Question about HP Pavilion F1903 19" Flat Panel LCD Monitor
Pavilion f1903 silver goes blank seconds after turning on.
The monitor goes blank a second or two after turning on. Cannot get the screen to stay on. power button shows blue (on) but blank screen. Shows desktop for a second then goes blank.
    Novelist:
  • 89 Answers
The monitor you have has bad components on the circuit boards inside.
This is a classic problem with all LCD monitors.
I rebuild them on a daily basis so I recognize the symptoms.
I would suggest finding someone who can do component level repair on the circuit boards inside.
I also suggest not trying to repair yourself as there are many breakable components to them as well as components inside that do not like static electricity discharges.
Posted on May 17, 2009
  • 23 Answers
I had the same problem, I replaced the 4 transistors (C5706) on the inverter board and then I had a very beautiful picture once again. Although I used (C5707) transistors because that is what I had on hand and have used them in other Dell monitors.
Posted on Jun 17, 2009
When i turn on the monitor it flashes on once for a few seconds t
faith1114, Try this first! See if any thing seems a little similar to your f1903 type of complaint. Problem been around a long time!!! Go do some reading here: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution. After doing some reading there, you will be in a better position to make decision to DIY repair, contract out the repair work, trade in for new , DIY repair + buy a new monitor keeping refurbished f1903 as emergency spare. Here is a little clue. If unit can display Win-desktop for 2 seconds and then the "black screen of death happens" you certainly need to do some reading and viewing of DIY videos at YOUTUBE so you can understand the big problem all major CCFL back-lit lcd monitor manufacturers are facing. do some additional reading here at fixya in the profiles of ccfl backlit lcd monitor technicians "budmrtn" "buddymc" , "12fixlouie" (late) "louie12fix" (old) Follow links you find there. Once you understand basic problem you will never walk past the new curlie-Q, screw-in energy-efficient CFL light bulbs at the local hardware or big box homecenter ever again with out having a slight grin on your face!! Bye for now. 12fixlouie
Jun 02, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
My HP vs19e Monitor went black, when I turn it off...
guest, If monitor vs19e acts same when connected to different "known good" pc then try this site for info: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ How old is this model? When was last time it worked correctly? 12fixlouie
May 19, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
When turning on my monitor - the blue light is on
This could mean that you video card is bad or going bad. Also that the monitor is going out too. Its one or the other.Try to plug the monitor into another computer to test it first. It will give you an idea where to start. then move to the video card.
Feb 15, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
No picture
Hi
You have parts on the power supply board which are going bad. You can send it to a company like mine or take it to a local repair person.
Aug 05, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Hp vs17e monitor says it's in sleep mode then goes blank
check the board postings for the HP f1903 monitor.I recall seeing a problem of the same there and a solution or fix. As it is only a newer version of the same model, it may be the same fix. Appears HP has a big problem with QA and this particular model. Lots of people have same or similar problems, and all appear to have a similar fix or solution. Tricky part... figuring out how to "Open" the monitor to check it inside!
Good Luck.
PS - if you figure out the opening part, let us all know!
Feb 02, 2009 | HP Pavilion F1703 17" LCD Monitor
Hp1903 blank screen
power shortage maybe...try to plug your monitor on the other power supply,,be sure that your monitor is compatible on the voltage it required..
Aug 04, 2008 | HP vs19 (Silver) 19" LCD Monitor
Monitor going black
HP's are known for bad capacitors in the power supply.
Replacing them is simple if you know how..not so simple if you don't.
Try your local TV repair centre. It should not cost alot to have the capacitors replaced.
Hope it helps =)
Apr 06, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
HP F1903 FLAT PANEL POWER PROBLEMS
internal power supply failure in the monitor generally repair is more costly then replacement,that can be verified if you can find a tv repair shop that provides free estimates.
Dec 26, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
HP Pavilion F1903 19" Flat Panel LCD Monitor Logo
426 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
