Question about Canon Cameras
Upload canon a1100is to pc problem
I have just purchased a A1100is (having previously had Powershot A85). The new zoombrowser installed over the existing one but the program says "cannot detect camera" when I plug in the USB to the new camera. It detects the A85 though? but not the new one?
  • Canon Master
  • 4,738 Answers
First try uninstalling and reinstalling Zoombrowser. If that doesn't help, it's very hard to troubleshoot software problems online. But why put up with the headaches of bad software in the first place? Please see the following blog article, as it describes the use of a card reader as a much easier, faster, and less error prone way to download your photos. In fact there are several important reasons discussed in the article for using a card reader vice downloading from the camera. USB Card readers are also very inexpensive these day, with cost virtually not an issue:
http://camerarepair.blogspot.com/2009/01/how-do-i-download-photos-or-pictures.html
Posted on May 17, 2009
Need operating instructions for Canon Power Shot A1100IS
Try Googling (canon)(A1100IS)(manual) without parens.
Aug 15, 2017 | Canon Cameras
Canon a1100is camera battery door replacement
Kurt- I have successfully completed a d-i-y battery door replacement on my Canon A1100IS, and I make no claims about being an "expert." My training was watching u-tube videos of guys disassembling digital cameras (other models). Here's how to open the case on the A1100is, which is not really much different than opening the case on most any compact digital camera.
Using a size #0000 phillips screwdriver (Sears sells a set of 6 minis--slotted and phillips--for $10), I removed the nine screws from the side and bottom of the case plus one inside the mini-usb cover and the one inside the battery compartment.
Then, I gently worked the front and rear of the case apart (the top of the case halves have two snap clips that hold them together. Unlike some cameras, the A1100IS does not have any flexible cable straps between its front and rear covers.
With the case halves removed, I then used a tweezers to move the straight end of the hinge spring out of its original place next to the tripod socket. That released spring pressure on the hinge and I could then easily remove the hinge pin with the tweezers.
Then, it's simply a matter of placing the replacement door's hinge/spring combo in the proper location and inserting the hinge pin to hold it there. I purchased a new door from Canon for $8.42 plus shipping). Then, I used the tweezers to position the straight hinge spring end in the slot next to the tripod socket.
The only thing left was to wipe my fingerprints off of the LCD screen and then gently replace the front and rear case halves--snapping the case's top together and then replacing the nine screws.
Feb 26, 2012 | Canon PowerShot A1100IS 12.1 MP Digital...
Powershot a1100is camera card is locked! How do I unlock it?
do u mean sd card then theres this like swich thing just move that to the way that you can
Jul 22, 2011 | Canon Cameras
I have a Canon powershot A1100is dig camera. When I try to turn it on, it reads need new batteries. even if I change the batteries. Sometimes it wont even turn on. Help
Do you using Ni-MH batteries? Canon cameras judge the battery is low power by the real-time voltage of the batteries. And the voltage of Ni-MH batteries are lower than Li-ion ones, so the camera will notice low power even there are new batteries. Try Li-ion ones and see is anything help. best wishes!!
If you will use of a special battery, please come to our online shop for digital camera batteries
Feb 21, 2011 | Canon PowerShot A1100 IS Digital Camera
How do you restart the canon A1100
http://www.freeservicemanual.co.cc/canon-powershot-a1100-user-manual/
canonpowershota1100.com/wp.../canon-powershot-a1100is-manual.pdf
This info is all in the user manual, so I have found one for you for later reference. Please simply download from the link above....
in any event the best way to restart is to Power OFF & then ON again, this will reset all settings and restart the software again.
Feb 13, 2011 | Canon PowerShot A1100 IS Digital Camera
I have a canon A1100IS and the LCD screen will not come on. Any suggestions would be appreciated. Thanks.
Try this.
1. turn it off
2. remove the batteries and memory card
3. reinstall new batteries and the memory card
4. turn it on.
If this doesnt work it will need servecing/repair.
May 30, 2010 | Canon PowerShot A1100 IS Digital Camera
There is no
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use ZoomBrowser or any other photo cataloging program.
Jan 24, 2010 | Canon PowerShot A1100 IS Digital Camera
How to down load the pictures from camera with microsft 2003
It's quite simple .Just connect your canon camera to your computer .when it's connected open the folder and simpley copy all jpeg images and past it where every you want
Jun 23, 2009 | Canon PowerShot A85 Digital Camera
Cameras Logo
168 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
