 | Televison & Video
Apr 07, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
While charging my O2 atom exec, the LED (Flash light) does not glow red ?
I have the same problem. What I did several time is to actually shut down the phone, remove the battery and leave it like that for several hours (3 to 4 hours). Then, I put the battery back in the phone, and it would charge again. However, due to the long time with no battery, the phone's clock would be reset to January 2007.
I found no other work around right now. However, I have to do this more and more often, almost once a week ...
Mar 21, 2008 | O2 Xda Atom Exec Smartphone
Televison shuts makes a sound and shuts off repeatedly
Probably needs an original SONY lamp instead of the "replacement" lamp you put in.
Dec 23, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
323 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
