Question about Kicker KX1200.1 Car Audio Amplifier
I have a Kole Audio amp and the green light comes on like everything is ok, but no sound comes through the subs
The speakers or the plugs are not connected correctly
Posted on May 18, 2009
The fan has a short and its sparking and channel is blown no sound coming from it but the power light is coming on and it is green like nothing is wrong with it
First of all remove this amp. from your car asap. Having something in a car that creates spark is a big no for safety reason. Once you have this take out, unscrew the amp unit and check for shorting wires and burnt parts. You need to send this amp for a service, most probably the amp IC is gone bad due to spark. Green light glowing seriously does not mean here that everything is fine. Its just an LED glowing.
May 05, 2011 | Kole audio Q1-3000D Car Audio Amplifier
The light is red and no bass is coming out of my subs
The Amp Is Most Likely In Protection Mode... 2 Ways To Figure Out Whats Wrong With it Is Check Every Single Wire And Make Sure That Every thing Is Hooked Up Correct And There Are No Bad Connections With Ur Remote Wire, Ground Wire, And Battery 12v Wire, Rca Cables As Well. If Every Thing Checks Out Good Then Try Checking The Fuses And Make Sure u Are Using The Correct Fuses That Are Good For That Amp. If U try These 2 Things And You No Your Subs Are Hooked Up Correctly Then The Worst Is Probably There. I Had The Pioneer 7200 Amp And It was A Blown Amp And The Red Light was Constantly On. No Sound No Nothing. If U Try Those Steps And it Still Does Not Work Then Most likely Your Amplifier Is Toast. Hope This Helps :-)
Feb 18, 2011 | Kole audio Q2-1920 Car Audio Amplifier
The green light stays on but sound comes out like a skipped cd
Check your RCA jacks. Wiggle them around a little, and see if it changes anything.. It could be a bad RCA< or the inputs them self. Could also be caused by over loading the amp. if nothing changes when you wiggle the RCAs then disconnect one of your subs. If disconnect the sub makes it play right then your impedance is to low, and is causing the amp to clip.
Aug 21, 2009 | Kole audio QX2-980 Car Audio Amplifier
Amp runs but then will just turn off and red light comes on
you may have fried the amp pre outs in the head deck, try the amps on another stereo
Jun 01, 2009 | Lightning Audio Bolt B2.150.2 Car Audio...
Kole amp in protect mode?
Are you setting the bridge switch for both left and right or are you trying to run both subs off of one set of terminals? If you running the subs off one set of terminals you are effectively running the amp below 2ohms and thus the amp is not 2ohm stable and you will destroy it.
Some amps actually all ready run a bridged output for left/right operation, this could also be the reason why the protection circuit is kicking on.
Either way it's a component mismatch and you either need a stronger amp or different subwoofer setup.
Mar 09, 2009 | Kole audio Nitric XP2-2000 Car Amp
Protection light
Hello. First, disconnect all of the speakers the amp is driving and the rca inputs while the amp is off. Now power on the remote. If the prot. light still stays on you will need to varify that the voltage across the ground and b+ terminals is a minimum of 12 volts. If this is true than your amp may be damaged due to shorted parts. Otherwise, try to repower the amp while a speaker is connected and if it is O.K. than there may be a problem with the RCA ground in the head unit or the amplifier. We service these amps at Sound Repair 321-690-0808.
Jul 10, 2008 | Kole audio Q1-3000D Car Audio Amplifier
Kole Q1-3000D Power Supply caps Keep blowin
you need a fuse of 300amps or higher with 1/2aut cable power supply connected to an after market altenator. also make sure the subs are wired properly.
Nov 12, 2007 | Kole audio Q1-3000D Car Audio Amplifier
How should I wire up this amp and sub
The amp's not actually a very good match for the sub, since the sub can be wired for 2 ohms or 8 ohms, and the amplifier is most efficient at 4 ohms in bridged mode. My advice would be to wire the amp in bridged mode, and wire the sub for an 8 ohm load. To do this, the amp's (+) wire should go to the (+) terminal on one of the sub's voice coils. Then run a wire from the (-) terminal on the OTHER voice coil to the (-) terminal on the amp. The remaining (+) and (-) terminals (on opposite voice coils) should be connected to each other with a wire. Your original wiring setup had the amplifier connected to only one voice coil, while the other voice coil was shorted.
Jun 10, 2007 | Kole audio Q2-480 Car Audio Amplifier
Problems
chenge and replace the safe of the amp
May 22, 2007 | Kole audio Q2-1920 Car Audio Amplifier
Kicker KX1200.1 Car Audio Amplifier Logo
57 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
